Lifted 4 door JK's Only! - Page 154 - JeepForum.com
 11Likes
post #2296 of 4008 Old 08-20-2012, 08:08 PM
Wonk
Originally Posted by jvandy50 View Post
^^this. And 3 grown men at least. It may depend on the tires but the MTR/K just did not want to stretch over that outer bead. We had to use fender washers to hold our place on the other side or about a 1/4 of the tire would just pop up on the other side. Used a couple molding tools and a wonder bar to bring lip over, and then a dead blow hammer to beat it the rest of the way over.
All the videos I've watched on the Internet DID NOT look that hard at all. Granted this was our first time doin it, but it just wasn't as easy as I thought. I knew it'd be tedious, and that was the easy part, but we are all sore after doin 5 lol
HUH??? What are you talking about? You didn't bolt the beadlock ring on before putting the tire on the wheel did you? I don't understand.
Wonk is offline
post #2297 of 4008 Old 08-20-2012, 08:17 PM
AppSt59Dave
2012 WK
That's funny as sheet. I just spit out my banana pudding!
'78 CJ-5 Loden Green, in the barn
'12 WK2 Black Forest Green Hemi
AppSt59Dave is offline
post #2298 of 4008 Old 08-20-2012, 08:23 PM
Wonk
Not trying to be funny. I've actually seen a Jeep dealership "install" a set of beadlocks on a new Jeep and they put the outer tire bead over the lip that the beadlock ring bolts to then bolted the beadlock ring on. I still don't know how they held air.
Wonk is offline
post #2299 of 4008 Old 08-20-2012, 08:28 PM
jvandy50
2010 JK Wrangler
probably bad terminology on my part. See the tire by the upper right corner of rim, it wouldn't go over the wheel without another part popping up. Not even with a 230# guy standing on the area that was already seated, it'd still pop up
jvandy50 is offline
post #2300 of 4008 Old 08-20-2012, 08:34 PM
AppSt59Dave
2012 WK
Width on that MTR? 13.50? I'll be mounting
Either a 35x12.50 Trail Grappler or a 36x14(I think) Irok Radial. Either way, lots of sunshine and tire lube!
post #2301 of 4008 Old 08-20-2012, 08:50 PM
Wonk
Just to clarify, the tire doesn't go OVER the part that has the bolt holes in it. It rests on TOP of this ring and is squeezed between the rim and beadlock ring. Shouldn't need any tire lube. With the tire in the position it is in the above pic, lay the ring on the wheel and use 4-6 extra long bolts evenly spaced around the ring to start the ring down evenly on the tire/wheel. Once everything is centered up, start putting in the regular bolts and tighten them in a criss-cross pattern a little at a time (neversieze all the bolts) and replace the long bolts with the supplied regular bolts. Keep tightening in the criss-cross pattern a little at a time until they are all evenly torqued to the recommended torque setting. Repeat 3-4 more times.
Wonk is offline
post #2302 of 4008 Old 08-20-2012, 08:53 PM
jvandy50
2010 JK Wrangler
12.50. We didn't have much heat here saturday so i put em in the powdercoating oven at 140 pretty much all day. used some soapy water too(mostly soap). i had read these tires were not fun to mount in multiple threads on forums, and that pretty much turned out to be true.. for us anyway. and no i didn't bolt up the ring and then try it. hope you have an easier time than we did!
jvandy50 is offline
post #2303 of 4008 Old 08-20-2012, 09:28 PM
jvandy50
2010 JK Wrangler
this isn't how mine worked. we needed lube to get the tire on, and the longer bolt idea didn't work for us. it didn't "rest" on anything, it had to be persuaded like crazy and then put the ring on. and by the time we had the inner tire over the lip, the standard bolts reached, just barely, but they did.
OP, what wheel did you order? i'm guessing some are designed a little differently
jvandy50 is offline
post #2304 of 4008 Old 08-21-2012, 12:45 PM
jvandy50
2010 JK Wrangler
AppSt59Dave, what wheel did you order? i'm guessing some are designed a little differently
jvandy50 is offline
post #2305 of 4008 Old 08-21-2012, 05:51 PM
AppSt59Dave
2012 WK
ATX Slabs. Im doing an article on it for my company's website and fb page. Should be a fun learning experience
post #2306 of 4008 Old 08-21-2012, 05:58 PM
Xet2ss615
AEV 3.5" lift
17" AEV pintlers, argent color
35" Goodyears
2012 Sahara JKU
Wife hates it now, too tall. Rock sliders power step sliders in the mail!
Xet2ss615 is offline
post #2307 of 4008 Old 08-21-2012, 06:01 PM
Xet2ss615
opps
post #2308 of 4008 Old 08-21-2012, 06:03 PM
Xet2ss615
opps
not sure why upside down!
post #2309 of 4008 Old 08-21-2012, 07:00 PM
jvandy50
2010 JK Wrangler
So pretty much same wheel as me with different ring. Those were back ordered when I got wheels. Love em. If you have any question during install feel free to holler at me. I can give ya the links I used to help us out. I don't think it'll be as difficult as long as you use a tire that isn't an MTR/K. That seems to be the common denominator in the other 2 folks I found that had a PITA time mounting them. Good luck and post some pics when done!
jvandy50 is offline
post #2310 of 4008 Old 08-21-2012, 07:08 PM
Papawhiskey
2011 JK Wrangler
Doors off
Papawhiskey is offline
4 door , image , JK Wrangler , lifted , photos , pictures , unlimited , wrangler
Lifted 4DR Rubicon to less lifted help h2obuff JK Wrangler Technical Forum 7 05-25-2012 10:23 AM
lifted 4 door t-case explosion adrock85 JK Wrangler Technical Forum 26 02-27-2012 12:02 PM
Lifted 2 door driveshaft/rearend clicking? ArmyMud JK Wrangler Technical Forum 3 01-29-2012 02:58 PM
Full size Door outer door latch issue andrew2641 YJ Wrangler Technical Forum 2 12-20-2011 07:58 AM
Questions about Half Door and Full Door Locking Mechanisms... atticus_ar TJ Wrangler Technical Forum 8 12-04-2009 02:26 PM
