leak - JeepForum.com
post #1 of 9 Old 05-30-2013, 06:28 PM Thread Starter
loveOffroad
leak
2 weeks ago I slammed nose first into a ditch while off road. I just noticed this week that some fluid is slowly leaking out from behind my right wheel.looks like its coming out of the axle maybe and pooling onto the lower spindle. What could this be? All help is much appreciated. I tried attaching a pic but the file was too large
loveOffroad is offline
post #2 of 9 Old 05-30-2013, 06:54 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Diff seal leaking? Did you hit the wheels hard? Bent axle tube?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 9 Old 05-30-2013, 07:14 PM Thread Starter
loveOffroad
I landed hard on the front wheels yes. Some days it leaks and others its dry. Nothing appears bent. Drives perfect, not sure. But it drips onto the inner sidewall of my tire.
post #4 of 9 Old 05-30-2013, 07:15 PM Thread Starter
loveOffroad
Diff isnt leaking
post #5 of 9 Old 05-30-2013, 08:16 PM
222Doc
222Doc's Avatar
you need to know what fluid it is. no one here can guess. How do you know the dif is not leak through the axle seal? From what you have explained it may well be what Rocky is saying. if its gear oil.
If you bent the axle or tube. there could well be other damage. This is a collision.
You need to put your pics on a third party site and link them.
222Doc is offline
post #6 of 9 Old 05-31-2013, 10:07 PM Thread Starter
loveOffroad
I thought u were talking about the diff cover leaking. Its not. Im no mechanic so I cant describe exactly .just I know oil leaks out of the end of the axle and drips onto my tire
post #7 of 9 Old 05-31-2013, 10:12 PM
COLOUXJ
2010 JK Wrangler
Your axle seal sounds like its gone bad. Probably needs to be replaced.
COLOUXJ is offline
post #8 of 9 Old 05-31-2013, 10:33 PM Thread Starter
loveOffroad
Colo after researching online thats the conclusion im coming to. Or I killed the bearings as well
post #9 of 9 Old 07-28-2013, 06:26 PM Thread Starter
loveOffroad
Well. Finally replaced the axle seals. It was confirmed.
