Loose hose (breather tube?) help - JeepForum.com
post #1 of 14 Old 02-18-2009, 07:44 PM Thread Starter
ge2
Gold Member
ge2's Avatar
So I just walked into my garage and as I walked up behind the jeep, I see a hose dangling. Get up under there and the loose end appears to be plugged with a white cap, but there is also a metal clip on the hose. It just came unclipped from where it belongs. It wasn't like this earlier this morning. Can someone tell me where to re-attach it? It's still attached to the axle.... it's the upper end that is dangling down.
ge2 is offline
post #2 of 14 Old 02-18-2009, 07:49 PM
BiGEN
i'd make it longer so u dont have to worry about it ever getting water in it...
FOR SALE!
R.E. Monotube Shocks - $200 NEW PRICE
[/color]
BiGEN is offline
post #3 of 14 Old 02-18-2009, 07:51 PM Thread Starter
ge2
Gold Member
ge2's Avatar
If, in fact, it is just a breather tube, I'd love to make it longer. Just seems kinda odd that it's got a plug on the high end. Plus-- between now and when I lengthen it, I still need to hook it back up. Can anyone either tell me, or snap a pic to where it should be clipped?
ge2 is offline
post #4 of 14 Old 02-18-2009, 08:03 PM
4whelin
Look around on the pumpkin(gear housing) there should be a short tube coming from the side near the top of it.
2008 JK Sahara 4dr. Wangler, Red Rock, Crystal Pearl, BFG M/T 35" w/ Pro Comp 7069 wheels, V-6 with Auto tranny, 3.5" Rubicon Express lift, 3 way hard top, My Gig system (to cool), 40 ch. Cobra CB, Xenon flat fenders, 12k Mile Marker winch, Tatrum LED rock lights, Front/Rear Smittybilt XRC bumpers.
River Raider rock sliders.
"you're not a serial killer till you get caught"
4whelin is offline
post #5 of 14 Old 02-18-2009, 08:06 PM Thread Starter
ge2
Gold Member
ge2's Avatar
No-- it doesn't attach to the pumpkin. In the pic I posted above, it is connected properly, so you can see clearly it doesn't go to the pumpkin.
ge2 is offline
post #6 of 14 Old 02-18-2009, 08:07 PM
BiGEN
it should be snapped somewhere near the wheel well on the frame.. if i remember right..
FOR SALE!
[/color]
BiGEN is offline
post #7 of 14 Old 02-18-2009, 08:09 PM
BiGEN
YES... its on the pass side rear right above the frame.. mine feels like its just tucked in there...
FOR SALE!
[/color]
BiGEN is offline
post #8 of 14 Old 02-18-2009, 08:11 PM Thread Starter
ge2
Gold Member
ge2's Avatar
Hmmmmmm.... it's just tough. I snapped that picture a few days ago, when the hose was attached properly (at least I assume it was). So what you're seeing here is the hose, properly attached, when viewed from the back passenger corner. It looks to me like the hose goes more towards the center of the jeep, as opposed to the frame near the wheel well.
ge2 is offline
post #9 of 14 Old 02-18-2009, 08:12 PM Thread Starter
ge2
Gold Member
ge2's Avatar
Ok-- I posted that last one before your last post, I'll go check there. Thanks!
ge2 is offline
post #10 of 14 Old 02-18-2009, 08:17 PM
BiGEN
one the the plastic bolts or w.e u wanna call them on the inner fender is holding mine in..
FOR SALE!
[/color]
BiGEN is offline
post #11 of 14 Old 02-18-2009, 08:22 PM Thread Starter
ge2
Gold Member
ge2's Avatar
Ahhhh.... thanks so much for your help. I appreciate it. My little Christmas tree plug that was holding it somewhere broke off. Still a metal clip, but I think I found a place for it. I bet it got rattle loose during the lift install.
ge2 is offline
post #12 of 14 Old 02-18-2009, 08:25 PM
BiGEN
yup no problem... hope mine doesnt get popped off after my lift gets installed..
FOR SALE!
[/color]
BiGEN is offline
post #13 of 14 Old 02-18-2009, 11:46 PM
desertjk
The little plastic cap that you described on the end of the hose is the standard way that breather tubes are terminated. The hose pointed to in your picture is definitely the breather for the rear axle.
Another poster mentioned extending it. I would second this suggestion as you don't want it to go underwater - you're likely to suck water into the axle housing in that case.
I replaced mine with a longer rubber tube and brought it across to the passenger's side and routed it up into the area behind the tail light. I had to remove the tail light to get access but it made for a relatively clean setup and the breather now terminates at a much higher point than the stock setup.
I also relocated the front breather to terminate on the firewall right at the top. I'd like to relocate the breather for the transmission (auto) and T-case but I can't find the bugger.
2007 2 door Rubicon. 3.5" RE lift, 35" Goodyear MTRs, Procomp 8179 15x8 wheels, 4.88 Superior gears and alloy shafts. Shrockworks stubby front bumper, Rockhard rear bumper, JE Reel 1350 driveshafts, Warn Powerplant winch, CB, GPS.
desertjk is offline
post #14 of 14 Old 02-19-2009, 11:12 AM
4whelin
My bad I was thinking of the front axle
4whelin is offline
Breather hose needs a home! rockymou TJ Wrangler Technical Forum 5 01-07-2010 05:56 PM
ax-15 breather vent hose mod fish4life TJ Wrangler Technical Forum 4 06-10-2009 09:41 PM
AX-15 breather hose fish4life TJ Wrangler Technical Forum 4 06-08-2008 01:53 PM
breather hose xj 98/yj 94 YJ Wrangler Technical Forum 1 05-15-2007 05:23 PM
Diff breather hose spyder6 TJ Wrangler Technical Forum 6 12-10-2006 01:36 PM
