Lifted 4 door JK's Only! - Page 220 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Lifted 4 door JK's Only!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-06-2013, 05:58 PM   #3286
04WJfreedom
Originally Posted by Mol
Maybe you have reverse mount wheels, and hammer ons won't work? I used stick ons for this reason
I just went out and checked and there is stick on weights on one of my wheels I never noticed them before? That's weird after they told me they couldn't use them? I don't know but I'm going to go have them rebalanced some where else soon.
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 06:20 PM   #3287
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Originally Posted by 04WJfreedom View Post
...I'm going to go have them rebalanced some where else soon.
If it hasn't been mentioned already, try to find a shop that uses Hunter Road Force balancing equipment and if possible a technician with experience balancing big *** "knobby" tires.
Edit: Also a good technician will stop, spin the tire on the rim and re-balance until the sweet spot is found that requires the least amount of weight. Takes longer, but worth it IMO.
PhatBasturd is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 06:44 PM   #3288
SubAtomicGenius
2011 JK Wrangler
Originally Posted by Mol View Post
Beads/sand are retarded...
I balanced a set of thoroughly used, and DIY grooved/siped comp compound tires on bead locks with sticky weights. Have never rebalanced them and I wheel my rig a lot harder than the average Joe. Reinflate to 30lbs and I'm comfortable up to 90mph.
Nothing fancy...I just use what has always worked. This whole bead craze is ridiculous, it doesn't even make sense. Can't even begin to tell you how many people have come in with wobble, shiy problems that we fixed by emtyping the tires and balancing with weights.
X2 Beads are retarded. Just balance the ****ing tire already.
SubAtomicGenius is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 06:53 PM   #3289
04WJfreedom
Yeah I have a few places near me with with a hunter road force balancing machine. I'm going to have to try that out. Thanks
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
Unread 09-06-2013, 09:28 PM   #3290
Mol
Disclaimer: I'm Polish
Mol's Avatar
Fwiw, the tires I mentioned above:
Are a lot "nobbier" than the average nitto, bfg, Goodyear discussed here. I balanced them myself, on a regular old wore out balancing machine, with about four other sets of tires under my belt (my own tires). No problems since day one. Worst tire had 10.5 oz, best had 8.5 I think. Keep in mind these are bias ply competition compound rubber that have all been cut by hand (far from symmetrical).
The trick is to find someone that's not and idiot, I guess balancing a tire is not a tough feat.
Mol is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 11:41 PM   #3291
DangFoo
Wow, those are nasty (in a good way)!
DangFoo is offline   Reply With Quote Quick reply to this message
Unread 09-07-2013, 02:34 PM   #3292
1222
Make mine a Jeep!
1222's Avatar
The post from Erbo1Kanerbo and all subsequent posts related to it have been moved to the Wrangler General Discussion forum with the title “Check it out!
1222 is offline   Reply With Quote Quick reply to this message
Unread 09-08-2013, 01:29 AM   #3293
TRAUMAhead
2010 JK Wrangler
Leveling kit and 35s.
TRAUMAhead is offline   Reply With Quote Quick reply to this message
Unread 09-08-2013, 08:45 AM   #3294
Mol
Mol's Avatar
Looks GREAT trauma...understated and beefy
Unread 09-08-2013, 09:26 AM   #3295
04WJfreedom
Agreed! looks good with the flat fenders too!
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
Unread 09-08-2013, 11:48 AM   #3296
bluerockymtn
Great backdrop as well
bluerockymtn is offline   Reply With Quote Quick reply to this message
Unread 09-09-2013, 12:09 AM   #3297
TRAUMAhead
2010 JK Wrangler
Thanks. Would've had it lifted over the summer, but I got was getting tired of the 3.8L, 4:10s, automatic, 35s combo so I opted to get it regeared. Disappointed with 5.38s and would rather have the lift right now. :
Unread 09-09-2013, 09:36 AM   #3298
rock-rocker
Trauma,
Why are you disappointed with the 5:38's? I have a 3.6 with the Auto and 4:10's and after I install 35's I'm planning on regearing to 5:13's. Please let me know cause you have my curiosity about whether I should go 5:38's instead. I will be taking mine on the Rubicon often so I have to take that into serious consideration. Thanks
BTCS, USN, Retired
2013 Jeep JKU Rubicon 10th Year Anniversary.
rock-rocker is offline   Reply With Quote Quick reply to this message
Unread 09-09-2013, 11:20 AM   #3299
RogueStatus
Originally Posted by rock-rocker View Post
Trauma,
with 35s and the 3.6 auto i would either do a 4:56 or 4:88 gear set... you dont need anything that low (or high? i always get confused haha) on the 3.6 unless you have larger tires.
my buddy with the 3.6 and an auto runs the 5:38 gears with his 42" tires for example.
Jeep-less again
RogueStatus is offline   Reply With Quote Quick reply to this message
Unread 09-09-2013, 11:33 AM   #3300
rock-rocker
I was considering 4:88's in the very beginning but I was erroring to the good because I wanted a good crawl ratio for a little solid rock climbing. That's why I was so surprised over the mentioning of disappointment of the 5:13's. I know I'll lose mpg with the 5:13's (along with some wear and tear) but the good thing is my wife currently uses it as a DD and her commute is only 15 miles one way. Also I'll eventually get her the vehicle she wants and the Jeep will be all mine. I haven't thrown 4:88's out the window yet...that's why I love these forum's because it constantly keeps me on my toes thinking all the time. Just when I thought I knew what I wanted and where I'm going there a detour...arrrrrgggggggg.........(put thinking cap back on and wallet back in pocket)
BTCS, USN, Retired
4 door , image , JK Wrangler , lifted , photos , pictures , unlimited , wrangler
