lift - JeepForum.com
post #1 of 6 Old 06-17-2010, 02:39 PM Thread Starter
2jk1cjtj
lift
do i need to get a front track bar, and new sway bar links with a rc 2.5 spring lift. or will it be ok
2jk1cjtj is offline
post #2 of 6 Old 06-17-2010, 02:52 PM
MrOrange
2009 JK Wrangler
http://www.jeepforum.com/forum/f96/2...k-bar-1041183/
http://www.jeepforum.com/forum/f96/2...ck-bar-887836/
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #3 of 6 Old 06-17-2010, 04:40 PM
onecrazyjeep
i just installed my rc 2.5 coil and shocks and didnt need any new track bar or sway bar links. one piece of advice is to track bar relocatin brackets. they keep your axels in line.
onecrazyjeep is offline
post #4 of 6 Old 06-18-2010, 06:00 AM
JKRoobi
From what I have gathered, its not required by most manufacturers, but wouldn't hurt to have. Pretty much any amount of lift shifts the axle some (less noticeable with less lift)...2.5" usually shifts the axle about 1/4" (this coming right out of RC's instructions).
The rear should come with a relocation bracket so no worries there...however the front will still be off slightly.
2010 Rubicon Unlimited - Sold
2000 XJ Sport
JKRoobi is offline
post #5 of 6 Old 06-18-2010, 07:27 AM
Dronac
For what it's worth, I got 3'' of lift out of my Rusty's Offroad coil lift, and didn't replace anything but the springs and shocks and everything is fine for me. If my axles are off, you would need a tape measurer to notice and it has no effect on driving so far. My sway bar links are a bit short, but until I can get some new links it's fine, if not a bit wobbly on speed bumps.
If it were me, I wouldn't bother with a new track bar until I was finished with all my other mods. I still have a few thousand dollars to spend before I'm finished
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #6 of 6 Old 06-18-2010, 08:03 AM
Charles
2017 WK
You don't need it but you're axle won't be centered without it.
Charles is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 10:11 AM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 06:59 PM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 11:03 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 10:04 AM
