Leveling/Lifting Question - JeepForum.com
post #1 of 14 Old 07-03-2014, 10:41 AM Thread Starter
ChefsSVX
Well I have read a bunch of threads about how people want to level their JK's and whatnot, but almost all of them are just stock or very minimal things done to them which makes it a bit difficult what to decide to do.
I do plan on doing a real lift but probably not for another year or so till I pay it off a bit more. I do use it quite hard sometimes so I think that the pucks wont do anything but give me trouble So I was thinking maybe a coil spring leveling/lift since I am sagging a lot in the front.
I have a Smittybilt XRC bumper with a Engo 10k winch and they are quite heavy. I have also upgraded my wheels and tires to a 4.5' bs and 33' tires, so I know I wont have to buy wheel spacers so I don't have any rubbing issues.
So what I really need to know is if I should just get the leveling springs now and I know I would also need a stiffer set of shocks as well, since I do plan to go to a 3' kit in the future, most likely a long arm kit as well. Or should I just deal with it for now and stick with the saggy front end.
Any insight is more then appreciated, thanks.
ChefsSVX is offline
post #2 of 14 Old 07-03-2014, 10:55 AM
222Doc
222Doc's Avatar
when you go to more lift the shocks will be longer so the shocks on a leveling kit wont be the same as the ones for a full lift. 3" lift wont need long arms. A 3' foot lift would need? Just kidding
Long arms on 33"s(33' foot tires?) and a small lift will just get hung up and drag on everything.
The front you could just get a 1" puck and call it a day. like 30+$. or go like 2-1 or 1.5-.75 For now. Unless you plan to really wheel your new jeep. then it should be built for the terrain intended. main issue is the track bars as you go up things shift to the left. as well as you go up you start to lose caster=control arms. the less lift the less correction needed.
222Doc is offline
post #3 of 14 Old 07-03-2014, 11:21 AM
JIMBOX
One thing to remember, you can't modify your jeep, NOW/one time and be set for life-
As time goes by, you get older/jeep gets older/family grows/wife changes hobbies--many things change, so forget trying to doitall NOW-
Make your move for the NOW time and see if you're happy withit for a period of time--then you can change/leaveit---whatever
Don't think about changes you're gonna make in a year+--that'll change-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 14 Old 07-03-2014, 12:45 PM
YATZI1980
2011 JK Wrangler
Good luck
JIMBO
Agreed but You also don't want to buy things twice and double pay. Not everyone has unlimited budgets for jeeps. So maybe look at a kit that is expandable ? You will get height from pucks but no performance... Springs will still be compressed from the heavy load.
YATZI1980 is offline
post #5 of 14 Old 07-03-2014, 01:00 PM
Maertz
2009 JK Wrangler
any kit is expandable...
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #6 of 14 Old 07-03-2014, 02:06 PM
JIMBOX
The never ending story--
Pucks are not detrimental to performance and springs compress, regardless of "PUCKDOM" the only thing jeopardized is EXTREME ARTICULATION and you won't have to worry about that !
Heh Heh, righton--
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #7 of 14 Old 07-04-2014, 02:38 PM
YATZI1980
2011 JK Wrangler
He said he has a heavy bumper and winch so his springs are more compressed. I just saying the pucks won't help with that.
post #8 of 14 Old 07-04-2014, 06:30 PM
JIMBOX
ok, LETS RETHINK THAT NOW--
My front springs are compressed to 8", but I have 2.5" PUCKS on them so my front bumper is --2.5" higher than it was, because--
My PUCKS are Cad. plated steel--NO COMPRESS- they measured 2.5" in the box and they lift the front suspension---2.5" !
Now over a period of time, the springs will compress more, but they will with, or without PUCKS !
It's a jungle out there-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #9 of 14 Old 07-04-2014, 10:58 PM
MudDuck99
2014 JK Wrangler
my first mod was a PSC mid brawler and a winch. A month later I added teraflex leveling kit. It definitely helped with that
MudDuck99 is offline
post #10 of 14 Old 07-05-2014, 07:38 AM
YATZI1980
2011 JK Wrangler
Yeah obviously the pucks will give you height. But they aren't helping your springs any. You are still losing suspension performance. It's just an aesthetic fix. Me personally would rather change out the springs. Some people just love to argue even when there is no argument. I never said the pucks wouldn't give you height. What I'm saying is there is no real performance advantage with them in this situation.
Dude it's your jeep. Drive it enjoy it and build it how it will best suit you for what you need. I had the same problem. Ended up doing a 2.5" teraflex coil lift with Bilstein 5100s for $600 and I couldn't be happier with the ride improvement on and off road. I did add trackbars though and def recommend them. If you went that route you wouldn't be disappointed. Everyone says good things about the OME HD springs too.
post #11 of 14 Old 07-05-2014, 11:40 AM
SLADE
If your looking for cheap to get you buy until a more complete lift, Pick up a pair of 4 door "18" front coil springs and throw on it to help level it and hold the extra weight. You can get the rear to match, and have a 1"-2" coil lift for $100 or less + shocks. Get a pair of shocks that offer a little room to grow, and your one step closer to your 3" that you want.
Not all "lift" shocks need a lift (BUMP STOP). Not all "lift" shocks are longer. You really need to look at the collapsed length. For example, You can run a Bilstein 5100 for 2"-3" lift on stock bump stops. The stock shocks are about 14.5" and there is room for around a 15" shock. The Bilstein 5100 front (part # 24-146708) measure 14.98" collapsed and 24.63" extended and have 9.65" of travel. The Bilstein 5100 rear (part # 24-146715) measure 15.39" collapsed and 26.38" extended and have 10.99" of travel.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #12 of 14 Old 07-05-2014, 11:42 AM
rubicon17
What are some quality springs for just leveling the front for the added weight of a skid and winch? Ive though about 3/4" spacer but then its still going to have the rake.
rubicon17 is offline
post #13 of 14 Old 07-05-2014, 12:25 PM
SLADE
Old Man Emu or Synergy 1" (1" 4 door/ 2" 2 door).
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #14 of 14 Old 07-05-2014, 04:59 PM
Doctor7474
JKS ACOS adjustable from 1-4.5"
Doctor7474 is offline
