Limited Slip - Necessary? - JeepForum.com
post #1 of 14 Old 10-22-2006, 08:52 AM Thread Starter
solbergg
I'm trying to spec out an X, and I'm not car savvy enough to know what a limited slip differential is for. Some people have told me that it makes only the wheel that has traction spin, which is good when you're stuck. If this is true, then is it really necessary when you have 4 wheel drive?
solbergg is offline
post #2 of 14 Old 10-22-2006, 09:00 AM
simadownow6988
since you are in Florida, it wont make much since unless you do alot of driving in mud. Limited slip especially comes in great during winter weather like snow and icy roads. even in 4wd, it helps in those conditions. if you are just going to road ride your JK with a little off- pavement use, you will be fine without the LS.
simadownow6988 is offline
post #3 of 14 Old 10-22-2006, 10:25 AM Thread Starter
solbergg
Ok, that's good to know. One other question - on the Jeep.com site, if you click on the information for the limited slip, it lists the Dana 44 rear axle. Does this mean you get the D44 if you order the limited slip, or is this a misprint on the page?
solbergg is offline
post #4 of 14 Old 10-22-2006, 10:29 AM
EagerJeeper
It's a very inexpensive upgrade. You'll wish you had it the day you discover you actually own a 2 wheel drive - One in the front and one in the rear.
My last 4x4 was a Toyota Truck with open differentials. I was amazed at how you could get stuck crossing very small obstacles on a diagonal line - on level ground! Get the limited slip!
EagerJeeper is offline
post #5 of 14 Old 10-22-2006, 12:16 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
It is worth it if you don't plan massive drivetrain upgrades.
2013 FR-S
BlaineWasHere is offline
post #6 of 14 Old 10-22-2006, 12:27 PM
Karamba
You already will have an electronic limited slip - that is actually quite effective. If I were to upgrade from that - a selectable locker in the rear is probably a better option as far as offroad performance and handling goes.
Karamba is offline
post #7 of 14 Old 10-22-2006, 12:29 PM
Karamba
In an FJ - this ATRAC electronic limited slip does work quite well just for that case. New Wrangler has a similar system.
Karamba is offline
post #8 of 14 Old 10-22-2006, 12:38 PM Thread Starter
solbergg
Ok, with the electronic slip, it sounds like I will be alright without the mechanical. The only reason I would order it at this point is if you get a Dana 44 rear axle by ordering it. But, I'm not sure if that's just a misprint or what.
solbergg is offline
post #9 of 14 Old 10-22-2006, 12:57 PM
ghostship
1978 CJ7
I don't see that. When you order the Tow Group, that includes the rear Dana 44 and 4.10 gearing. But the Limited Slip option is all by itself.
ghostship is offline
post #10 of 14 Old 10-22-2006, 03:54 PM Thread Starter
solbergg
It's when you're going through the configurator. On the options tab, you can actually click on each option to get a little more info. The limited slip detail mentions the dana 44. BUT, in my case this is all irrelevant if the dana 44 comes with the tow package, as I will be getting that for sure.
solbergg is offline
post #11 of 14 Old 10-22-2006, 04:49 PM
SecondTJ
SecondTJ's Avatar
get the limited slip. my old durango had an open diff, and now ive got a limited slip with the jeep and its night and day difference. i can go someplaces in 2wd that id get stuck in 4wd with the durango. its well worth it
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #12 of 14 Old 10-22-2006, 05:24 PM
03jeeper78
03jeeper78's Avatar
But your old durango didn't have brake assisted traction control like the JK does.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #13 of 14 Old 10-23-2006, 04:18 AM
infosponge
infosponge's Avatar
For $260 it seemed like a no-brainer option for me.
infosponge is offline
post #14 of 14 Old 10-29-2006, 11:40 AM
shredX
I believe the e-LSD just applies the brake to slow the spinning wheel.
The mech LSD actually transfers power. As previously stated, a 2WD w/ LSD can often out perform a 4X4 without.
07 JK Unlimited X ~ Stone White & grey int ~ 4X4 ~ Trac-loc LSD ~ Tow w/ 4.10 ~ Power package ~ S package ~ Freedom Top ~ 16x7 w/ BFG AT 265/75/R16 ~ base radio w/ Sirius Sportster ~ Thule rack
shredX is offline
Limited slip... more like limited thinking 1dirtywhyjay YJ Wrangler Technical Forum 12 04-17-2009 07:08 AM
Anti-Slip / Limited Slip HELP!!! mtb1981 JK Wrangler Technical Forum 3 05-18-2007 07:06 AM
limited slip ddmech YJ Wrangler Technical Forum 2 12-28-2006 12:10 PM
Limited Slip Flatsix TJ Wrangler Technical Forum 11 03-28-2006 09:12 AM
? about limited slip in D35 cspoffroad TJ Wrangler Technical Forum 11 04-27-2005 05:57 PM
