Lift Questions? Tire Questions - JeepForum.com
post #1 of 9 Old 01-20-2011, 01:58 PM Thread Starter
john304
2010 JK Wrangler
Real quick, traded a 2008 Mustang for my '10 JK Sahara, love it. I'm rather knowledgable on Mustang specs and mods, but not Jeep. So I need help.
First question, lift. I just want a small lift, as my offroading is nothing major. The trails and roads I drive on in the mountains here in WV on a scale from 1-10 probably don't exceed a 5. My problem is, do I go with a body lift or suspension lift? Being in college I don't really want to put a lot of money into a lift. Performance-speaking, like I said, I'm no champ and it doesn't matter, I just want some more clearance so I can step it up a notch offroad. I'm looking at a 2" body lift from Zone offroad, and also a Teraflex 2.5" budget booster from Quadratec. What modifications, if any, need to be made after installing a lift? If it's going to be a lot of work, I may go a different route. Also keep into consideration this is my only vehicle so it's a daily driver.
Next question, tires. What are the biggest tires I can run without rubbing? This is really ignorant but I don't even know what's on my Sahara, I just know it's stock. Also, with bigger tires, is regearing required? I know I'd have to adjust my odometer, but anything else? And another thing, can I run bigger tires on my stock rims? =\
If I didn't make myself clear please tell me and I'll try to explain a little better. Thank you guys so much for any help/input.
*EDIT*- I have a 2dr Sahara, auto trans. If that helps.
john304 is offline
post #2 of 9 Old 01-20-2011, 02:15 PM
skivviss
2010 JK Wrangler
a 1-2" puck budget boost + jks quick disconnects
a bit more underbody clearance and a lot more flex up front for a pretty cheap price
getting some rubicon take-off coils, shocks from a 4dr, assuming you have a 2dr sahara would also net some more lift.
rubicon take-off tires would also be another minor upgrade. slight lift and better rock/mud tread pattern then the stock sahara tires.
skivviss is offline
post #3 of 9 Old 01-20-2011, 02:19 PM Thread Starter
john304
2010 JK Wrangler
Thanks. The coils, shocks from a 4dr, in addition to the budget boost and jks quick disconnects or as an alternative? Sorry. Also, Rubi tires would fit on mine? I thought the Saharas had bigger wheels =\
john304 is offline
post #4 of 9 Old 01-20-2011, 02:28 PM
skivviss
2010 JK Wrangler
oops, you are right on the wheels, sahara 18s. so you would need full rubi wheel/tire take-offs. on a budget i wouldn't worry about the tires, the A/T aren't going to let you down in 5rated stuff.
i'd say a good budget setup to boost your sahara offroad would be:
1-2" budget boost pucks
rubicon 4dr coils
jks quick discos (or any similar product)
you could also get the rubicon take off shocks, slightly better then the non-rubi ones. won't really improve clearance or such, but a slightly better washboard ride. probably not noticeable.
if you still want to do tires, you can probably sell your take-offs to recoup a bit the cost of rubicon take offs for yourself.
others have posted great deals on 15" rims/tires. most of the time tires get cheaper the smaller the rim they go on. have to be careful on 15s not all will fit the jk properly.
skivviss is offline
post #5 of 9 Old 01-20-2011, 02:33 PM
skivviss
2010 JK Wrangler
oh, and virtually free one. cut the stock bumper ends off and turn it into a stubby. will help on approach angles quite a bit when you can hit things at an angle and crawl up and over even when its taller then your bumper.
skivviss is offline
post #6 of 9 Old 01-20-2011, 02:46 PM Thread Starter
john304
2010 JK Wrangler
Sorry again, but by jks, is that a brand, or are you meaning like, JK's (the model)? lol
john304 is offline
post #7 of 9 Old 01-20-2011, 03:10 PM
skivviss
2010 JK Wrangler
JKS Quicker Disconnects is a brand of sway bar quick disconnects. There are a few companies making them.
skivviss is offline
post #8 of 9 Old 01-20-2011, 07:14 PM
gdub
2010 JK Wrangler
Check your spring part numbers (on the tags) if you have the towing pig you may have the stiffer springs anyway - highest number for fronts is 19 and back is 60...
If you are close on those #'s then just go to a 2.5 budget boost and some quick discos (JKS are nice, but here are others as well - some of the bb's come with them) and you should be good to go...
2.5" Rock Krawler Stock Mod Lift : Bilstein 5100's Front & Back : Rock Krawler Discos : 35X12.5X17 Goodyear MTR/K's : ProComp 7089's 17x9 4.75BS : Poison Spyder Evap Skid : Poison Spyder Brawler Lite : Spiderwebshade - Trailmesh : Recon 10,500lb Winch : Olympic Rock Sliders : Hella Black Magic Lights
gdub is offline
post #9 of 9 Old 01-20-2011, 07:31 PM Thread Starter
john304
2010 JK Wrangler
Thanks guys
john304 is offline
Help...lift and tire questions... Full_Rut95 YJ Wrangler Technical Forum 5 09-19-2009 07:32 AM
Tire/Lift questions (oh yay) 41MB-04TJ TJ Wrangler Technical Forum 4 11-03-2007 09:16 AM
A FEW TJ lift and Tire Questions! Jeremy E TJ Wrangler Technical Forum 9 02-07-2007 12:20 PM
same old lift/tire questions lokua TJ Wrangler Technical Forum 6 03-07-2006 07:41 AM
Enough Lift/Tire questions! K9JEEP TJ Wrangler Technical Forum 4 01-21-2003 10:37 PM
