Loud Squeaking From Rear Driverside Wheel - JeepForum.com
post #1 of 6 Old 06-01-2009, 11:19 AM Thread Starter
Enforcicon
In the last couple days I have started hearing a loud squeaking noise coming from my rear driver's side wheel. It goes away after a few miles but starts up again every time I drive. Any thoughts on cause/ or fixes?
Now a Forum Supporter! Previously: Hyperjeevz
2007 JK Wrangler X (2dr)
255/75R17 Goodyear Wrangler SR-A's on 17" Rubi Wheels, 4.10 Gears/Tow Package, 6" KC Slim Lights w/ Windshield Mount, Rugged Ridge Tubular Side Steps, Rugged Ridge Headlight and Tail Light Gaurds, Brushed Aluminum Grill Inserts, Cool Tech Switch Panel, CB Radio w/ 4ft FireStik
Someday: Shrockworks Bumpers Front and Rear, 2-3 inch lift, Winch, etc...
Enforcicon is offline
post #2 of 6 Old 06-01-2009, 12:03 PM
bunkrdfool
Whooops never mind, you said rear, my eyes saw front. sorry
USAF Security Forces. Keeping your chair safe since 2009.
bunkrdfool is offline
post #3 of 6 Old 06-01-2009, 12:25 PM
FatBuoy
FatBuoy's Avatar
Here's my thread from a while back and still no resolution...does it stop when you hit the brakes?
http://www.jeepforum.com/forum/f96/squeak-squeak-squeak-632063/
Black Rubi JKU with a rompin' stompin' 6.1 magnuson supercharged hemi!
FatBuoy is offline
post #4 of 6 Old 06-01-2009, 12:25 PM
tricked919
...first off, you don't have u-joints in the rear...
secondly, I'd almost bet a small fortune that its your emergency brakes. There is a drum brake assembly inside the rotor hat - that is your parking brake. If you get any kind of dust/grime (mud) in there it will squeal badly - sounds almost like a bearing gone bad.
You might get lucky and be able to spray a high pressure hose up there to clean it out. Worst case, take of your wheel, loosen your caliper and swing it up (just like you were changing your pads) and pull the rotor off. Once you get it off, spray a bunch of brake cleaner in there.
I've done mine a few times and it works every time.
tricked919 is offline
post #5 of 6 Old 06-02-2009, 12:53 AM
ElPaso2007
ElPaso2007's Avatar
Thanks, this might resolve this same problem for me.
ElPaso2007 is offline
post #6 of 6 Old 06-02-2009, 07:51 AM
ctown67
i had the same situation that was resolved with some e brake adjustments.
List of stock parts that have been eviscerated.
power steering pump, tie rod, front left knuckle, horn, weld on rear track bar, rear track bar bracket, both rear fenders, front passenger fender, punctured spare tire, rear bar pins, steering stabilizer shock, front drivers side shock, spare tire carrier.
ctown67 is offline
Steering making a loud squeaking noise! ninjajeep TJ Wrangler Technical Forum 12 09-13-2009 10:18 PM
tension wheel squeaking/squealing CRISTOF1 TJ Wrangler Technical Forum 0 08-19-2009 12:32 PM
squeaking steering wheel... genisis88 TJ Wrangler Technical Forum 3 02-23-2009 01:13 PM
replaced wheel bearings same squeaking noise back??? snakester14 TJ Wrangler Technical Forum 9 04-09-2008 04:27 PM
My steering wheel is squeaking.... Beefstew TJ Wrangler Technical Forum 4 12-12-2007 10:20 PM
