LOW tire pressure warning.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > LOW tire pressure warning....
GenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWarn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 08-03-2010, 02:04 PM   #1
JeffinWesternWA
2010 JK Wrangler
Was traveling the WA / OR "gorge" this weekend when decided after a concert to head up to Goldendale Observatory and see the stars...The Observatory is up a bit of elevation and was maybe 10~ish degrees cooler (about 60'F vice 70' down in the Dalles). Got up to there and low tire pressure lite came on just as I parked after an hour ride up. Restarted engine after an hour and still got the LP lite, visual check of all 5 tires was fine, drove down and lite was off after about 30~ mins and didn't reappear. Got home and rechecked tires w/ accurate gauge and All 5 were still @ 35.5-36.0 lbs at 70'F (cold after overnight) ...just the same pressures as I started trip.
Wasn't pressed against any curbs, potholes etc., and the ride was fine too. No visual problems after checking today
thoughts of this gremlin?
JeffinWesternWA
JeffinWesternWA is offline   Reply With Quote
Unread 08-03-2010, 02:12 PM   #2
ncb
Plasti Dip yourself!
ncb's Avatar
2009 JK Wrangler
Probably had a tire that dropped below the pressure threshold from the cooler air. If I remember right the sensors trip below 37PSI. I wouldn't worry about it.
ncb is online now   Reply With Quote
Unread 08-03-2010, 02:16 PM   #3
JeffinWesternWA
2010 JK Wrangler
pressure recommended on the JK Sport IS 35 lbs COLD so I imagine the sensor/lite is set lower, maybe around high 20's perhaps(?) and a 10'F temp change and some altitude shouldn't set it in the description I gave but, that "in combo" was my thought of why. Wasn't worried as much as curious....street driving I find that 36-37 lbs is wearing tires nice/good mpg but ride doesn't justify any more pressure over 37~...
JeffinWesternWA
Unread 08-03-2010, 02:22 PM   #4
1222
Make mine a Jeep!
1222's Avatar
I had my sensor go of a couple of times for no apparent reason. It was very hot out at the time. One time it was on for two days. Of course I checked the tire pressure and everything was fine. I just mark it as a glitch. I still think it’s a very good system to have. I like it.
1222 is offline   Reply With Quote
Unread 08-03-2010, 02:43 PM   #5
OneLoud
10* outside temp shouldn't make a difference. I would just keep an eye on the pressures and if you don't see the light again in the next month or so, just forget it.
Nyctophobia...I'll beat this b!tch sooner or later!
[URL="http://www.jeepforum.com/forum/f7/pay-forward-1091342/"]http://www.jeepforum.com/forum/f7/pay-forward-1091342/[/URL]
^Check this thread out!!!^
"What is this? It's my car, it's a Prius. It literally feels like I'm riding around in a vigina right now!"
OneLoud is offline   Reply With Quote
Unread 08-03-2010, 02:48 PM   #6
JIMBOX
I'm afraid the sys is a PITA
I just set mine to "0", so now I get NO chimes and NO lights
I set it because I've got wheels on, with no xmitters inem !!
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote
Unread 08-03-2010, 03:00 PM   #7
WhiteJK
2009 JK Wrangler
My low pressure light came on this morning. Had all my tires at about 32-33psi, one was actually at about 31psi. I went ahead and bumped all of them up to 35psi and drove home from work, about 30 miles, with no problems with the light any longer.
WhiteJK is offline   Reply With Quote
Unread 08-03-2010, 03:10 PM   #8
wilywillie
wilywillie's Avatar
I keep mine at 37psi hot, and my OEM TPMS is set at 35.
During the winter, -10 to 10*F, they can come on when it sits overnight, but driving it for a few minutes sends the light away.
(there's also the air compressor option)
wilywillie is offline   Reply With Quote
Unread 08-03-2010, 04:41 PM   #9
md41969
Mine has come on 5-6 times and it's never been because the pressure was low. I carry a guage and check each time but haven't had anything other than a false reading yet.
Current:
2008 Rubicon Unlimited
Sold:
1995 Wrangler
White Jeep Club Member #81
Originally Posted by FourbyFour View Post
"....you know what hurts the most, it's the lack of respect, that hurts the most.....and, and the the other thing hurts too, BUT not as much as the lack of respect..disgusting.."
Originally Posted by Rob99 View Post
Your dog's head doesn't look like it belongs on his body. Is it an aftermarket head?
md41969 is offline   Reply With Quote
Unread 08-03-2010, 05:05 PM   #10
JeffinWesternWA
2010 JK Wrangler
Is the "Warning pressure lite" adjustable to the temp it comes on? (w/o a programmer?)
JeffinWesternWA
Unread 08-03-2010, 05:15 PM   #11
JIMBOX
--The TPMS sys. doesn't measure temperature, it's based on tire air pressure !
It's not adjustable--without an external chip
JIMBO
Yellow Jeep No. 683
Unread 08-03-2010, 05:37 PM   #12
JeffinWesternWA
2010 JK Wrangler
yep, meant pressure, typed 'temp', i'm 50, excusable...
JeffinWesternWA
Unread 08-03-2010, 05:42 PM   #13
JIMBOX
Heh Heh, well you're kinda right anyway, the higher the temp--the higher the air pressure and vicey/versey !!
JIMBO
Yellow Jeep No. 683
Unread 08-03-2010, 05:43 PM   #14
JeffinWesternWA
2010 JK Wrangler
JIMBO
Ya don't "change a chip"... just a reflash of the eprom....but, that's what ya meant
JeffinWesternWA
Unread 08-03-2010, 05:47 PM   #15
JIMBOX
Well, call it what you want, my chip is an AEV Procal !!
JIMBO
Yellow Jeep No. 683
false reading , JK Wrangler , reading , t.p.m.s. , threshold , tpms , wrangler
