Lower control arms needed? - JeepForum.com
post #1 of 3 Old 05-29-2013, 10:46 AM Thread Starter
toxicwaste29
I put on a RK 2.5" this weekend and was going to take it into a local shop for an alignment. I got the kit that didn't have lower control arms. If I get it aligned say tomorrow and buy front lower control arms next week, could I put on the new lower control arms without needing it aligned again?
toxicwaste29 is offline
post #2 of 3 Old 05-29-2013, 11:28 AM
222Doc
222Doc's Avatar
if they need to adjust the caster, as you lift the jeep it loses caster, the only good way is with adj. arms.
JeepJK the only real adjustment is toe in. Unless you have bent the tie rod bar. The lift changed nothing but caster angle.
everyone Iknow and myself just use a tape to set toe, its 1/8 inch.
They can adjust camber but the would need special ball joints. Cost is high.
They can sdjust caster with Cam bolts, not recommended off road, they tend to wallow out the bracket under harder off road use.
222Doc is online now
post #3 of 3 Old 05-29-2013, 12:17 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
As 222Doc said, there are no adjustments other than toe that can be done on a stock JK. Since the tow can be done in a driveway with a tape measure, it doesn't really make any sense to get it aligned. If you're planning on getting the LCA's, I would just wait then take it to the alignment shop and have it done with the LCA's installed.
I hope this helps!
-Zach
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
