lift /gas millage - JeepForum.com
post #1 of 20 Old 08-12-2013, 07:31 PM Thread Starter
rockrider66
lift /gas millage
Does anyone know that how does the lifting of the jeep effect the gas millage & by how much ?
"ROCKRIDER"
rockrider66 is offline
post #2 of 20 Old 08-12-2013, 08:07 PM
brianjw
You're barking up the wrong tree if you're looking for a lifted jeep and concerned about mileage. There is no single answer.
Differences would depend on the engine, trans, axle ratios, lift height, tire size, etc etc etc. Too many variables.
I have a manual trans 2012 rubicon with 4.10 gears. Stock it got around 19mpg highway if driven easy. Now with a 3.5" lift, 35s, bumper, winch, heavy/taller top, I get around 17mpg in similar conditions. 16 in town normally. As low as 13mpg high in the winter if the roads are covered in water, it's windy and I'm driving 80mph.
So my guess is you'll lose somewhere between 1 and 8mpg. Useless right? The answer is it depends, and if you're concerned, don't lift it. Or don't get a jeep in the first place.
brianjw is offline
post #3 of 20 Old 08-12-2013, 08:15 PM
SubAtomicGenius
2011 JK Wrangler
I would say that lifting itself is negligible at best, however removing the front air dam has been noted to have an effect. More considerable is the addition of big tires and increased weight.
Frankly, IMHO, if people are concerned in any fashion about gas mileage and fuel economy, they shouldn't purchase a solid-axle, 4x4 vehicle. A proper decision-making tree would include: choosing form and function, overall cost of purchase, cost of operation and maintenance (including fuel), etc. before deciding to buy. But that's just me. And that's why I don't drive a Corolla.
SubAtomicGenius is offline
post #4 of 20 Old 08-12-2013, 09:23 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Corolla? A SmartCar seems better for you.....
Agree, too many variables just in general about anything you do to modify your Jeep from factory will result in lower mpg IMO, just how much depends on all those other things (variables)...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 20 Old 08-13-2013, 01:50 AM
SubAtomicGenius
2011 JK Wrangler
... smartass car... lol
post #6 of 20 Old 08-13-2013, 02:52 AM
Breitling
Any extra weight decreasing your mpg, lift is normally done to install larger and heavier tires and tons of other heavy cra. on your Jeep Wrangler is initially bad aerodynamically, lift is making it worse I believe.
But you are getting great look and improve your off road abilities, so think about what is better for you? I am not lifting ...
2013 Jeep Wrangler Unlimited Sport S, hardtop, white, duratracs, tons of mopar parts
2012 Mercedes Benz C350 coupe, white
Breitling is offline
post #7 of 20 Old 08-13-2013, 09:20 AM
dyjk44
Went from 19-20 mpg highway to 16-17 mpg after adding 3" BDS lift and 35's. Didn't buy if for fuel economy, so it didn't matter to me.
dyjk44 is offline
post #8 of 20 Old 08-13-2013, 09:50 AM
Scherer
3.5" AEV lift, 37" KM2s and I get 14-15 MPG around town.
“The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money.”
- Alexis de Tocqueville
Scherer is offline
post #9 of 20 Old 08-13-2013, 12:55 PM
xraypat23
I didn't buy or lift for economy. But my 2008 JKUR with a 2.5" rock krawler lift and 35's and 5.13's got 19mpg on a recent trip upstate, and 17 on the way down towing a 1500lb trailer. Gas mileage is directly proportionate to how hard you press on the skinny pedal. keep your cruise set at a respectable number(sub 70mph) and it'll do ok.
xraypat23 is offline
post #10 of 20 Old 08-13-2013, 02:08 PM
73azbronco
Tire pressure biggest variable for my 2dr JK. 35's/3" TF lift, tires at 38psi, I can get 19 in town, tires at 32, I get 15.
73azbronco is offline
post #11 of 20 Old 08-13-2013, 05:14 PM
DangFoo
Lifting doesn't impact mileage in and of itself. The extra weight is usually negligible on most suspension kits, but wider/taller tires or aggressive treads with greater rolling resistence will adversely impact your mpgs.
I get about 15 mpg with 35s and 3.73 gearing [2008 JKU]. The newer generation engine 2012+ may yield a little better.
DangFoo is offline
post #12 of 20 Old 08-14-2013, 02:35 AM
Yendor
I'd have to agree that the lift alone won't effect fuel economy. A jeep is about as aerodynamic as a dehumidifier. Kind of hard to make it much worse. But almost no one lifts without putting on big tires, and the tires are what probably kill your mileage.
Probably not applicable, but I lifted the front of my 11 Ram Hemi 2.5". (Stock tires) At the same time, I installed an AirRaid cai. I think I actually picked up about 3/4 of an mpg; which isn't much, but better than a loss. From Cullman Al to Jasper in, I got 20.7 mpg, hand calculated. Not bad for a vehicle rated at 19 mpg.
MPGs are the reason I'd want a diesel.
Yendor is offline
post #13 of 20 Old 08-14-2013, 04:42 AM
hub0619
2010 JK Wrangler
Ur gonna lose some mpg but ur gonna be happy you lifted if you do use it. It's alot more fun now with the lift
hub0619 is offline
post #14 of 20 Old 08-17-2013, 11:52 AM Thread Starter
rockrider66
Holly molly !!!! I just asked a general question & you guys brought me down to the "corolla level " . Looks like i touched a sensitive nerve .
I want to enjoy the perks of a lifted jeep but also was thinking of my daily commute . Was trying to get the best of the two worlds .
But I liked Hub0619's answer the best ......Thanks
FYI : My other car is Benz S500 ......an 8 cylinder monster ........i'm not the corolla type of a guy ;-)
"ROCKRIDER"
post #15 of 20 Old 08-17-2013, 09:11 PM
JTPhoto
JTPhoto's Avatar
Sorry Bud, but this happens from time to time when lift and MPG appear in the same post.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
