Quantcast LED on dash/footwells - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > LED on dash/footwells
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 08-13-2009, 10:06 AM   #16
MrOrange
2009 JK Wrangler
Originally Posted by ThomasMack View Post
How can we put this in so it goes on off with the vehicle? Can we wire this directly to the outlet that turns off and on?
If you want them to come on/off every time the vehicle does, you could always connect them to the power from the lighter. Just don't use the one that's always hot or you may come out to a dead battery one day.
MrOrange is online now   Reply With Quote
Old 08-13-2009, 11:20 AM   #17
WaldenL
2009 JK Wrangler
While I agree you should go to the switched circuit, I think you've have to be gone from the jeep for a _long_ time if a couple of LEDs was going to drain your battery.
WaldenL is offline   Reply With Quote
Old 08-13-2009, 01:59 PM   #18
Xtremjeepn
There really is nothing to tricky about it.
I went to Pep-Boys and bought a 3 LED pack for $7.
Drilled holes where I wanted them mounted.
Took a test light to the wires going into the window switches, or maybe it was the heater controls....does not really matter. Either one have a lights for night time use. Find that (+) wire and hook the LED to it. Ground to the ground and they will work with the headlights/headlight switch like stock.
Cole Ford
Xtremjeepn is offline   Reply With Quote
Old 08-13-2009, 03:35 PM   #19
MrOrange
2009 JK Wrangler
It's more of a disclaimer because you never know. I don't want someone to wire up an LED circus inside and then let it turn up to be a final straw for an old battery. When temps were exceeding 105 around here, people were having batteries die on them that were 3+ years old.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
Old 08-13-2009, 07:01 PM   #20
DominicR
2011 JK Wrangler
Originally Posted by Xtremjeepn View Post
I did these in the dash. They are wired to dim with the light dimmer switch. They were like $7 at the autoparts store. They help a LOT!! Just enough light inside to see things on the console, cup holder area.
Did you have to take the face off that pannel to install the lights? Does it just pop off? How difficult is it to do that? Sorry for the rookie questions but that looks amazing and I'm thinking of doing it myself.
Thanks!
DominicR is offline   Reply With Quote
Old 08-14-2009, 12:19 AM   #21
MacK
2010 JK Wrangler
I was thinking of hooking a switch to that outlet, that way you'd have to turn the key on. I'm def. doing this in a few weeks.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline   Reply With Quote
Old 08-14-2009, 01:21 PM   #22
DominicR
2011 JK Wrangler
I found a write up on how to remove the front pannel is anyone needed it.
http://amerustechnology.com/wrangler.html
Old 08-15-2009, 01:45 PM   #23
f1rocco
I just bought these from EBAY.
http://cgi.ebay.com/ebaymotors/Green-9-LED-LIGHT-fit-Jeep-Wrangler-Liberty-Commander_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em 14QQhashZitem3ca01d0487QQitemZ260384294023QQptZMot orsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Hopefully it will look good with my Rescue Green. I Also bought switches which I will be wiring this to.
I'll let you know how it works out.
f1rocco is offline   Reply With Quote
Old 10-04-2009, 09:22 PM   #24
Savage223
2007 TJ Wrangler
I know this is a bit of an old topic, but I'll be installing red, blue, green, yellow, UV, and white diodes around the front compartment. The first will be the floor, mounted under the dash using a custom LED mount and plumber's strapping. (The latter is that roll of cheapo bendy galvanized steel with holes down the entire length in the middle of the width.) The next will be the instrument cluster, very similar to what is shown here. I'm tired of fumbling around at night looking for my Zippo, cell phone, Yuengling Lager, Savage pistol....you know... the essentials.
Edit: Install should take place 10-09 thru 10-11. I'll have pics up as soon as I'm through.
"A nation can survive its fools, and even the ambitious. But it cannot survive treason from within. An enemy at the gates is less formidable, for he is known and carries his banner openly. But the traitor moves amongst those within the gate freely, his sly whispers rustling through all the alleys, heard in the very halls of government itself." Marcus Tullius Cicero
Savage223 is offline   Reply With Quote
Old 10-06-2009, 12:19 PM   #25
Savage223
2007 TJ Wrangler
No, really: with only two cup holders for immediate tactile access, I get tired of looking for stuff in the dark. Now, why all those colors?
Red = General running. Has less negative impact on nighttime vision.
Blue = Almost as good as red for maintaining nighttime driving vision, but you can read topo maps with blue, since the elevation lines are generally in red on the maps I use.
White = Will go on regardless of other selections when dome / door / floor lights come on.
Green = As, or more, bright than White, but like the yellow that also follows, simply for effect.
The green, yellow, and UV (I might not end up using the latter) are basically being added because: (1)I already have them, and (2)Simply for lighting effect.
Because LEDs have such a low current draw, I can leave them on in a parked state. I'm a huge fan of showing everyone what I DON'T have in the car: mysterious envelopes that could contain cash, high end stereos that are more likely to work when ripped off than the stock one, cameras, spot lights, etc. I'd rather someone see that I don't have anything to offer than to cut a hole in my soft top windows to find out. If you use another color other than white, you're also less likely to have a good Samaritan tell you, "Hey, buddy: do you know you left your inside lights on?" It looks more like I tried it.
I don't get off-road, by the way, to the point where I'm blazing trails with the vehicle. The maps are for early morning hunting and for when I hike to do nature photography.
Call me silly, but I'm not spending time, money, and energy on the "bling" of a stereo, amp, and speakers. (Those days are gone until I get through school.) I enjoy doing crap like this, and getting professional results. I've been a Manufacturing Engineer for the past six years, working very often in a machine shop building tooling to support manufacturing processes. I keep swearing I'll do all the neat stuff I've wanted to when I didn't have a machine shop, this is one of those small projects where I can do a bit of that kind of "government work".
Old 10-06-2009, 12:22 PM   #26
MacK
2010 JK Wrangler
I used white lights and love it.
Old 10-08-2009, 11:00 PM   #27
Savage223
2007 TJ Wrangler
Neat stuff coming
Once I had the center dash section apart, I came up with a couple really good ideas. So work is taking a bit longer, but still should be complete by this Sunday.
Old 10-09-2009, 09:22 AM   #28
DominicR
2011 JK Wrangler
Pictures please.
Old 10-09-2009, 06:39 PM   #29
Jazant
2011 JK Wrangler
Originally Posted by DominicR View Post
Pictures please.
where did you tap into for power? I want them to dim, but I don't have power windows, any help????
Jazant is offline   Reply With Quote
Old 10-09-2009, 08:06 PM   #30
Jazant
2011 JK Wrangler
looks good, any idea where I can tap into my dash lights so they will dim? I don't have power windows.
Thanks,
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
