Keyless entry acting up ? What is going on ? - JeepForum.com
post #1 of 105 Old 12-09-2009, 04:43 PM Thread Starter
fleck
2009 JK Wrangler
I have only had our 09 Sahara 2door for a month. Love it !
Anyway we recieved 2 key/remotes with the Jeep. I lock the Jeep with the remote and when I come back to get in.... it will not work..period. I have to unlock it the old fashoin way (hahaha) So I switched keys and the other key is doining it from time to time. ARGH !!
Took the Jeep and both keys to dealership. They tested the keys and said there is nothing wrong with them. But they won't look at the Jeep because there appears to be nothing wrong. Here is the funny part.... They told me to bring it in when it does it again ??? How??? Once I get into the Jeep...start it.. drive it there.... the problem is gone! Everytime it stops working... I manually unlock it, the alarm goes off, I start it, drive home, And it works fine for a couple days.
So basically they told me they can't do nothing unless it repeats this problem while in their possesion.
I know this is not any big mechanical issue, but it is annoying. The keyless is a nice touch when it works. I was just curious if anyone else has had this problem and what did you do to fix it???
Thank you for your time !
Jesus saves
fleck is offline
post #2 of 105 Old 12-09-2009, 04:47 PM
Joe Diver
2009 JK Wrangler
I'd start by replacing the batteries in both fobs.....see if it still happens.
2009 Sahara, Red Rock, auto, MyGig REN, Trac-Lok, remote start, soft top, Nuvi 765T, Escort X50 Blue, Cobra 29WXNW, Firestick II, Recovery Kit, Bestop Bikini Top, Soft Top Cover, Jeep Hood Bra
Joe Diver is offline
post #3 of 105 Old 12-09-2009, 05:24 PM
CGScotty
Straight And To The Point
CGScotty's Avatar
Yup can't go wrong by putting new betteries in.
ɟlǝsʇı ʇnɔ plnoʍ ʇı uǝɥʇ˙˙˙˙˙oɯǝ sɐʍ ssɐɹƃ ʎɯ ɥsıʍ ı
NRA Patron Member
CGScotty is offline
post #4 of 105 Old 12-09-2009, 05:46 PM
NetworkMD
2008 WK
Absolutely agree new battery, and if that does not work ask the dealer to reprogram the fobs to the Jeeps computer. Do you carry both fobs to determine if the issue impacts both of them at the same time?
Good luck, getting this issue resolved.
05 Libby CRD, 08 WK Overland CRD, 07 JK Rubi Green HT Manual, 03 VW TDI
NetworkMD is offline
post #5 of 105 Old 12-09-2009, 06:03 PM
Scooter_Trash
Get a spare key too, you'll need it if you ever need to reprogram the keys. If you loose one, you'll be out some serious cash, so the spare is cheap insurance. But none of this solves your fob prob.
Jeep - Transponder keys for less
Scooter_Trash is offline
post #6 of 105 Old 12-09-2009, 06:53 PM Thread Starter
fleck
2009 JK Wrangler
Thank you for all the suggestions... I will try them all and see what happens !!
Thanks again guys =)
Jesus saves
fleck is offline
post #7 of 105 Old 12-09-2009, 08:06 PM
PhatJK
2009 JK Wrangler
Happend to me a couple of times. Snap opened the back, wiggled the battery, then everything worked fine.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #8 of 105 Old 12-09-2009, 09:07 PM
waterboarder
waterboarder's Avatar
In my experience, the batteries in the FOBs go much more quickly than they should. Replace early, replace often.
waterboarder is offline
post #9 of 105 Old 12-11-2009, 09:56 AM Thread Starter
fleck
2009 JK Wrangler
Well I just spent $5 on 1 battery to see if it was the battery and sure enough............... this did not help So I went and fetched the other remote with the original battery and it worked ?? What the ?!?!!??
So I start the Jeep up and then shut it off. The key with the new battery now works fine ?? It's like the Jeep doesn't want to recongize the key transponders all the time. I acts up when it feels like it.
Can I reprogram them myself or do I have to take to dealership and have them look at me like I crazy again.
Jesus saves
fleck is offline
post #10 of 105 Old 12-11-2009, 11:40 AM
PhatJK
2009 JK Wrangler
having the key your pocket, vibrations, shock from keys slaming onto tables, thermal cycles, moisture build up, etc..., can degrade battery connectors. The spare key is safely stored so everything should be pristine.
ORFAB tire carrier
PhatJK is offline
post #11 of 105 Old 12-11-2009, 01:05 PM
jearnold
Could be the wireless control module which receives the signal from the key remote. Have the dealer reprogram your keys to the wcm. This should take care of the problem.
jearnold is offline
post #12 of 105 Old 12-11-2009, 02:53 PM
TJeeper
TJeeper's Avatar
Mine does this at least once a week. One remote does not work, the other does. Replaced batteries, no help. It is like the computer "forgets" the remote, then remembers it for a week or so and forgets it again. I haven't even bothered taking it to the dealer, I know the run around I would get from them.
It's like the Jeep forgetting the settings I have on the locks. I set it, a month later the settings change. Again, can't prove it to the dealer, so I know I'll just get blown off.
Patrick
TJeeper is offline
post #13 of 105 Old 12-11-2009, 09:11 PM Thread Starter
fleck
2009 JK Wrangler
Amen ! I just know they hate doing any kind of warrenty work !
Jesus saves
fleck is offline
post #14 of 105 Old 12-11-2009, 09:36 PM
waterboarder
I just don't see how that could be. They get paid for warranty work. They don't get paid if you don't bring them something to fix.
post #15 of 105 Old 12-12-2009, 04:53 PM
PhatJK
2009 JK Wrangler
Happened again today! Cleaned the battery and it worked again. Still use the same battery that came with the key.
ORFAB tire carrier
PhatJK is offline
JK Wrangler , keyless entry , problems , troubleshoot , wrangler
keyless entry on a TJ anyone do it? Bot TJ Wrangler Technical Forum 19 08-29-2010 01:16 PM
Keyless Entry Pad - For remote keyless entry systems ericg JK Wrangler Technical Forum 16 06-04-2009 03:28 PM
Keyless entry....on another JK!! roxy JK Wrangler Technical Forum 9 05-03-2009 09:56 AM
keyless entry bswish247 JK Wrangler Technical Forum 4 05-18-2008 10:02 PM
keyless entry joebruni TJ Wrangler Technical Forum 10 05-19-2006 11:22 AM
