LEDs on with switch AND/OR with highbeam - JeepForum.com
post #1 of 8 Old 09-25-2013, 08:59 AM Thread Starter
GreenRenegade
I'm trying to get my LEDs to light up (im)properly.
If I wire it into the highbeams, it comes on if the toggle switch is on, and it stays off if the switch is off when I use the highbeams.
I want it to come on with the highbeams AND I want it to come on with the switch, regardless if the headlights are on or not.
I am trying to do the same for the LED bar in the back with the back-up lights. I want it on whenever I shift into reverse AND I want it to come on whenever I hit the toggle, even when I'm not in reverse.
The switch, wired according to the constructions, seems to only kill the lights when wired to the highbeams or back-up lights.
What am I overlooking?
Dan
2013 Wrangler Rubicon 2dr
GreenRenegade is offline
post #2 of 8 Old 09-25-2013, 09:13 AM
brianjw
You need different switches. Double pole single throw (dpst) switches. They would typically be labeled "ON-OFF-ON"
Basically this switch would accept power from two different sources. Wire one that is always hot (or ignition switched) and the other source is your switched source (back up or high beam). The power goes out from the switch, to the relay, to the LEDs.
brianjw is offline
post #3 of 8 Old 09-25-2013, 10:58 AM
JTPhoto
JTPhoto's Avatar
Be sure that when connecting off factory wiring that you use relays as Brian has mentioned. All power in your Jeep is controlled by the computer and will sense the extra draw from a circuit and possibly throw a code. A relay does not draw enough to cause an issue..
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #4 of 8 Old 09-25-2013, 11:17 AM
73azbronco
Also be careful how you wire your choices, it sounds as if you wire the second switch to turn the lights on without the headlights on, you may provide a path for juice to feed your headlights when you turn on the aux lights. Relays are only way to go.
73azbronco is offline
post #5 of 8 Old 09-25-2013, 11:24 AM
rainmn
2014 JK Wrangler
I don't think you need a new switch, just a change in the wiring and couple of diodes.
Wire the LED lights to a relay.
Wire a +12v trigger from both the high beams (or reverse lights) and from the switch to the same pole on the relay
You'll need to use diodes on these two leads to prevent the +12v output from the switch from backfeeding into the high beam circuit and vice versa.
With it wired this way, the high beams should turn on the lights regardless of the switch position. The switch will also turn on the lights, regardless of whether or not the high beams are on.
rainmn is online now
post #6 of 8 Old 09-25-2013, 01:32 PM
Filthy-Beast
I did this with my LJ. I have a three position switch. Up is on and off with high beams, middle is off, down is on. You need to have two 87a relays. first one sends power to the fogs/driving lights and is controlled by the always on side of the switch. 2nd one is controlled by the operate with high beam side of the switch. If high beams are on it sends a signal to the 87A side of the first relay telling it to send power to the fogs.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #7 of 8 Old 09-26-2013, 05:41 AM Thread Starter
GreenRenegade
Thanks everyone for your help. This will give me something to start with.
Dan
post #8 of 8 Old 09-26-2013, 10:28 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
The simple way (as I now have to control high/low on my daystars):
If you wire the leds to to the normally closed lug of a dp relay - you can then fire the relay with the fog lamp wire. The leds will then be ON anytime the switch is powered and fogs are NOT (the fogs go off when you select high beams).
I am now going to modify with a three position - although more complex - more function. Thanks beast.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
