Loose driver's seat - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Loose driver's seat
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-22-2013, 10:55 PM   #1
rainmn
Loose driver's seat
My driver's seat makes a slight clunk when I hit a bump, go around a turn, etc. It's as if something is slightly loose, but I can't find it.
I can't make it happen by just shifting my weight around, yet it will do it every single time I back out of my garage. There's about a 2 inch lip I go down as I'm backing out, and I can feel the seat clunk every time.
It's not the bolts that hold the seat to the floor, nor is it the bolts holding the seat itself to the frame. I've checked them all at least 3 times, both in the Jeep, and when I had the seats out to install seat heaters. (And no, this didn't start after I installed the heaters)
I'm assuming that it's something in either the slider or height adjust mechanism, but I can't find it for the life of me.
Anyone else have this issue, and found a fix for it?
rainmn is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 11:06 PM   #2
JLC08JK
What was I thinking?
JLC08JK's Avatar
There is a common clunk that comes from the B pillar door latch. The easiest way to fix this is by putting a few wraps of electrical tape around the latch loop.
I would try this first as the simplest thing to check off the list as a possible cause.
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 11:11 PM   #3
Tanimal
My bump/clunk was my rear seat not latched and locked down properly and it was bouncing off the seat bracket every once in awhile ! Maybe that's it
[URL="http://www.jeepforum.com/forum/f96/tanimals-2008-2d-jk-build-thread-1397184/"][COLOR="Blue"][B]-=-CLICK HERE FOR MY JK BUILD THREAD-=-[/B][/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f11/tomimal-tanimals-1993-cherokee-country-build-thread-1440379/"][COLOR="GREEN"][B]-=-CLICK HERE FOR MY XJ BUILD THREAD-=-[/B][/COLOR][/URL]
[B][I]Learning as I go and it's worth every penny![/I][/B]
Tanimal is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 08:00 AM   #4
rainmn
Thanks for the suggestions, however I'm 100% positive this is the seat.
If it were just a noise, I'd have my doubts, but I can actually feel the seat moving slightly when it happens.
Also, I already fixed the B-pillar clunk with the tape several months ago.
Unread 04-23-2013, 11:51 AM   #5
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Possibly a broke support spring in the seat.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a hard knock...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 06:36 PM   #6
jbro27
I have the same thing going on with me seems like the hardest fix on my jeep. Haha
2 door 07 JK
35' Nitto Mud Grapplers
4" Rough Country Suspension Lift
jbro27 is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 06:47 PM   #7
1222
Make mine a Jeep!
1222's Avatar
Sounds like itís time to remove the seat so you can look in every nook and cranny.
1222 is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 07:26 PM   #8
rainmn
Been there, done that. I just installed heated seats a few months ago, so I had the seats out and apart - couldn't find anything at the time.
I searched on this, and found several threads where people were saying they had this issue, but no fixes.
Unread 04-24-2013, 03:23 AM   #9
1222
Make mine a Jeep!
1222's Avatar
Well damm that really sucks. Is there anyone you know that might let you exchange their seat temporarily into your Jeep to see if it is in fact the seat and not something else?
Unread 07-14-2015, 07:01 AM   #10
capio7
Hate to awaken this but I'm having the same issue in my 11 JK. Has anyone found the issue. Also, it seems that it takes a lot of force to lift mine to let someone in the back.
capio7 is offline   Reply With Quote Quick reply to this message
