Leaking axel seal - JeepForum.com
post #1 of 3 Old 11-05-2013, 07:58 PM Thread Starter
the_cable_guy
Leaking axel seal
Had my u-joint replaced and had a bit of gear oil coming out the axel tube. Is it possible when the axel was pulled out gear oil seeped into the axel tube and my seals are ok cause it doesn't seem to be leaking anymore and my diff fluid is about a quarter inch below the fill hole.
2003 Jeep TJ Rocky Mountain, 4" Rough Country Lift wit 1" Body Lift SI12000 Mile Marker Winch
the_cable_guy is offline
post #2 of 3 Old 11-05-2013, 09:55 PM
ronjenx
ronjenx's Avatar
Could be residue from the axle removal.
Could have stopped leaking due to low level.
Fill it up to the level of the stock cover's fill hole.
Clean all the residue from the C with brake cleaner.
Drive it and check for evidence of continued leaking.
ronjenx is online now
post #3 of 3 Old 11-06-2013, 07:26 AM
1222
RIP John
1222's Avatar
Could be either but depending on how much leaked out to begin with it is probably just oil that leaked into the tube while the shaft was out. Jacking up the side where the axle was removed could have prevented any oil escaping in the first place.
1222 is offline
