Keyless entry acting up ? What is going on ? - Page 6 - JeepForum.com
post #76 of 105 Old 01-10-2010, 07:45 PM
connie
There are two outlets, one that is wired that is on all the time, the one on the right , the other is on the left.it shuts of with the key, you can use that one for anything because it is off when your trying to use your remote so it works fine. it only effects the remote in the ac outlet on the right that stays on. You don't need your stuff when your not in the vehicle so just switch it or unplug it when you exit the jeep and plug it back in when you get in.
connie is offline
post #77 of 105 Old 01-10-2010, 07:48 PM
carnut08
2017 WK
Correct, except....I don't have anything plugged in and I have exactly the same symptoms you described.
I have remote start. I wonder if you or the others who have remote start are the only ones that are experiencing this issue.
carnut08 is offline
post #78 of 105 Old 01-10-2010, 08:05 PM
PhatJK
2009 JK Wrangler
Don't have remote start or any electrical accessory in the Jeep. This means no CB radio. May be the cell phone and that's it.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #79 of 105 Old 01-12-2010, 11:29 AM
jimmyzwheelz
Ok! ready for this one?? Took the jeep in today, the said that the ionizer that I keep in the ac outlet is interfering with the keyless entry! The remote works when I do not have plugged in and as soon as I plug it in it wont work. They said there are many things that interfere with remotes. So if you have anything plugged in to those such as battery charger for cell phone, I have ionizer to keep the air fresh, I can still use it just not when I want to lock the doors. Let me know if this works for you...
Connie, thank you for this information! Mine was doing the same thing. I unplugged the charger for my iPod and haven't had any trouble since (knock on wood). Most excellent advice to a frustrating situation!
Jimmy
jimmyzwheelz is offline
post #80 of 105 Old 01-12-2010, 02:36 PM
FatBuoy
FatBuoy's Avatar
Originally Posted by jimmyzwheelz View Post
Connie, thank you for this information! Mine was doing the same thing. I unplugged the charger for my iPod and haven't had any trouble sense (knock on wood). Most excellent advice to a frustrating situation!
Jimmy
Yep! Day seven and counting here...
I should still take it to the dealer with the charger plugged in to see if THEY can figure it out... Wish I had the time to burn. Man, if I were retired I would jack with everyone!
Black Rubi JKU with a rompin' stompin' 6.1 magnuson supercharged hemi!
FatBuoy is offline
post #81 of 105 Old 01-12-2010, 04:43 PM
carnut08
2017 WK
Sorry to burst your bubble, but you can go weeks that way and then one day it happens again. Items plugged in may be part of the problem, but I don't have any plugged in and I have the problem.
carnut08 is offline
post #82 of 105 Old 01-12-2010, 04:57 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
I just unplugged my charger and I will see if it happens....
I do have my cb wired into that outlet so I guess we will see...
-Matt
mattman8706 is offline
post #83 of 105 Old 01-21-2010, 08:51 AM
FatBuoy
FatBuoy's Avatar
Two weeks and counting with no hiccups!
FatBuoy is offline
post #84 of 105 Old 01-21-2010, 09:05 AM
jimmyzwheelz
Same here...working great since unplugging the charger! WooHoo!!
Jimmy
post #85 of 105 Old 01-21-2010, 09:32 AM
mattman8706
2009 JK Wrangler
I unplugged the charger from there and it has only done it once since the 12th.
much better than 2 or 3 times a day
-Matt
post #86 of 105 Old 01-21-2010, 09:38 AM
mattman8706
2009 JK Wrangler
right after I posted that I tried to start the jeep and it isn't working
so 2 times since the 12th
boooooooooo
-Matt
post #87 of 105 Old 01-21-2010, 10:09 AM
carnut08
2017 WK
Means nothing. Mine hasn't done it since I first posted. Nothing plugged in now or then. It's totally random. It WILL happen again.
carnut08 is offline
post #88 of 105 Old 01-21-2010, 12:19 PM
FatBuoy
FatBuoy's Avatar
Well MY glass is half FULL!
I told the dealer about it since he got my new module in. He's just going to keep it there with my name on it in case it rears its ugly head again.
FatBuoy is offline
post #89 of 105 Old 01-30-2010, 06:37 PM
carnut08
2017 WK
Just checking in to report that the problem happened again today. Jeep would not respond to my remote. My wife's remote worked fine. Once her remote worked, mine did too.
This has to be a known problem. Too many have reported the same situation.
carnut08 is offline
post #90 of 105 Old 02-10-2010, 08:37 PM
victorgator
I've got the same problem in my '09 Sahara with remote start. Intermittant, with no rhyme or reason when it will happen.
Nothing plugged in to the accessory. It happened twice today. Had to use the key to get in both times with the alarm blaring until I could get the key in the ignition.
victorgator is offline
JK Wrangler , keyless entry , problems , troubleshoot , wrangler
keyless entry on a TJ anyone do it? Bot TJ Wrangler Technical Forum 19 08-29-2010 01:16 PM
Keyless Entry Pad - For remote keyless entry systems ericg JK Wrangler Technical Forum 16 06-04-2009 03:28 PM
Keyless entry....on another JK!! roxy JK Wrangler Technical Forum 9 05-03-2009 09:56 AM
keyless entry bswish247 JK Wrangler Technical Forum 4 05-18-2008 10:02 PM
keyless entry joebruni TJ Wrangler Technical Forum 10 05-19-2006 11:22 AM
