Lift and Ride, Can you have both? RE or MC - Page 3 - JeepForum.com
post #31 of 36 Old 01-17-2014, 07:27 AM Thread Starter
Luxx989
Originally Posted by brianjw View Post
37s and 4.5" is way overkill for you. You'll spend a ton if money in the long run and just end up with problems trying to make it drive straight and chasing vibrations.
I'd recommend the AEV 2.5" lift, with geometry correction brackets, synergy full suspension bolt/hardware kit, and a quality adjustable front track bar. 35s max if you really think you have to. It should handle well, retain stock driveshafts, and hold up reasonably well for what you're doing.
Originally Posted by PhatBasturd View Post
X2. Would be a good choice for this OP with 35's. Rides better than stock on road.
You may need a new front drive shaft at some point with anything >3".
Thanks, I appreciate the details
Luxx989 is offline
post #32 of 36 Old 01-17-2014, 09:55 AM
1222
RIP John
1222's Avatar
...You may need a new front drive shaft at some point with anything >3"...
Thatís true and an often overlooked fact. I had to on my í08 and now Iím getting a slight rumble on my í12.
(2011-2016)
1222 is offline
post #33 of 36 Old 01-17-2014, 02:51 PM Thread Starter
Luxx989
I'm starting to agree with the 2.5" option - So with front and rear bumpers, winch, tire carrier. (admit idly for looks other than the winch) would I possibly need to think about a 3.5" to account for added weight that might pull it down a bit? If I go small with the 2.5", I'm gonna want to keep all of that 2.5" I'm gaining. The AEV 2.5" says up to 35", but so does their 3.5", up to 35" as well. I did not see where the Metalcloak specified, but I know I saw it somewhere I think?
Luxx989 is offline
post #34 of 36 Old 01-17-2014, 02:55 PM
14Sport
Proud Deplorable
14Sport's Avatar
With my 2.5 MC, I got 3.25" in the front and 3.5" in the rear, before the wheels. I have steel bumpers, tire carrier, sliders, winch, and hardtop on my 2-door.
14Sport is offline
post #35 of 36 Old 01-17-2014, 05:18 PM
brianjw
AEV springs are progressive and designed to provide lift with aftermarket bumpers and accessories.
brianjw is offline
post #36 of 36 Old 01-17-2014, 05:20 PM
yjcrawlr
My only advice would be build your jeep for its intended purpose! If not you will be throwing money away and you will not be satisfied with the end product. This is why my jku has a 2" lift and 33s. 37s are not practical for a daily driver unless you live real close to work or have really deep pockets.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
