Looking for HIGH Quality HID Headlights for JK - JeepForum.com
Closed Thread
post #1 of 95 Old 12-14-2010, 08:26 PM Thread Starter
kegreene
Any suggestions for HIGH Quality HID headlights for JK Wrangler? Looking for low and high beam HID. Thanks
kegreene is offline
post #2 of 95 Old 12-14-2010, 08:28 PM
theskier74
Jeep Wrangler HIDs Jeep Wrangler HID Kits Headlight Conversions Xenon Bulbs
not sure if this would work for a JK but this is pretty much one of the top HID companies.
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #3 of 95 Old 12-14-2010, 08:32 PM
muttytruckster
I thought the JK stock lighting wiring harness couldn't support the amp draw of these lights?
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
post #4 of 95 Old 12-14-2010, 08:35 PM
theskier74
im not a JK owner, so i wouldnt know. i just know that that site makes top quality HID lights. i know they do have conversion kits(75 DOLLARS) for high and another 75 for low, so idk if that changes the amp draw.
200k+
post #5 of 95 Old 12-14-2010, 08:49 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Would you replace the fog lights with matching color, 6-8K, or get the 3K or keep stock?
Mol is offline
post #6 of 95 Old 12-14-2010, 08:54 PM Thread Starter
kegreene
I have changed the driving lights to Hella units to work with stubby bumper. I would like all HID up front and need them all to match. Delta makes some nice looking units but I do not see headlights. Two tone front lights would look tacky so I am looking for a total package if possible or at least same temp range. Thanks for any help.
kegreene is offline
post #7 of 95 Old 12-14-2010, 08:57 PM
Mol
Mol's Avatar
Follow the link above that skier posted, select jeep wrangler, then select "buy now" This is where you choose your model year and kit - they have lows only (you lose hi's), or you can choose bi-xenon to keep low and hi, for $179.99, and for an additional $79.99 you can buy fogs that match
Mol is offline
post #8 of 95 Old 12-14-2010, 08:58 PM
Mol
Mol's Avatar
But I can't recommend or offer any review...sorry
Mol is offline
post #9 of 95 Old 12-14-2010, 09:18 PM
muttytruckster
Bueller......? Anyone? Anyone?
post #10 of 95 Old 12-15-2010, 08:47 AM
theskier74
i believe the Xenon lights are also the ones in my dad's BMW...if they are, they are amazing. No doubt in my mind these are the perfect lights. They literally turn night into day. If they fit in your JK, and you want top quality, these are the way to go. I would recommend the 6000K. That's what most people have.
200k+
post #11 of 95 Old 12-19-2012, 08:27 AM
4x4Reaper
2011 JK Wrangler
I have a JK with HID headlights and LED fog lights. I love it, there is no comparison between the halogin bulb and the HID.
Last edited by 4x4Reaper; 12-19-2012 at 09:10 AM. Reason: adding picture of HID and LED
4x4Reaper is offline
post #12 of 95 Old 12-19-2012, 10:35 AM
deltabravo
Also consider the Truck Lite LED headlights, which are DOT / FMVSS108 approved.
Any HID headlight installed in a typical housing will likely void the DOT approval, which isn't a show stopper, BUT, in many cases they become very hard to adjust so as to not blind other drivers.... this is because a typical factory or aftermarket housing was not designed for the amount of light put out by an HID, only the replacement style bulb is was intended for.
I had HIDs and IPF housings in my TJ. They were very difficult to get adjusted, there was so much light, it scattered everywhere.
Truck Lite LEDs:
http://www.northridge4x4.com/shop/tr...cs-design-each
I went with Truck Lite LEDs on my JK - they were plug and play and didn't require a bunch of extra underhood doo-dads like balasts, extra wire bundles, etc. (which seem to be hard to find room for in JKs)
Just mentioning this as another option to consider.
deltabravo is offline
post #13 of 95 Old 12-19-2012, 11:31 AM
2006_Sport
Projector retrofit. /thread.
retrofitsource.com
2006_Sport is offline
post #14 of 95 Old 12-19-2012, 12:56 PM
Shabbernigdo
HID's draw less power then standard halogens.
Shabbernigdo is offline
post #15 of 95 Old 12-19-2012, 01:41 PM
BigMikeOfTO
2011 JK Wrangler
My buddy installed the xenon 8700's on his '12 am has nothing but problems. I wanted to get them last year when I got my JK, an went to a couple local performance shops and both told me not to bother. The only ones that are half decent are the same ones that go on BMWs, which about 800. Almost went with truck lite's LED but instead I'm saving up for the JW Speaker. Just my opinion tho
Sent from my iPhone using my thumbs
BigMikeOfTO is offline
Closed Thread
headlights , hid , lighting
My 2011 JK (New High Quality pics added) Sooner11JK JK Wrangler Technical Forum 31 11-22-2010 03:49 PM
2004 TJ Dana 44 Differential Total rebuild - high quality parts advice needed Difflok TJ Wrangler Technical Forum 4 11-16-2009 08:57 PM
High Quality Die Grinder ScotZ YJ Wrangler Technical Forum 2 07-11-2007 07:46 PM
Auto transmission oil change - high quality ATF? zband TJ Wrangler Technical Forum 4 05-19-2007 05:49 PM
