Long crank time - JeepForum.com
post #1 of 10 Old 04-09-2008, 10:57 AM Thread Starter
sprtplt
Long crank time
2007, new, has the "long time to start" problem. You turn the key to start and it just keeps cranking. does this only occasionally. I believe there is a TSB on this "08-023-07 OCT 07 Engine Controls - Long Crank Time to Start" from Alldata. But Alldata doesn't sell the complete text for the 2007 Jeep yet so you can only see the title. Idiot dealer, of course, said unable to duplicate. told him about the TSB and he just kept saying the same thing. Someone on here had this and had some sensor (crank position maybe?) replaced. Does anyone have the specific info on this? thanks
sprtplt is offline
post #2 of 10 Old 04-09-2008, 12:02 PM
TampaJK2008
Yes, this was me. Same thing happened to my 08 from the day I got it. I mentioned it to the dealer, they said they could not replicate. After some time of searching I found the TSB for the 07 model. I printed the TSB, walked into my dealer and said fix it please. The dealer then went online, and found the TSB for the 08 as well. BE AWARE the first thing they will try to do is a "computer chip update" that they will tell you "should fix the problem"...WRONG! The cam- shaft sensor has to be replaced. I had this done about a month ago, and it has not happened since.
Hope I was able to help.
2008 Jeep Wrangler X Unlimited
Stone White
6 Speed Manual
TampaJK2008 is offline
post #3 of 10 Old 04-09-2008, 12:17 PM
N2rock
N2rock's Avatar
here's the full tsb: http://project-jk.com/images/tsb/TSB_08-023-07.pdf
When I took mine in, I printed that out and took it with me because I knew I would get the "unable to replicate" response- of course you can't replicate it, it does it at random! The dealer I took it to did the TSB and I have not had a problem since (that was back in December)
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 10 Old 04-09-2008, 12:50 PM
V-Powered
2015 JK Wrangler
N2Rock...thanks for the excellent link.
'15 Sunset O HardRock Unlimited 6-speed. There is no such thing as overKILL.
V-Powered is offline
post #5 of 10 Old 04-09-2008, 12:58 PM
rirrgang
Mine does this about 1 in 20 starts. Thanks for the TSB.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #6 of 10 Old 04-09-2008, 02:06 PM Thread Starter
sprtplt
yes!
many thanks!
sprtplt is offline
post #7 of 10 Old 04-08-2014, 02:49 PM
goochieman83
2014 JK Wrangler
I know it's been a while since this thread has been visited but I just bought a 2014 Wrangler and it does the exact same thing. It has 700 miles on it and has done it about 5-6 times. Go to start and sometimes it takes twice as long to crank. Any ideas or anybody else with newer jeeps with this issue?
goochieman83 is offline
post #8 of 10 Old 04-08-2014, 03:36 PM
gjeffers72
I have a 2007 and its been doing it from beginning. I have 110000 on it and its just fine, just a glitch.
gjeffers72 is offline
post #9 of 10 Old 04-08-2014, 06:39 PM
Utah_Jay
Wow old thread but glad I saw it. Mine does this on occasion. Now I know why!
2007 JKU Sport
Utah_Jay is offline
post #10 of 10 Old 04-09-2014, 10:10 AM
goochieman83
2014 JK Wrangler
That's crazy. Well glad to know how to fix it. It hardly ever does it but it freaked me out the first time, especially since this is the first new vehicle I've ever owned. What's bad is my CJ starts better than that, thanks "Team-Rush".
Takes a long time to crank cntryboy97 TJ Wrangler Technical Forum 9 09-13-2009 10:00 PM
4.0 long crank to start ryan6942 TJ Wrangler Technical Forum 9 02-28-2009 09:50 AM
long crank time FIXED nasty habit TJ Wrangler Technical Forum 5 11-10-2008 08:54 PM
Long time lover first time owner 98 Sahara omarkhan860 TJ Wrangler Technical Forum 16 04-04-2008 07:46 AM
Long crank time? dth JK Wrangler Technical Forum 13 08-19-2007 08:25 PM
