Quantcast KC Slims won't tighten - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > KC Slims won't tighten
Old 02-06-2009, 09:53 PM   #1
spillz
spillz's Avatar
Hi everyone, well for being an easy installation I'm getting my rear end handed to me. I installed the first KC Slimlite and tighten in down, but after a really snugged it down it still is not secure. The light still moves from side to side...is this normal or is it suppose to be tight where it wont move? If so, I cant get it tight enough....any suggestions.....
spillz is offline   Reply With Quote
Old 02-06-2009, 09:55 PM   #2
whiteguyjames
Yeah they aren't supposed to move, lol. I can't imagine how they wouldn't tighten. It's just 3 bolts... the two on the sides and the one on the bottom. If it's just one that won't tighten then I'm guessing it's a problem with the threads. If both won't, then I'm guessing you're just doing it wrong.
2006 X
whiteguyjames is offline   Reply With Quote
Old 02-06-2009, 10:21 PM   #3
OregonVette
Location: peoplez socialist portland Estados Unidos de América
post some pictures to better explain. aka "we can't come get you if we don't know where you are at."
OregonVette is offline   Reply With Quote
Old 02-07-2009, 12:07 AM   #4
WVUJeeper
I had to tighten my bottom nut enough to bascially flatten the lock-washer. I tried it without smashing the living bejesus out of it, but it kept wiggling in the wind and everything. Annoyed me to no end, so I squished it. Did the same on the sides because they would tilt back at highway speeds.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread: HERE
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline   Reply With Quote
Old 02-07-2009, 08:22 AM   #5
sean2857
they're supposed to move. not alot, but enough so you can adjust them. unless you get out and move them by hand, then they should be stationary.
sean2857 is offline   Reply With Quote
Old 02-07-2009, 10:17 AM   #6
1222
Make mine a Jeep!
1222's Avatar
Lock washers are supposed to be squished. If they are not flat, then they are not tight.
1222 is online now   Reply With Quote
Old 02-07-2009, 11:16 AM   #7
JeeperSC
I had to tighten my bottom nut enough to bascially flatten the lock-washer. I tried it without smashing the living bejesus out of it, .
Wait, so you didnt tighten the screws all the way? If not, then of course the lights are going to have play because they are not tightened down.
2008 Wrangler Unlimited-X 4x4
Steel Blue Metallic
JeeperSC is online now   Reply With Quote
Old 02-10-2009, 10:26 AM   #8
WVUJeeper
Wow...now I feel real dumb. I always was under the impression that lock washers didn't need to be tightened all the way to work correctly. No one ever told me, I just sort of thought if you flattened them, then they became just like any other washer. Thanks though.
Old 02-10-2009, 11:58 AM   #9
spillz
spillz's Avatar
yes and an engineer can prove that 1+1 does not equal 2
Old 02-10-2009, 01:00 PM   #10
WVUJeeper
Chemical Engineer here...all I can do is make moonshine, and did in my college apt.
Old 02-10-2009, 01:04 PM   #11
spillz
spillz's Avatar
well you are from West Virginia
Old 02-10-2009, 06:45 PM   #12
Swagger
I believe that V has a stem on it .....making it a Y. Looks like Wyoming to me there HOSS!
Swagger is offline   Reply With Quote
Old 02-10-2009, 09:12 PM   #13
WVUJeeper
West Virginia born and raised.... Moved to Wyoming last June.
Old 02-11-2009, 07:40 AM   #14
Swagger
LOL! My Badd! That's what I get for butting in huh! I looked at your profile and seen the WY. Thouhgt "spillz" must need glasses like me.
Glock Forum
