KC lights not even? - JeepForum.com
post #1 of 20 Old 03-25-2012, 05:35 PM Thread Starter
goldenglory18
All, does this look normal?
I installed the KC slimlites on the windshield yesterday and while trying to adjust the pattern, I noticed one lamp is putting out a much larger beam than the other. Like, significantly larger. These are the longrange units.
Glass is the same, part numbers on the housings are the same. I'm racking my brain here and dont know what's going on.
Thoughts?
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
post #2 of 20 Old 03-25-2012, 05:42 PM
wwch99tj
I would email kc hilights they will make it right, maybe include that pic
They don't look right to me
wwch99tj is offline
post #3 of 20 Old 03-25-2012, 06:50 PM
SubAtomicGenius
2011 JK Wrangler
Eliminating install issues: what gauge wire are you using on the lights? I'd check the voltages right at the light with a multimeter. You may be suffering from a voltage drop across the longer wire lead. If so, you might have to use a heavier-gauge wire on the longer lead. Either that or the bulbs are different or the bulbs are sat in either reflector differently. Let us know what you find out!!!!
SubAtomicGenius is offline
post #4 of 20 Old 03-25-2012, 07:53 PM Thread Starter
goldenglory18
I used the stock wiring kit from KC. "Off" light is the shorter of the two (passenger side.)
I definitely think its a bulb or light specific issue. I'm going take the jeep to a isolated area tonight and play around with the pattern. Either way, ill let you guys know what KC says...
post #5 of 20 Old 03-25-2012, 08:05 PM
SubAtomicGenius
2011 JK Wrangler
Ok, manufacturer's harness and short lead. Still could be a high resistance from a bad crimp or connection. Interested to find out what the issue is. Keep us posted.
post #6 of 20 Old 03-25-2012, 09:33 PM
DrHolliday
2011 JK Wrangler
Looks like someone messed up and put a spot lit into a flood or vice versa.
Anyone else notice the eye that shows in the large light's reflection?
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #7 of 20 Old 03-25-2012, 11:32 PM
HappyTrails
HappyTrails's Avatar
Yes, that's eerie!
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #8 of 20 Old 03-25-2012, 11:32 PM
smcutter
Yeah. Instantly reminded me of the Indiana Jones ride at Disneyland.
(kudos to anyone who gets that one...)
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #9 of 20 Old 03-26-2012, 01:00 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
If I remember right the bulb snaps into the back of the reflector/lens just like a headlight does. I would guess that the bulb is not snapped in all the way or that it is crooked in the reflector.
The effect that is showing in your picture is like that of a mag-light when you turn the front to get their "flood" pattern!
Good luck with the fix
Jim
JLC08JK is offline
post #10 of 20 Old 03-26-2012, 07:58 AM Thread Starter
goldenglory18
So which one looks correct? The one on the left?
post #11 of 20 Old 03-26-2012, 03:06 PM Thread Starter
goldenglory18
Email sent to KC. I'll let you guys know what they say....
post #12 of 20 Old 03-26-2012, 03:08 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
The bricks on the right side were not fully sealed so they are absorbing the light...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #13 of 20 Old 03-26-2012, 04:12 PM Thread Starter
goldenglory18
post #14 of 20 Old 03-26-2012, 06:05 PM
JLC08JK
JLC08JK's Avatar
My long-range Dayilghters have a very narrow beam such as the one shining on the right. I would say that the one on the left needs the attention.
Jim
JLC08JK is offline
post #15 of 20 Old 03-26-2012, 07:18 PM
1997YoungJeeper
the eye is creepy!
1997YoungJeeper is offline
