LED Lights-Where is the Dimmer switch? - JeepForum.com
post #1 of 10 Old 10-13-2009, 05:19 PM Thread Starter
spillz
Hi guys/gals...I'm in the process of putting a few led lights on my dash and I'm looking for a place i can tap in for power that will allow me to dim the led with the dimmer switch. Any suggestions? If so, can you please provide location. I have no clue and I've searched this forum with no luck on location. Thank you...
spillz is offline
post #2 of 10 Old 10-13-2009, 05:32 PM
Motomaniac321
are you talking about the switch that dims the radio, speedometer, and such? if so its located right next to your headlights on the same stick thing for your blinkers. if thats not what you were talking about then i apologize.
I'm also a huge gators fan. that was a good game against lsu
Motomaniac321 is offline
post #3 of 10 Old 10-13-2009, 05:55 PM Thread Starter
spillz
Yes, great game I would have never expected Florida to be in a defensive type of game. Unfortunately, I'm trying to tap into the dimmer switch for my led lights so when I dim my console lights etc..it will dim the LED lights
spillz is offline
post #4 of 10 Old 10-13-2009, 07:59 PM
Motomaniac321
oh, i think i gotcha now. cant help you there. sorry.
post #5 of 10 Old 10-13-2009, 08:10 PM
AlterEgo
Accessing the dimmer switch may not do you any good because it does not drive the lights directly. There is a pulse width modulated panel lamp driver in the instrument cluster that drives all dash illumination LEDs. I do not know if it has the capacity to drive extra LEDs or not.
Gary Greenway - KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
AlterEgo is offline
post #6 of 10 Old 10-13-2009, 08:39 PM
ronjenx
ronjenx's Avatar
Originally Posted by AlterEgo View Post
Accessing the dimmer switch may not do you any good because it does not drive the lights directly. There is a pulse code modulated panel lamp driver in the instrument cluster that drives all dash illumination LEDs. I do not know if it has the capacity to drive extra LEDs or not.
That's correct. When you turn the dimmer, you are only telling the computer you want the lights to be more or less bright. The computer does the rest.
The old days of tapping into the cluster lights are gone.
ronjenx is online now
post #7 of 10 Old 04-07-2010, 04:53 PM
GEM1N1
Bump. I'm trying to figure out where to tap into the headlight switch wires so my LEDS will come on when I turn the headlights on. Anybody......
2008 2dr Black Rubicon Automatic.
2.5" Rough Country BB
295/70/17 Nitto Trail Grapplers
GEM1N1 is offline
post #8 of 10 Old 07-21-2010, 08:37 PM
Victorcro
2010 JK Wrangler
I'm in the same boat mate!! i have some switches I am installing and need a dimmer feed for them.............I have looked everywhere of a feed and no luck. I am sure someone has figured it out right??
Victorcro is offline
post #9 of 10 Old 07-21-2010, 08:49 PM
Jiblet
I haven't done it (yet) but folks are hooking in footwell-lighting to the dome light wire. I believe it is a yellow wire with a white stripe in the bundle of wires found by the passenger kick panel (right side).
maybe this'll help:
Footwell lighting
Jiblet is offline
post #10 of 10 Old 07-21-2010, 09:36 PM
Victorcro
2010 JK Wrangler
Thanks to another forum here it is! just tested and it works like a charm!!
Orange with Gray stripe wire
dimmer switch , interior light , JK Wrangler , LED lights , wrangler
Having problems with lights. Does the dimmer switch run through the headlight switch? spshultz YJ Wrangler Technical Forum 2 10-25-2009 07:43 AM
HELP!!! Dimmer switch on 99 tj bradbodigon TJ Wrangler Technical Forum 5 12-08-2008 09:46 AM
dimmer switch rod laredo89 YJ Wrangler Technical Forum 5 01-24-2008 11:46 PM
dimmer switch help herde1724 YJ Wrangler Technical Forum 1 08-01-2006 12:01 AM
Lights staying on..dimmer switch?? HELP PLEASE!! ronandmichelle YJ Wrangler Technical Forum 5 03-11-2003 01:33 PM
