Lifted 4 door JK's Only! - Page 220 - JeepForum.com
 11Likes
post #3286 of 4008 Old 09-06-2013, 04:58 PM
04WJfreedom
04WJfreedom's Avatar
Originally Posted by Mol
Maybe you have reverse mount wheels, and hammer ons won't work? I used stick ons for this reason
I just went out and checked and there is stick on weights on one of my wheels I never noticed them before? That's weird after they told me they couldn't use them? I don't know but I'm going to go have them rebalanced some where else soon.
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #3287 of 4008 Old 09-06-2013, 05:20 PM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Originally Posted by 04WJfreedom View Post
...I'm going to go have them rebalanced some where else soon.
If it hasn't been mentioned already, try to find a shop that uses Hunter Road Force balancing equipment and if possible a technician with experience balancing big *** "knobby" tires.
Edit: Also a good technician will stop, spin the tire on the rim and re-balance until the sweet spot is found that requires the least amount of weight. Takes longer, but worth it IMO.
PhatBasturd is offline
post #3288 of 4008 Old 09-06-2013, 05:44 PM
SubAtomicGenius
2011 JK Wrangler
Originally Posted by Mol View Post
Beads/sand are retarded...
I balanced a set of thoroughly used, and DIY grooved/siped comp compound tires on bead locks with sticky weights. Have never rebalanced them and I wheel my rig a lot harder than the average Joe. Reinflate to 30lbs and I'm comfortable up to 90mph.
Nothing fancy...I just use what has always worked. This whole bead craze is ridiculous, it doesn't even make sense. Can't even begin to tell you how many people have come in with wobble, shiy problems that we fixed by emtyping the tires and balancing with weights.
X2 Beads are retarded. Just balance the ****ing tire already.
SubAtomicGenius is offline
post #3289 of 4008 Old 09-06-2013, 05:53 PM
04WJfreedom
Yeah I have a few places near me with with a hunter road force balancing machine. I'm going to have to try that out. Thanks
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #3290 of 4008 Old 09-06-2013, 08:28 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Fwiw, the tires I mentioned above:
Size:  86.3 KBName:  1378520631234.jpg
Are a lot "nobbier" than the average nitto, bfg, Goodyear discussed here. I balanced them myself, on a regular old wore out balancing machine, with about four other sets of tires under my belt (my own tires). No problems since day one. Worst tire had 10.5 oz, best had 8.5 I think. Keep in mind these are bias ply competition compound rubber that have all been cut by hand (far from symmetrical).
The trick is to find someone that's not and idiot, I guess balancing a tire is not a tough feat.
Mol is offline
post #3291 of 4008 Old 09-06-2013, 10:41 PM
DangFoo
Wow, those are nasty (in a good way)!
DangFoo is offline
post #3292 of 4008 Old 09-07-2013, 01:34 PM
1222
RIP John
1222's Avatar
The post from Erbo1Kanerbo and all subsequent posts related to it have been moved to the Wrangler General Discussion forum with the title Check it out!
1222 is offline
post #3293 of 4008 Old 09-08-2013, 12:29 AM
TRAUMAhead
2010 JK Wrangler
Leveling kit and 35s.
TRAUMAhead is offline
post #3294 of 4008 Old 09-08-2013, 07:45 AM
Mol
Mol's Avatar
Looks GREAT trauma...understated and beefy
Mol is offline
post #3295 of 4008 Old 09-08-2013, 08:26 AM
04WJfreedom
Agreed! looks good with the flat fenders too!
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #3296 of 4008 Old 09-08-2013, 10:48 AM
bluerockymtn
Great backdrop as well
bluerockymtn is offline
post #3297 of 4008 Old 09-08-2013, 11:09 PM
TRAUMAhead
2010 JK Wrangler
Thanks. Would've had it lifted over the summer, but I got was getting tired of the 3.8L, 4:10s, automatic, 35s combo so I opted to get it regeared. Disappointed with 5.38s and would rather have the lift right now. :
post #3298 of 4008 Old 09-09-2013, 08:36 AM
rock-rocker
Trauma,
Why are you disappointed with the 5:38's? I have a 3.6 with the Auto and 4:10's and after I install 35's I'm planning on regearing to 5:13's. Please let me know cause you have my curiosity about whether I should go 5:38's instead. I will be taking mine on the Rubicon often so I have to take that into serious consideration. Thanks
BTCS, USN, Retired
2013 Jeep JKU Rubicon 10th Year Anniversary.
rock-rocker is offline
post #3299 of 4008 Old 09-09-2013, 10:20 AM
RogueStatus
Originally Posted by rock-rocker View Post
Trauma,
with 35s and the 3.6 auto i would either do a 4:56 or 4:88 gear set... you dont need anything that low (or high? i always get confused haha) on the 3.6 unless you have larger tires.
my buddy with the 3.6 and an auto runs the 5:38 gears with his 42" tires for example.
Jeep-less again
RogueStatus is offline
post #3300 of 4008 Old 09-09-2013, 10:33 AM
rock-rocker
I was considering 4:88's in the very beginning but I was erroring to the good because I wanted a good crawl ratio for a little solid rock climbing. That's why I was so surprised over the mentioning of disappointment of the 5:13's. I know I'll lose mpg with the 5:13's (along with some wear and tear) but the good thing is my wife currently uses it as a DD and her commute is only 15 miles one way. Also I'll eventually get her the vehicle she wants and the Jeep will be all mine. I haven't thrown 4:88's out the window yet...that's why I love these forum's because it constantly keeps me on my toes thinking all the time. Just when I thought I knew what I wanted and where I'm going there a detour...arrrrrgggggggg.........(put thinking cap back on and wallet back in pocket)
BTCS, USN, Retired
4 door , image , JK Wrangler , lifted , photos , pictures , unlimited , wrangler
Lifted 4DR Rubicon to less lifted help h2obuff JK Wrangler Technical Forum 7 05-25-2012 09:23 AM
lifted 4 door t-case explosion adrock85 JK Wrangler Technical Forum 26 02-27-2012 11:02 AM
Lifted 2 door driveshaft/rearend clicking? ArmyMud JK Wrangler Technical Forum 3 01-29-2012 01:58 PM
Full size Door outer door latch issue andrew2641 YJ Wrangler Technical Forum 2 12-20-2011 06:58 AM
Questions about Half Door and Full Door Locking Mechanisms... atticus_ar TJ Wrangler Technical Forum 8 12-04-2009 01:26 PM
