Low Tire Pressure - JeepForum.com
post #1 of 8 Old 02-08-2011, 06:02 PM Thread Starter
georgemanfra
2010 JK Wrangler
Low Tire Pressure
Hello All! I'm new to this forum, and here's my first post. I have a 2010 Jeep Wrangler Unlimited. My Low Tire Pressure warning light recently came on. My tires' stated maximum air pressure is 35 lbs. (these are the stock tires that came with the Jeep). I checked my pressures and found them all to be hovering around 30 lbs., so I increased them to 32 lbs. Still the warning light stayed on. I called my dealer's service department and asked his advice. He stated I need to fill the tires to 37 lbs. I'm in New England and we're buried in cold snow. I'm leary of inflating my tires over their maximum limits. Any thoughts out there? Thanks in advance.
georgemanfra is offline
post #2 of 8 Old 02-08-2011, 06:11 PM
Blu-Jacket
2009 JK Wrangler
What does it say for tire pressure inside your left door jamb? That is the pressure you need to set them at. Otherwise, you will not satisfy the TPMS and the light will not clear. Also, once you do get them inflated, it's not uncommon that the light won't extinguish until you drive a few miles.
Blu-Jacket is offline
post #3 of 8 Old 02-08-2011, 06:46 PM
Vin
Fill them to 37-40 psi. After the light turns off you can air down to a more comfortable pressure.
Vin is offline
post #4 of 8 Old 02-08-2011, 07:20 PM
jabsther
2010 JK Wrangler
Dont forget about the spare tire pressure also will affect the TPMS.
jabsther is offline
post #5 of 8 Old 02-08-2011, 07:58 PM
paul84043
When the air gets cold, the pressure drops and the sensors come on. Ther'es a bit of hysteresis built in so you have to overshoot the setpoint and then you can come back down to what it's supposed to be.
paul84043 is offline
post #6 of 8 Old 02-09-2011, 06:52 AM Thread Starter
georgemanfra
2010 JK Wrangler
Low Tire Pressure
Thank-you to everyone who replied. I always judged tire pressure levels by just what it said on the tire, but I'll now check what the door jamb tag says since they're the stock tires. Didn't know that there was a way for the Jeep to know what the spare tire pressure was. i didn't check that pressure since I have a locked spare tire cover on it and it was very cold at the time. Just too lazy to unlock and remove it. Thanks again everyone!
post #7 of 8 Old 02-09-2011, 07:33 AM
JIMBOX
Gettan AEV Procal Module-
Then you can change tires/set any pressure/correct speedo-a whole buncha things-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #8 of 8 Old 02-09-2011, 01:59 PM
jrmandryck
I turned mine down to 0psi because in Maine now with the temp change of 40* it goes off almost every morning
jrmandryck is offline
31" BFG A/T Tire pressure and Spare tire carrier Questions.. jeep2029 TJ Wrangler Technical Forum 14 08-20-2009 07:31 PM
What tire pressure should I have? jeep-newbie JK Wrangler Technical Forum 12 09-25-2008 04:53 PM
Tire Pressure MUDDYJEEP YJ Wrangler Technical Forum 4 10-17-2007 02:43 PM
MTR Tire Pressure fivedive69 TJ Wrangler Technical Forum 4 10-04-2007 04:40 PM
Tire Pressure? brk913 YJ Wrangler Technical Forum 9 10-11-2006 11:41 AM
