Just Ordered TF 2.5" Coil/Shocks Lift...CAM Bolts? - Page 2 - JeepForum.com
post #16 of 20 Old 05-21-2010, 02:03 PM
MilitaryJK4455
2010 JK Wrangler
Im probably going to get flamed for this but Im on 4 inches of lift and I did not even install the cam bolts... I have no driveline vibes and my DS does not rub.... I really dont think they are necessary.
MilitaryJK4455 is offline
post #17 of 20 Old 05-21-2010, 03:13 PM
DeepSky
Did the RC lift you got come with replacement static LCAs?
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #18 of 20 Old 05-21-2010, 03:29 PM
MilitaryJK4455
2010 JK Wrangler
Yeah. Why? They are the same length as the stockers though.
post #19 of 20 Old 05-21-2010, 04:12 PM
DeepSky
Ah, never mind.
DeepSky is offline
post #20 of 20 Old 05-21-2010, 10:11 PM
JKommuter
2009 JK Wrangler
Originally Posted by PlaHrd View Post
Nice! Let me know how much (if any) you had to adjust the castor, and how you like the ride on the road
I installed my 2.5" tf coil lift, TF adj front trackbar, and TF front Lower control arms. Did it by myself in my garage, and it took 7 hours. Using the dial angle finder I checked my caster before I started and I was at 4.5 degrees. I used the adjustable lower control arms to set the caster at 5 degrees.
I didn't drive it until everything was installed and torqued to spec so I can't tell you if I would have been fine on the stock LCA's or not. What I can tell you is that it drives great with the lift installed, and the lca's set where they are. The steering isn't light or darty at all, the ride is firmer, not harsh, but firmer.
So far I'm very happy with my lift, but I've only ran 3 or 4 errands. I like the jeep on stock 32's, so no rush to upgrade yet.
Good luck with your lift, I think you will be happy.
JKommuter is offline
Longer shocks with 1" coil spacer? Woodenya TJ Wrangler Technical Forum 16 04-02-2010 08:52 AM
coil-over shocks?! do i need a new lift? cmandes13 TJ Wrangler Technical Forum 5 06-19-2009 03:40 PM
Shocks to use with Teraflex 2.5" Coil lift? vanner77 JK Wrangler Technical Forum 3 06-13-2009 11:45 AM
Anyone have the BDS 2" coil lift with shocks jake97jeep TJ Wrangler Technical Forum 30 11-20-2006 08:36 PM
can 2" coil spacers be used with oem shocks cybiker123 TJ Wrangler Technical Forum 2 02-09-2004 01:37 AM
