Looking for advice modifications, Our first jeep! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Looking for advice modifications, Our first jeep!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 02-17-2009, 11:08 AM   #1
g025256
I just purchased a wrangler unlimited, first one for me. I want a 4'' lift with 33'', but would prefer 35'' with 17''? rims want to go black rims and armor. Dana 35 on rear....do i need to change it out to dana 44 and at what what size tire would the 35 handle......suspension lifts? Just getting started.. any advice would be helpful.... will do very little off roading...wife will drive as second ride for fun a few days a week and in the summer
g025256 is offline   Reply With Quote
Unread 02-17-2009, 11:21 AM   #2
wrestlerobx
with a 4 " lift you will need to replace the drive shaft. if you only want 33" you could do a 2 or 2.5" BB or BL and keep stock handling and fit 33" just fine i would suggest this route if you do not offraod much and just want a mean jeep its generally cheap and works well as a DD
a 3" lift will give you plenty for 35" as long as you have the correct backspacing
a 4" lift will take a lot more money to get everything needed to change other components so unless money is no issue i would suggest one of the other options. also maybe do a search on lifts in general on this forum and do a lot of research and searching it will help and there is a lot of useful information on here
wrestlerobx is offline   Reply With Quote
Unread 02-17-2009, 01:03 PM   #3
N2rock
N2rock's Avatar
you have a Dana 35 rear? Not many of those around considering they only did that for 1/2 of the first year of 2007.
If you wheel it, you're going to want a D44 back there. Definitely don't want to push your luck with a D35, 35" tires, and wheeling. I've see the result of that, and it ain't pretty.
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Unread 02-17-2009, 03:05 PM   #4
tricked919
..and you don't need anywhere close to a 4" lift to run 33's OR 35's. You have lots of options under 3" that will work with 35's and yield far less risk and involvement. If you're wheeling is going to be moderate, go with a 2.5" BB.
Why 35's on 17's? Nothing wrong with that, but you have FAR more (and cheaper) options for any size tire on a 16" rim - even 18's, but 35's for 18's ain't cheap.
If your JK really does have a D35 in the back, then chances are you might have the 3.21 gears - if you're lucky, you might have 3.73s. The latter might be OK, but anything taller than a 3.73 is NOT good for either 33's or 35's. You'll want to kill yourself.
tricked919 is offline   Reply With Quote
Unread 02-17-2009, 03:50 PM   #5
wrestlerobx
he does have more options but he already is running 17 stock rims so if he wants to keep those i think that is what he is talking about
