Keyless entry acting up ? What is going on ? - Page 3 - JeepForum.com
post #31 of 105 Old 12-28-2009, 10:15 PM
waterboarder
waterboarder's Avatar
Originally Posted by TJeeper View Post
Wow. That's informative. Unfortunately no dealer in the country will perform warranty work unless they actually see the problem. The whole point of this thread is the problem is intermittent, and can not be replicated in the dealer's lot.
Well, I guess you're screwed then. Good luck!
waterboarder is offline
post #32 of 105 Old 12-28-2009, 10:17 PM
TJeeper
TJeeper's Avatar
Are you actually old enough to drive, or are you just an *sshole?
Patrick
TJeeper is offline
post #33 of 105 Old 12-28-2009, 10:19 PM
waterboarder
Hey, I tried to offer some advice, which you chose to piss on.....so....good luck!
post #34 of 105 Old 12-28-2009, 10:30 PM
TJeeper
TJeeper's Avatar
Your vehicle is not working normally. Make the dealer fix it, or get on with lemon law related activities.
Explain to me what part of what you said is useful advice. Like I said, no dealer will perform warranty work unless they see the problem.
Patrick
TJeeper is offline
post #35 of 105 Old 12-28-2009, 10:33 PM
waterboarder
After post #32? No thanks. Solve your own problem.
If you treat everyone trying to help you with the same attitude, I can see why a dealer isn't going out of its way to help you either.
post #36 of 105 Old 12-29-2009, 04:40 AM
FatBuoy
FatBuoy's Avatar
Oh stop it you two, am I going to have to get your father?
So I took mine to the dealer yesterday. This thread reminder me of how fed up I am and I have off work for a few days. What do you know, it acted up in front of them! He took my key inside the shop somewhere and came out saying the tester they use to see if the key is emitting a signal indicated the key was malfunctioning. I told him it didn't matter which key I used. Sooo...he ordered two new keys that should be in today. I am very skeptical though. It seems that it would be very coincidental that both keys are having this erratic behavior. I expressed my skepticism and he said, "Lets start there. If it's still malfuncioning we will check other areas." Well you know what's going to happen. It will work fine until I get home! Hahaha! I'll keep you all posted.
Black Rubi JKU with a rompin' stompin' 6.1 magnuson supercharged hemi!
FatBuoy is offline
post #37 of 105 Old 12-29-2009, 04:56 AM
connie
Remote keyless entry
The dealer called me back yesterday and said there is documentation with Jeep to replace the antenna on the passenger door. So I am taking the jeep back to the dealer for the 5th time and now having the antenna replaced the is for the RKE.....Let you know what happens. Your right though, it is intermittent, I take it in it the have replaced my keys, my WCM, and now antenna. But as soon as I go to get in it again after leaving the dealer it doesn't work. It did work standing in front of it yesterday.....But then it snowed on the Jeep and it did not work. It is almost like the antenna it not getting the signal. So sick of going back to the dealer. How does that lemon law work? I bought this 2008 with 6400 miles on it 3 weeks ago from a dealer. Still has 2 years of warranty. Does it only apply to new cars? I will have been to the dealer 5 times after today.
connie is offline
post #38 of 105 Old 12-29-2009, 08:36 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
mine is doing the same thing.
someone figure it out because it is so annoying.
-Matt
mattman8706 is offline
post #39 of 105 Old 12-29-2009, 04:13 PM
FatBuoy
FatBuoy's Avatar
So I picked up my two new keys today and they take it in back to program them. He comes out 30 minutes later and says it's the receiver module. I knew it wasn't the friggin keys but you have to let things run their course. New module ordered. I'll update this after it's all installed and programmed. Fingers, toes, nuts crossed...
FatBuoy is offline
post #40 of 105 Old 12-29-2009, 05:56 PM
carnut08
2017 WK
I'm starting to think this is a known bug with no specific cure.
My '09 Rubi started doing it almost from day one. The funny thing is it took me a while to discover that when my key wouldn't work, my wife's would....every time.
Additionally I discovered that once I got in and started the Jeep, my key would work....every time. It would continue to work fine for a while and then the process would repeat.
These things use some sort of rolling code algorythm. Right now my guess is that my key probably gets the buttons pressed in my pocket and perhaps the code rolls to an unexpected code and the Jeep won't respond.
Due to the fact that I've seen so many threads on the subject dating all the way back to 2007, and due to the fact that the solution has yet to be documented, I'm just going to live with the inconvenience for now.
carnut08 is offline
post #41 of 105 Old 12-29-2009, 07:45 PM
connie
Remote Keys Now Workin!!!!
I went to dealer to now have antenna replaced, it did nothing for the problem, so they ripped out the dash to trace the wire it had been located in a area with obstruction and a solder that was preventing it from receiving the signal. It works great now. It is simply the wire placement from the antenna.!!!!!!!!!!
connie is offline
post #42 of 105 Old 12-30-2009, 03:44 AM
FatBuoy
FatBuoy's Avatar
Nice! Now was yours working erratically, or not at all? Mine either works or doesn't. When it works I can be a good distance away and indoors. That leads me to believe it's not an obstruction but a complete malfunction.
FatBuoy is offline
post #43 of 105 Old 12-30-2009, 04:23 AM
rennypogo
Most electrical and electronic problems are results of bad grounds.I would check to make sure I had a good ground on the module.Hope you find your problem.
rennypogo is offline
post #44 of 105 Old 12-30-2009, 04:02 PM
connie
mine was erratic, and from all different distances and depending if the jeep had snow on it or rain, I was crazy.
connie is offline
post #45 of 105 Old 01-01-2010, 12:21 PM Thread Starter
fleck
2009 JK Wrangler
So is it the module?? or the antenna ?? or both ??
Jesus saves
fleck is offline
JK Wrangler , keyless entry , problems , troubleshoot , wrangler
keyless entry on a TJ anyone do it? Bot TJ Wrangler Technical Forum 19 08-29-2010 01:16 PM
Keyless Entry Pad - For remote keyless entry systems ericg JK Wrangler Technical Forum 16 06-04-2009 03:28 PM
Keyless entry....on another JK!! roxy JK Wrangler Technical Forum 9 05-03-2009 09:56 AM
keyless entry bswish247 JK Wrangler Technical Forum 4 05-18-2008 10:02 PM
keyless entry joebruni TJ Wrangler Technical Forum 10 05-19-2006 11:22 AM
