Lift kit install time - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Lift kit install time
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 05-23-2008, 03:58 PM   #1
Pirata
I am looking at a ballbark time for installing a 4" Rough Country lift kit on a JK. Also is there anything in the install that "needs" 2 people? I will be John Wayne'ing this tomorrow but if it's impossible to do single handedly I will call the cavalry to assist.
The only way to discover the limits of the possible is to go beyond them into the impossible.
Pirata is offline   Reply With Quote
Unread 05-23-2008, 05:57 PM   #2
igofshn
Locked @ both ends
igofshn's Avatar
By yourself having no experience, probably 8 hours. If you know what you are doing less than 4. There is no need for 2 but it sure does make it go quicker.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Unread 05-24-2008, 02:25 PM   #3
Pirata
It there an easy way to remove a pitman arm? I tried and tried to remove it with a pitman puller to no avail. Any suggestions?
Unread 05-24-2008, 08:28 PM   #4
Pirata
Anyone have some guidance here?
Unread 05-24-2008, 09:27 PM   #5
igofshn
Locked @ both ends
igofshn's Avatar
I really don't think the dpa is required. i run 3.5 up front with out a dpa and I have no problems.
[Jeep Pics
Unread 05-24-2008, 09:35 PM   #6
Pirata
The lift kit I bought came with a new pitman arm that drops the whole steering linkage 4" I am guessing it could be run without replacing the pitman arm but I am thinking it should have the new arm attached.
