low temp thermostat Qs? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > low temp thermostat Qs?
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-26-2015, 04:04 AM   #1
zjilla
2013 JUKR Auto
Installed 180 degree thermostat
(in effort to keep it from running at high temp). I flushed the rad fluid 5 times, cleaned the mud out of the radiator fins without bending them. and this thermostat. The jeep did over heat at one time. I did all this to combat a break down in fluid life and off chance that the thermostat was fried (b/c it was over heating intermittently)
The thermostat did the trick for the overheating problem, but no throws a CEL code every 200 miles or so.
Is there anyway to have the jeep computer mesh with this new thermostat? Other than that, the jeep cools and runs great.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 08:52 AM   #2
ronjenx
ronjenx's Avatar
If replacing the thermostat fixed the overheating problem, one with the proper degree setting would have fixed it, too.
If you want to lower the water temp in your JK, you need to increase the amount of air through the radiator so the temp will hover around thermostat temp. In the JK, that would be 195°F, which is plenty cool enough.
To increase the air through the radiator, you can lower the temp the fan comes on with a programmer. Or, you can install a mechanical fan that pulls air all the time the engine is running.
Otherwise, even with your 180° thermostat, the water has to reach the same high temp before the stock fan will come on. When on the road, there is sufficient air to keep the water temp low, but 180° may be too low for the computer's liking.
Put the correct thermostat in there, and consider the two possibilities I mentioned above.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 09:50 AM   #3
LVCapo
The Voice of Reason
LVCapo's Avatar
What's the code you are getting? RIPP sells a 180F thermostat to go with their supercharger, and I've seen others add the 180F thermostat without any problems.
Have you taken it to the dealership and have them check the cooling system? I've seen some instances where casting sand was stuck in the cooling system and caused issues. When you flushed the system did you use the right coolant? The 2013 Wrangler uses OAT coolant, the really expensive stuff.
LVCapo is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 01:00 PM   #4
number40Fan
2014 JK Wrangler
Probably an unable to reach operating temp code.
number40Fan is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 04:51 PM   #5
goodwrenchdave
Most likely a p0128."Coolant Temperature Below Thermostat Regulating Temperature": The ecm monitors the amount of time to reach a predetermined temperature and hold. it calculates in outside temp, coolant startup temp, time, load etc etc.
And unless aftermarket has some bypass to this; no there is no way around it, it is seeing a bad thermostat (as it is out of specs of the original)- one that opens before it's suppose to.
A cooler thermostat will allow an engine to run cooler but will do nothing for overheating as it "flows" the same as a higher temp thermostat when open.
If you don't want other problems (higher fuel consumption, fouled plugs, reduced life of catalytics; put the OEM spec thermostat.
You probably had a bad thermostat originaly(one that didn't fully open)if it fixed the overheating, so just swap back a new oem spec. thermostat
Thermostats are one of the parts that I will only go original manufaturer on- seen to many aftermarket nightmares. Yes they cost more but so much can go wrong when they fail.
goodwrenchdave is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 06:08 PM   #6
duneslider
Doesn't the Ripp tune also adjust the thermostat setting so you don't get the code? I thought I had heard that but I could be wrong.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 09:53 PM   #7
zjilla
Thats the only thermostat quadratec sold for the 3.6L. Ill look elsewhere for the right one
Sent from my GT-N7000 using JeepForum
Unread 01-27-2015, 05:37 AM   #8
JLH
2015 JK Wrangler
Just go to the Jeep dealer and buy one. They are not that expensive. Avoid the $2.00 Saturday night specials at the auto parts stores.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 06:28 AM   #9
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
RIPP adjusts the timing of the fan kicking on. It comes on more often to keep the radiator cool despite having the intercooler in front.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Fox 2.0 shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
"Don't give up 5 minutes before the miracle occurs."
HappyTrails is online now   Reply With Quote Quick reply to this message
Unread 01-27-2015, 03:45 PM   #10
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by LVCapo View Post
I've seen some instances where casting sand was stuck in the cooling system and caused issues. .
Pentastar block and heads are die cast - no sand in the process... where does casting sand come from otherwise?
edit: found this - High-pressure die-cast aluminum cylinder block and semi-permanent mold aluminum cylinder head - NOT die cast head but SPM is a sandless process (sand mold is sacrificial mold - not semi perm)...
J Wm Bishop EA, ASADE
I am a LEADER - not a FOLLOWER. Unless its a really steep hill with a good chance of falling off the mountain - then screw that YOU'RE going first...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 04:04 PM   #11
JBTJ
You need a 195 degree stat. Now the computer thinks it's in warm up mode and is running rich. Even just a little mud in the radiator will cause it to over heat due to poor air flow.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 05:27 PM   #12
LVCapo
The Voice of Reason
LVCapo's Avatar
Hmmm, must be a lot of people imagining the issue then.....cuz Chrysler has already acknowledged the problem. Google "Casting Sand Pentastar".
Unread 01-27-2015, 05:29 PM   #13
ronjenx
ronjenx's Avatar
The problem exists. It just may not be sand.
2008 JKU Rubicon
42RLE Auto
Unread 01-27-2015, 05:35 PM   #14
LVCapo
The Voice of Reason
LVCapo's Avatar
Well, there's pictures and YouTube videos showing the sand if you Google it.....but ok...
Unread 01-27-2015, 05:40 PM   #15
ronjenx
ronjenx's Avatar
I have seen the pics. Have not seen confirmation it's sand.
2008 JKU Rubicon
42RLE Auto
