Lifting the JK - JeepForum.com
post #1 of 10 Old 10-03-2006, 09:50 PM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
Lifting the JK
Well it's been a whole 3 days and the dealership called telling me about a new 3" lift for my Rubicon... It's $1800 installed and man it sounds cool. 35" tires would look very sweet under this thing.
My concern is; Would a lift change the road manners drastically? I'm really happy with how my Jeep drives on the road, but I really like the bigger tires and visually the Rubicon looks low to me. Unfortunately I doubt anyone has lifted one of these, so input is probably bleak.
Also, I really want to put a plow on before winter (the main excuse I used for buying it) but in my infinite wisdom, it never occurred to me that it is a brand new model design and no one has a plow for it yet... Crap!!!
So, even if I got a 3" lift and a plow was available. Would it be difficult to put a plow on a lifted Jeep?
Roadtrip is offline
post #2 of 10 Old 10-03-2006, 09:54 PM
momomike3
It shouldnt be a DRASTIC change. However, it does change. Mainly, you have to just slow down a little bit, and as long as you pick good shocks, it should be good.
BTW, DO IT. I havent seen a lifted JK on the road yet.
momomike3 is offline
post #3 of 10 Old 10-03-2006, 10:49 PM
ToolFan
you should try and do the pift yourself. I am sure there are plenty of people willing to help, then it would be like getting free tires!
ToolFan is offline
post #4 of 10 Old 10-04-2006, 11:05 AM
Stevebo
Ive seen 3" lifts for under $500 without install, Im sure you can get it way cheaper than that.
Stevebo is offline
post #5 of 10 Old 10-04-2006, 11:35 AM
Lud04X
Better yet take that 1800 and get some people to help install this....
http://www.northridge4x4.com/proddet...?prod=FTS-7133
Go to northridge4x4.com, there's the cheaper 500 dollar version of the lift as well.
I'm sure people would be willing to help and some people might want to see what would be encountered in lifting one as they're a new design especially if they're thinking about buying one. Post pics when its lifted.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #6 of 10 Old 10-04-2006, 12:01 PM
Karamba
Be sure you know what brand of a lift you are getting, and ask folks around here for advise.
There is a plenty of "show-off special" lifts out there... Not that many of trail worthy ones..
Karamba is offline
post #7 of 10 Old 10-04-2006, 12:21 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
The SnowBear snow plow is a system that custom-mounts the plow to the front of your vehicle. They make the basic plow compatable with every model of vehicle, then the mounting is specific to your vehicle.
If they don't have something for the JK already, I imagine you could use the TJ-style brackets, modify a bit and mount fairly easily.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #8 of 10 Old 10-04-2006, 01:16 PM
Dukes69
Dukes69's Avatar
or contact a local plow mfg. and see if they want to prototype a plow/mounting system using your Jeep. Most of the time that means a free product.
AIM: Dukes69
Ya Savvy?
Dukes69 is offline
post #9 of 10 Old 10-04-2006, 03:35 PM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
Yeah,
I have a call into SnowWay in Milwaukee hoping they can use my truck. Not sure if I'll hear back from them... I hope so, because so far it's my favorite plow. It only weighs 275lbs and the hydrolics detach with the plow itself. leaving a small bracket/rack attached to the truck.
Otherwise I might be bumming this season...
Roadtrip is offline
post #10 of 10 Old 10-04-2006, 03:40 PM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
I'll probably hold off on the lift until a few other guys try it first. I really want the plow more than anything this year.
Sounds like If I supply the brew, I could get a few hands putting on the lift when I decide to do it. I guess, we could get alot of beer and pizza for the $1300 I'd save.
Roadtrip is offline
lifting my 88 88wrangleryj YJ Wrangler Technical Forum 5 03-19-2007 09:38 PM
lifting a TJ Bobz007 TJ Wrangler Technical Forum 7 12-27-2006 08:23 AM
new to lifting cotoole TJ Wrangler Technical Forum 10 10-10-2006 01:39 PM
lifting? StuckInMud94 TJ Wrangler Technical Forum 1 05-29-2006 10:51 PM
Lifting? jmhat98 YJ Wrangler Technical Forum 1 04-11-2006 06:18 PM
