Lift and tire/rim size question. - JeepForum.com
post #1 of 4 Old 02-24-2010, 11:14 AM Thread Starter
RainingThunder6
im looking to lift my jeep 2 inches. i think im going to go with the OME kit, but i want to keep my stock rims cause i don't have a lot of money right now. i also want to get the 32X10.50 Mickey Thompson MTZ tires but i don't know if they would fit with the 2inch lift. im very new to the whole jeep thing so any help is much appreciated
RainingThunder6 is offline
post #2 of 4 Old 02-24-2010, 11:21 AM
bigdobes
2009 JK Wrangler
I have the 2.5" OME lift on my '09 Rubi and just upgraded to 35" tires. I checked to make sure I wasn't goiung to rub. You should be just fine with 32s'.
bigdobes is offline
post #3 of 4 Old 02-24-2010, 11:25 AM
MrOrange
2009 JK Wrangler
welcome to the Jeep scene. There's a lot of good information here on the forums and plenty of helpful people. One thing we do request is that you do a little research before posting just to make sure the info isn't already out there. At the top of the forum are some stickies which handle some of the more common questions like yours.
http://www.jeepforum.com/forum/f96/faq-will-rub-610856/
Just for reference, any JK can run 32s with a stock suspension without an issue. Rubicon models come with 32s. As far as how wide can you got, you can check the tire size on a Rubicon as a good starting point and can even check the tire manufacturer's website on what size wheel the tire will fit on. If you go too wide you do run a risk of rubbing when at full turn. Hope this helps and don't forget to wave.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #4 of 4 Old 02-25-2010, 09:39 AM
Tornado
[QUOTE=MrOrange;8959232]Just for reference, any JK can run 32s with a stock suspension without an issue. QUOTE]
Notice he said "any JK" it looks like you have a TJ, you should go to the TJ section to research you question.
And welcome to the Jeep community!
Tornado is offline
2 inch , lift , micky thompson , ome
Lift and tire size question whitecopter TJ Wrangler Technical Forum 1 11-22-2008 11:03 AM
Lift and tire size question skeeterskat TJ Wrangler Technical Forum 2 08-11-2008 09:56 PM
Lift/Tire Size Question autovon TJ Wrangler Technical Forum 4 06-20-2007 09:51 AM
Lift and Tire Size Question BjeepK315 TJ Wrangler Technical Forum 4 03-20-2005 03:22 PM
Lift and tire size Question? Broadway TJ Wrangler Technical Forum 6 01-26-2004 09:43 AM
