lights wont come on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > lights wont come on
Labor day sale @ rockridge 4wd! 8/29-9/1 site wide..promo Rough Country Deals at JeepHut.comShocktober is here! Get new shocks for your Jeep!!!!
Unread 08-21-2014, 07:52 AM   #1
jenniferjeep
2010 JK Wrangler
lights wont come on
Went to drive to work this Am and my headlights wont come on. The running lights and tail lights come on but no headlights. Has any one else had this issue?
jenniferjeep is offline   Reply With Quote
Unread 08-22-2014, 08:17 AM   #2
jenniferjeep
2010 JK Wrangler
So no one out there has had any issues like this?
Unread 08-22-2014, 09:10 AM   #3
XTRyan
ExtremeTerrain.com
XTRyan's Avatar
Have you checked all the related fuses? Do you have power at the bulb sockets? Is there a relay in that circuit? (I assume so but I'm not as familiar with the JK wiring).
Start with the fuses and a test light/multi-meter to see where you do and don't have power. Good Luck!
-Ryan
Ryan H. | ExtremeTerrain.com Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
EARN UP TO $200 TOWARD YOUR NEXT PURCHASE!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
GET YOUR FREE JEEP PARTS CATALOG!
XTRyan is offline   Reply With Quote
Unread 08-22-2014, 10:34 AM   #4
jenniferjeep
2010 JK Wrangler
Batterie voltage is 12.46 with out the engine running 14.8 with engine running. This tells me the batterie and alternator are good. The fuse is good as the lights will blink. In my experiance once a fuse go on and off. The relay is a possibility. I was wondering if this is one of the funky electrical issues that are common among Jeeps.
Unread 08-22-2014, 10:50 AM   #5
TexanTJ
2014 JK Wrangler
There are no fuses for our lights, they are controlled by a highside driver from the TIPM.
Get a test light & flip the TIPM over & check the C3 connector ( it's green ) & check pin 3 ( white wire/ dark blue tracer ) for power. Thats your left low beam. If theres no power when turned on, more then likely the TIPM has an issue or the multifunction switch.
Does your high beam indicator come on in the cluster? If it does, that usually means the switch is working right.
2014 JKU Sport
1999 F250 7.3
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline   Reply With Quote
Unread 08-22-2014, 01:50 PM   #6
jenniferjeep
2010 JK Wrangler
What is the TIPM? Is that the relay module? I have the high beam indictator ligh on the dash. So that means the TIPM is working correctly?
Thanks
