Lift kit - JeepForum.com
post #1 of 9 Old 05-25-2012, 09:51 AM Thread Starter
WrnglrGal11
2011 JK Wrangler
Lift kit
Hey guys, looking to lift my 2011 two door wrangler. I don't want anything crazy, probably just three inches or so, maybe four. Any suggestions on good quality lifts?
WrnglrGal11 is offline
post #2 of 9 Old 05-26-2012, 03:26 PM
ljrubitm
2011 JK Wrangler
How much $$$ are you willing to spend on a lift? Do you want to run 33',35'', or 37''?
ljrubitm is offline
post #3 of 9 Old 05-26-2012, 03:37 PM
jeepinjeffrey
look on quadratec.com or other websites for different lift brands
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #4 of 9 Old 05-26-2012, 04:51 PM
fernjack
Old Man Emu........
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #5 of 9 Old 05-26-2012, 08:04 PM
jaxs1984
2009 JK Wrangler
In all honesty , you must ask yourself how much are you willing to spend I would guess that 99.9 of the people that get a lift over 2' end up getting new tires and wheels to match the lift. And we all know what happens if you get bigger tires/wheels you may have to upgrade your gears, etc.. Its a loaded question What are you trying to accomplish ?
If your just looking for brands, I would suggest Old Man Emu, AEV . Of course, more people would chime in with different brands.
jaxs1984 is offline
post #6 of 9 Old 05-27-2012, 04:31 AM
SubAtomicGenius
2011 JK Wrangler
TeraFlex all the way.
Type of lift is dependent on your BUDGET and your PURPOSE for lifting the vehicle. Lift facts:
First, 3" or 4" of lift for a 2011: if you keep it to 3" or less, you won't need new driveshafts right away (stock ones will fail [sooner] with more lift than that due to being stretched out and too short).
$$$ With 3" of lift, and to maintain great drivability, you'll need some way to adjust the caster angle for your front axle to prevent the 'dartiness' feeling during steering/driving and re-center your wheels in your wheel wells (Jeep goes up, tires will sink into the center of the vehicle with stock control arms due to them being shorter). There are many ways to fix this, including adjustable control arms, brackets, etc. IMHO the proper way to go is adjustable upper and lower control arms (or adjustable lower control arms as a minimum). Your budget will ultimately decide what you want to do, however.
$$$ With 3" of lift or more, you'll most likely need a new front adjustable trackbar and a rear adjustable trackbar/trackbar relocation bracket to re-center your axles under the vehicle (each one will have a tendancy to poke out further on one side when lifted otherwise and look silly).
$$$ Brake lines may be an issue for the front and rear - they will be too short when articulated - some lifts use relocation brackets, but the best thing to do is to get longer brake lines (stainless steel braid).
You can see where this is all going! With a simple spacer lift, you'll have axle caster issues, driving handling issues, axles will not be centered under the vehicle from left-to-right, brake lines may not be long enough when suspension is articulated, and driveshafts will give up the ghost due to stress.
IMHO, if you are on a budget and going for looks, keep it to a 2.5-inch budget boost. If you want to stretch your legs and go offroading and have good handling on the road: go with a full-control arm lift kit package with adjustable trackbars and new brake lines. If you go more than 3-inches, expect to have to purchase new longer aftermarket driveshafts sooner or later.
SubAtomicGenius is offline
post #7 of 9 Old 05-27-2012, 05:02 AM
1222
RIP John
1222's Avatar
My advice is to study this forum and a couple of others and do some major research. Lifting the JK is not something to take lightly, you need to study up and see what others have done and are doing. Depending on how high you want to go “lifting” when all said and done can get very expensive. When/if you decide to research, have a note pad and pencil handy, it’s very easy to get overwhelmed and forget what you’ve learned. Good luck.
1222 is offline
post #8 of 9 Old 05-27-2012, 01:26 PM Thread Starter
WrnglrGal11
2011 JK Wrangler
Thanks everyone for your input. Little did I know, the legal lift in my state is only 2". So I'm going to do some more research and probably go with a 2" lift with 33's just to be sure that I can still get a sticker.
post #9 of 9 Old 05-27-2012, 03:53 PM
1222
RIP John
1222's Avatar
Originally Posted by WrnglrGal11 View Post
...Little did I know, the legal lift in my state is only 2"...
Damm that sucks big time, what idiotic state would that happen to be?
1222 is offline
