K&n air & oil filters... - JeepForum.com
post #1 of 23 Old 02-24-2008, 05:24 AM Thread Starter
2442george
curious how many are running either of these and if there was any significant gains in mpg's or performance.i have a friend who swears the air filter will improve gas mileage.
2442george is offline
post #2 of 23 Old 02-24-2008, 05:51 AM
Grant211
i have the K&N air filter in mine. I might of got 1/2 better mpg. I just bought it as my jeeps stock filter was getting kinda dirty and I figured why not get the K&N.
2007 JK Unlimited Sahara
2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc...
Grant211 is offline
post #3 of 23 Old 02-24-2008, 08:03 AM
RussK
I have heard those more expensive oil filters aren't much better than lets say a WIX as long as you change them every 3K miles, if they're that free flowing they're not catching the bad stuff.
The air filter on the other hand is different at least on my previous vehicles. I haven't done mine yet on the 07 but I want to go with the whole intake and not just the filter.
RussK is offline
post #4 of 23 Old 02-24-2008, 08:10 AM
BigJerm
i run both filters. Not sure of gains but when it was time to change the stock ones i went with K&N. Ive always used the filters, never had problems with them. I change my oil every 3k and the 1" wrench fitting on the end of the k&N makes things really easy.
07 Jeep Wrangler Unlimited Rubicon
BigJerm is offline
post #5 of 23 Old 02-24-2008, 01:07 PM
waterboarder
waterboarder's Avatar
I have one. No gains in performance or mileage. I use it because it's a quality filter.
waterboarder is offline
post #6 of 23 Old 02-24-2008, 06:59 PM
XpensiveWino
I have a drop in K&N air filter. I noticed about 1 to 1+ mpg better than stock.
I took out the K&n for a week and noticed the difference in MPG. Call me crazy.
XpensiveWino is offline
post #7 of 23 Old 02-25-2008, 10:59 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
^You're crazy. Not really a scientific test, either.
A stock air filter will flow far more air than your engine can use. Since this is a proven fact, that means there is no way there can be a gain by simply changing an air filter. No HP, no mileage. And even if there was...is .5-1mpg that people claim worth allowing dirt into your engine?
Plus, a stock filter is FAR superior at filtration.
K&N's are notorious for letting dirt into engines.
Ask any reputable engine builder and he'll tell you that he can tell by the wear that an engine had a K&N or other oiled filter.
Cost...A K&N is 40+bucks. Precharger to go on it is another 20..and you need this to even get close to stock filtration ability.
Plus the oil to "recharge" the filter. So you'll have a solid 75 bucks in a K&N setup....how many stock filters that do a better job can you buy for that?
You'll have lots of fanboys who believe the K&N hype come in here and argue against me, but isn't that always the case.....
Pacfanweb is offline
post #8 of 23 Old 02-25-2008, 04:44 PM
RussK
In my last post I said I noticed a difference but in my last vehicle that my k&n was on was a 96 dakota with a 318 in it. When I put the filter in I also changed the exhaust. So it did help.
If your letting more in it doesn't help enough to notice unless you allow your engine to let it out just as fast. That is the only way that I know it will make a difference.
This what I hear I haven't done any dyno's on it though.
RussK is offline
post #9 of 23 Old 02-25-2008, 05:09 PM
waterboarder
I get K&N oil filters for about $12 AT Shucks...
post #10 of 23 Old 02-25-2008, 05:22 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I was talking about air filters. Nothing wrong with K&N oil filters, other than they are overkill. An OEM oil filter is better than most anything out there, but I'll grant that K&N oil filters are a bit better than OEM's.
post #11 of 23 Old 02-25-2008, 05:25 PM
waterboarder
overkill...based on what? makes the oil too clean or what?
post #12 of 23 Old 02-25-2008, 05:26 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
But the truth is, the factory air filter will let more air in than your engine can possibly ingest, regardless of what mods you make to it....unless you're talking several hundred horsepower's worth of mods.
And since the air filter is not a restriction in the first place, making it flow more won't help anything. Helping the exhaust flow better certainly will help, but it would have helped whether you put a K&N in there or not.
post #13 of 23 Old 02-25-2008, 05:28 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Based on the OEM filter already cleans the oil plenty. You can't get any cleaner than clean.
But I can see if you're worried about your oil using a better filter.....personally, I'm not, as cars regularly go hundreds of thousands of miles using OEM filters, but at least there is a measurable difference (small as it may be) between these oil filters.
I guess if you're going to run a K&N air filter and allow all that extras dirt into your engine, it stands to reason that you might need a K&N oil filter to get that extra dirt out of the oil.
post #14 of 23 Old 02-25-2008, 05:34 PM
waterboarder
In an extremely cold environment (it was -70F up here a few weeks ago), it's good to do anything possible to keep one's oil happy.
I don't have a K&N air filter.
post #15 of 23 Old 02-25-2008, 06:04 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
Let's talk about chips/power programmers next.
- Bill (formerly VetteDriver)
ChicagoGuy is offline
Air filters bassin JK Wrangler Technical Forum 8 01-28-2010 05:57 AM
Best OEM Air filters? defleppardsg TJ Wrangler Technical Forum 7 01-28-2009 01:37 AM
What oil filters? SDDAVE TJ Wrangler Technical Forum 83 10-04-2008 05:54 PM
K & N air filters tigers34 JK Wrangler Technical Forum 16 07-24-2008 06:59 AM
Do k & n filters stop as much dirt as paper filters ? magnum629 TJ Wrangler Technical Forum 7 12-17-2006 03:06 PM
