Keyless remote start - JeepForum.com
post #1 of 6 Old 01-12-2014, 09:07 PM Thread Starter
jester116th
So my remote start stopped working. When I hold the sensor down and push the button on the key fob all I hear is a clicking sound over by where the fuse box is. Fuse is good. Any ideas?
Wheels Up Wheelin'!
jester116th is offline
post #2 of 6 Old 01-13-2014, 04:12 AM
Av8terZ06
If youre low on fuel, the remote start doesnt work so you wont run out of fuel. Whats your fuel status?
2012 Jeep Wrangler Unlimited "Call Of Duty"
2007 Corvette Z06
2009 Jeep Wrangler Unlimited Sahara - Sold
1994 Jeep Wrangler Renegade - Sold
Av8terZ06 is offline
post #3 of 6 Old 01-13-2014, 08:44 AM Thread Starter
jester116th
Battery's in key fobs new, in JK good, full thank fuel
Doers closed & locked ect,ect
Wheels Up Wheelin'!
post #4 of 6 Old 01-13-2014, 08:57 AM
Jiblet
More remote start fail reasons:
Low fuel lamp on or at fuel level of telltale lamp on.
Low Voltage below 11 V
High Voltage above 16 V
Key in Ignition
Doors or hood are opened before remote unlock
Hazard Switch depressed
Panic or theft alarm active
Brake applied
A prior remote start cranked the engine , but failed to start the engine
Battery voltage NOT in the normal range
High (run away) or Low Idle (stall) RPM
MIL Active
High Engine Coolant Temperature
Low Engine Oil Pressure
Remote start allows a maximum of two starts per ignition off cycle; cycling the ignition resets
Jiblet is offline
post #5 of 6 Old 01-13-2014, 09:27 AM Thread Starter
jester116th
All that stuffs good. When I push the button x2 it just
Makes a clicking sound from near my fuse box
Wheels Up Wheelin'!
post #6 of 6 Old 01-13-2014, 12:09 PM
Jiblet
Originally Posted by jester116th
All that stuffs good. When I push the button x2 it just Makes a clicking sound from near my fuse box
Maybe a loose connection? Check the hood plunger connections?
Jiblet is offline
