Locker Question... - JeepForum.com
post #1 of 36 Old 03-31-2014, 08:33 PM Thread Starter
Will09JK
Locker Question...
So as I'm a noob at this and not all that smart here's my question... I have an '09 JKU with a dana 30 up front and dana 44 in the rear and I'm looking to install an aussie locker but I was told by a friend that if I wasn't ordering both lockers at the same time that I was going to have to get the rear one first?...
Will09JK is offline
post #2 of 36 Old 04-01-2014, 07:57 AM
duneslider
You can put an Aussie in the front and not have one in the back. If I had to choose I personally would want a back locker before a front though.
07 JKU Wrangler
10 XK Commander Limited
duneslider is offline
post #3 of 36 Old 04-01-2014, 10:30 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
^^^^^^ This!
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #4 of 36 Old 04-01-2014, 10:35 AM
SubAtomicGenius
2011 JK Wrangler
I'd lock the rear first if you are only doing one at a time.
Special consideration for the Aussie - which I use on the front - you have to ensure that your tire pressures are the SAME and the tires on the same axle assembly are within 3/8" diameter or you'll activate the locker while you are DD. The front tracks a bit offroad, which is manageable - but you can't switch it off like a selectable. Other than that, it is a great locker option in my experience, especially for the price. You're essentially only buying the center section and replacing the spider gears of your open diff carrier.
SubAtomicGenius is offline
post #5 of 36 Old 04-01-2014, 04:23 PM Thread Starter
Will09JK
Thanks for all the info, I contacted Aussie also said they would have the Locker ready for the JK D44 ready soon.
Will09JK is offline
post #6 of 36 Old 04-01-2014, 07:24 PM
WAC_Jeeper
WAC_Jeeper's Avatar
I'll go against the grain here and say I'd prefer a locked front, if only one locker. I've ran both setups before. With an aussie in front, your Jeep will drive like it is 100% stock on-road, while in 2wd. When in 4WD, the front will climb up over obstacles with greater ease, as a rear-only locked vehicle will want to "push" the front tires into an obstacle, as opposed to the front tires climbing. If mud, sand or snow is your thing, being able to saw the steering wheel and have both steering tires spinning and grabbing really helps.
But locking just the rear is still a vast improvement over stock.
12 JKR 2 door, MCE Gen III Flares, Teraflex 1.5" Perfomance Leveling kit, 35" MTRs, ARB bars front/rear, ARB diff covers, ARB Dual Compressor, AEV DOT-compliant beadlocks, Warn Zeon 8
97 TJ, MCE fenders and flares, heavily used and reliable on 35's.
WAC_Jeeper is offline
post #7 of 36 Old 04-01-2014, 07:54 PM
chris79
JK Wrangler
Just remember with an Aussie, your fully locked at all times, it can get very tricky to drive on pavement....especially if it's in the front. If you not going to do a selectable locker look into a Detroit Truetrac, not a true locker but the reviews are awesome.
chris79 is offline
post #8 of 36 Old 04-01-2014, 07:59 PM
Jeffro06
Jeffro06's Avatar
You don't need 4wd on dry pavement, and shouldn't use it on dry pavement....much less a locker.
Jeffro06 is offline
post #9 of 36 Old 04-01-2014, 08:12 PM
chris79
JK Wrangler
Wow, thanks for clarifying. To be perfectly clear for those who may be a little slow, IF you live somewhere that it snows I'd assume you'd be using your 4wd on the road, and in that case an Aussie would be tough to drive with.
chris79 is offline
post #10 of 36 Old 04-01-2014, 08:28 PM
Neo1130
2015 JK Wrangler
I didn't think you wanted to use lockers in the snow either... On road snow I know from experience, is dangerous to drive on locked... Now pulling in the snow with lockers is one thing... But driving locked, things get pretty exciting...
Neo1130 is offline
post #11 of 36 Old 04-01-2014, 08:34 PM
Jeffro06
Jeffro06's Avatar
I drove my YJ with an Aussie up front, on snow covered roads, it's a bit different than standard 4wd for sure. The locker wants to go straight, so turns/curves were interesting. I tended to lift off the gas when turning and things were pretty good. I much prefer the selectable locker I have in my TJ, but the Aussie was awesome off road in the YJ, huge improvement.
Jeffro06 is offline
post #12 of 36 Old 04-01-2014, 08:40 PM
WAC_Jeeper
WAC_Jeeper's Avatar
That is actually not true. The auto lockers, such as the Aussie, Lock-Right, Grizzly, and Detroit are only "locked" when receiving power from the engine. In a front application, during 2WD operation, the front axle is just freewheeling, so the locker will not engage. Some light ratcheting noises can be heard around slow, sharp turns in parking lots, etc., but that is the only way you can tell there is a locker in there. Once in 4wd, the locker will be alive.
post #13 of 36 Old 04-02-2014, 03:26 AM
Yendor
Will, I'm in the learning stage of all this, also. However, when I ordered my Jeep I ordered the factory rear "posi-Trac". ( what ever Jeep is calling it now) The posi- Trac, 3.73s, and 285/70/17 Duratracs were unstoppable this winter.
I don't know anything, but if I were to choose a locker for the front today, I'd do an Eaton Performance ELocker. I want to know exactly when the front is locked.
Question: if you had a Detroit Truetrac and had one wheel off the ground, would the "Brake Lock" on the newer Jeeps kick in and help to get the grounded tire some power?
Is a True Trac difficult to install? I went to a local transmission shop to ask about having it installed in my 11 ram 4X4, and he was clueless. My dealership is really good. Do you think they'd do a good job? My Jeep has me spoiled. I'll never have an open rear again.
How reliable and trouble free are the ELocker? I have trust issues with anything electric.
Yendor is offline
post #14 of 36 Old 04-02-2014, 04:18 AM
SubAtomicGenius
2011 JK Wrangler
Correct, when the differential receives input from the driveshaft (ie. in 4wd on the front axle), the locker will mechanically "detect" slippage from one axle shaft and mesh the locker teeth/halves together. Instant lockup without any input. In 2wd, you hear a clicking when you turn the wheel as the locker springs let the Aussie teeth ratchet past each other. I used my Aussie in heavy snow on the road yesterday, and I'll be using her again today! I've pretty-much got the wife convinced to get rid of the car and buy another Wrangler for times like this!
If one tire was off the ground, the brakes would have to overcome both tires from spinning if they were getting power. This is also why auto-lockers are dangerous to work on if one tire is left on the ground in the shop - they can inadvertently hop off of jack-stands.
I wouldn't say the Truetrac is difficult to install - much as any locker. Oh, and in my mind Eaton has historically had a bad reputation with their ELocker... whether that is fixed now I don't know.
post #15 of 36 Old 04-02-2014, 06:58 AM Thread Starter
Will09JK
The Jeep community is far smarter than I. Where the hell do yous guys learn all this. LMAO...FYI I'm driving an '09 JKU on 315/70/17r and 3.5" rough country lift, don't hate me I know rough country is the devil on here but I'm married and live in brooklyn NY and it was all I afford after rent LOL so... The front locker is okay to install alone then as long as I don't drive locked on pavement and turn at all? Lol
Will09JK is offline
