Leveling kit or suspension kit - JeepForum.com
post #1 of 9 Old 03-21-2014, 08:02 PM Thread Starter
A321jr
I am trying to make a decision on installing a leveling kit or suspension kit on my 2014 Rubicon. I only want to go 2 to 2.5" that's all. Anyone know which would give me the better ride?
A321jr is offline
post #2 of 9 Old 03-22-2014, 04:13 PM
Cause
MR CONGENIALITY
Cause's Avatar
...better ride?
In what way; on road, off road, handling, cornering, ???
1. Stupidity should be more painful!
2. Don't believe everything you think!
3. Your post is as worthless as you!
Cause is offline
post #3 of 9 Old 03-22-2014, 07:12 PM
222Doc
222Doc's Avatar
i feel that spacer lifts of 2-2.5 is not a great idea. I mean you just dropped what 35K+ on this new Rubi and are now going to stuff spacers of that size?(cheep lift) a leveling kit is just that not a lift . front say 1" rear 3/4 or to me at most 1.5 front 3/4 rear. there is a reason why the front is a bit lower as well. off road you do not want the front higher than the rear, or to me even level.
just m2c
222Doc is online now
post #4 of 9 Old 03-23-2014, 10:26 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
My opinion, at 2 to 2.5 inches, a good (emphasis on good) spring lift will ride better than a spacer or budget boost.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 9 Old 03-26-2014, 02:48 PM
Matt98XJ
Matt98XJ's Avatar
2014 JK Wrangler
I have been debating the same thing for the last several weeks. I ended up purchasing the OME lift with HD springs. I have not installed the kit yet, but I will most likely get close to 3 inches with the springs. You will be happier in the long run with the full kit, over the spacers in my opinion.
Well I woke up this morning, I grabbed myself a beer.
The future's uncertain and the end is always near.
Matt98XJ is offline
post #6 of 9 Old 03-26-2014, 03:19 PM
ferninaz
ferninaz's Avatar
Format for asking what lift you should get
1.2 Door or 4 Door?
2.Vehicle Year?
3.Do you go off roading?
What type of offroading?
-Rocks
-Mud
-Sand
-Prerunner desert racing
-Dirt roads (backroads)
4.What size tires would you like to run?
5.What size wheels would you like to run?
6.Will you be regearing?
7.Do you care about your comfort when on the road?
ferninaz is offline
post #7 of 9 Old 03-27-2014, 09:25 AM
ROCKR8R
Seems like a lot of misinformation here. Budget boosts do not ride bad. In fact, it will ride close to OEM, except of course the roll centers will change, but that is with any lift. You still gain ground clearance with a budget boost if you throw on bigger tires.
On the flip side, most aftermarket suspension will ride a bit more stiff than OEM as they are typically stiffer springs to accommodate more weight. Typically, most of us want a stiffer ride. Not that we want it to beat our kidneys down, but a bit more spirited. If ride comfort is truly your intention and you spend 99% on road, then the budget boost will probably ride more comfortably. The soft OEM springs will soak up bumps in the road. An actual spring lift will handle better but you will feel more bumps and what not in the road, it will also gain suspension travel and be able to support weight of steel bumpers and armor.
There are spacer leveling kits and lift kits also spring leveling kits and lift kits. It is really up to you what your end goal is.
PM me if you have any more questions and to talk about options.
-Dan
ROCKR8R is offline
post #8 of 9 Old 03-27-2014, 09:46 AM
tyvanwie
I had a 2" skyjacker bb on my JKU and loved it.
tyvanwie is offline
post #9 of 9 Old 03-27-2014, 10:20 AM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
This is my opinion, that is all.
If you want that much lift then do it with aftermarket springs. Those springs with appropriate shocks will give a better ride and handling. Why? because these springs will support the weight of aftermarket bumpers much better than stock, IMO along with the added wieght of larger tires.
All the factory stuff is designed to work with a factory stock vehicle. Stock bumper weights, stock wheel tire size and weight etc....You start changing parts and that messes up what the factory did.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
