Lifted 4 door JK's Only! - Page 57 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Lifted 4 door JK's Only!
Swag Off Road BIG-HIT TJ-YJ Rear BumperAll Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!
Unread 07-02-2010, 11:49 AM   #841
JLC08JK
What was I thinking?
JLC08JK's Avatar
The difference between 33" and 35" is 2"
The difference between 35" and 37" is 2"
The amount of regret if you get 35's instead of 37's =
The amount of regret if you get 33's instead of 35's =
You get the picture!
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 03:49 PM   #842
MilitaryJK4455
2010 JK Wrangler
Actually, my 35's only measure out to 34"... I wonder how much smaller true 33's would look on my rig sometimes.
MilitaryJK4455 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 05:25 PM   #843
rballman
I regret my 35s. Next will be 38s one day.
2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s
Colorado Jeep Club member #2007
My JK Build Thread
rballman is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 09:24 PM   #844
Grizzly1
2010 JK Wrangler
I like my 35's just fine. If I get a hemi....then maybe 37's!
Semper Fi
Grizzly
Grizzly1 is offline   Reply With Quote Quick reply to this message
Unread 07-03-2010, 04:58 PM   #845
MilitaryJK4455
2010 JK Wrangler
Yeah, I would love some of them! But I would feel comfy runnin 38's on a 30
Unread 07-06-2010, 11:16 AM   #846
JLC08JK
JLC08JK's Avatar
So I pulled out the RC BB and added the OME 618 rear and 619 front springs.
I can't call them 2" lift coils! They gave me over 2" more than the RC 2" BB
Unread 07-06-2010, 09:59 PM   #847
Mudhound0530
1988 MJ Comanche
So this is the Lifted 4 door page......any of you guys that have had to remove the TRANNY SKID ever tried to notch it out so that it will fit back on???????
I really want to do this but if anyone has done it... ill take your advice.
88 MJ 94 XJ
09 JKRU SOLD
14 Chevy Silverado Quad Cab 4x4
Mudhound0530 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 10:55 PM   #848
JLC08JK
JLC08JK's Avatar
I think that some guys have just shimmed it down with some washers.
Notching is another option if shims won't work.
Unread 07-07-2010, 05:18 AM   #849
Neoxxis
Meaning you removed it?
Why?
07 Unlimited Rubi Rescue Green/Auto/pwr
Neoxxis is offline   Reply With Quote Quick reply to this message
Unread 07-07-2010, 09:34 AM   #850
nwbronco
2014 JK Wrangler
Sweet!. As a rule, all the spring lifts net more than advertised. While the BB's are a hard puck, so they are pretty much defined. I went with the RE 3.5, and I know I netted close to 4.5
It has settled though as the Jeep just keeps getting fatter...
nwbronco is offline   Reply With Quote Quick reply to this message
Unread 07-07-2010, 09:36 AM   #851
cadeddie
I myself could not decide between 33" or 35" but after much research I realize that if I go with 33" I will regret it...plus I found a local 4x4 shop that will regear for $1,000....but for now I just plan to run a flashpaq
as some guy said " 33's are for guys that don't have the balls to go with 35's "
oh yeah I plan to run 35" nitto trail graps....
cadeddie is offline   Reply With Quote Quick reply to this message
Unread 07-07-2010, 07:17 PM   #852
Mudhound0530
1988 MJ Comanche
Why?
So I dont eff up my drive shaft........duh?
88 MJ 94 XJ
09 JKRU SOLD
Unread 07-08-2010, 05:00 AM   #853
Neoxxis
You removed the tranny skid plate to not F-up your drive shaft?
What lift do you have?
I have 3" and the drive shaft is not even near the skid plate...
duh.
Unread 07-08-2010, 05:27 PM   #854
Mudhound0530
1988 MJ Comanche
duh.
I thought you're drop down box said 5" of lift. My bad. Anything over 3 inched they recomend removing it so that at full flex the drive shaft doesn't get tore up.
88 MJ 94 XJ
09 JKRU SOLD
Unread 07-09-2010, 07:27 AM   #855
Neoxxis
Ah ok we're on the same page then.
Yes, 5" including 2" body lift.
And yes, past 3" suspension lift you need to take care of the skid plates and drive shaft angle...
10-4.
4 door , image , JK Wrangler , lifted , photos , pictures , unlimited , wrangler
