Just Ordered TF 2.5" Coil/Shocks Lift...CAM Bolts? - JeepForum.com
post #1 of 20 Old 05-20-2010, 08:46 AM Thread Starter
PlaHrd
2010 Sahara Unlimited...
Takin the plunge, ordered the TF 2.5 inch coil/shocks kit plus JKS disco's.
Havin a local shop do the install, a guy who has done 100's of jeep lifts. He said I didn't need anything but the TF Kit (did agree with me on the sway bar disco's), asked him about LCA's, front/rear adjustable track bars, he said not necessary.
Asked him how he will set Castor, and he will use cam bolts...
I brought up how I'd read a lot of negative comments about cam bolts on internet forums, he says only problem he has ever seen with cam bolts is if they are not tightened enough.
Question: Do you agree? I don't need adj trackbars, LCA's, he puts on the cam bolts correctly, I will be fine?
Thx in advance, want to do this the right way
PlaHrd is offline
post #2 of 20 Old 05-20-2010, 09:41 AM
JKommuter
2009 JK Wrangler
If I was a bettin man I would bet most responses are going to say stay away from cam bolts.
I will be installing the same lift on my Unlimited tomorrow with Teraflex LCA's and a Teraflex front adjustable track bar.
JKommuter is offline
post #3 of 20 Old 05-20-2010, 10:32 AM Thread Starter
PlaHrd
Nice! Let me know how much (if any) you had to adjust the castor, and how you like the ride on the road
PlaHrd is offline
post #4 of 20 Old 05-20-2010, 10:51 AM
PIG
Your guy is correct... As long as they are on tight you'll be good to go.
Modifying the factory lower control arm can be tricky though. Here is a link to a tool that is VERY useful.
CAM BOLT KNOCK OUT TOOL
www.SynergyMfg.com
PIG is offline
post #5 of 20 Old 05-20-2010, 01:24 PM
aristobrat
2010 JK Wrangler
Some friends and I installed the TF 2.5 coil lift on my '10 JKU two weekends ago. I also bought some TF LCAs but haven't installed them. A few other JKUs in a local club running the TF 2.5 coil lift and nothing else, either.
Based on how well its felt driving around town, on the highway, and the light offloading that i've done, I'm thinking about about selling the front LCAs instead of installing them.
It's a tough call. It's like they're required to do a proper job, but the "improper" job I did seems like it has no problems???
aristobrat is offline
post #6 of 20 Old 05-20-2010, 03:02 PM Thread Starter
PlaHrd
So is the main purpose of the LCAs to be able to reset castor angle to optimal settings after a lift? Is it that for the TF 2.5" lift castor angle doesn't really change significantly?
PlaHrd is offline
post #7 of 20 Old 05-20-2010, 03:17 PM
DeepSky
Yeah I didn't think you really needed to adjust your castor with 2.5" of lift, at least it wouldn't make a big enough difference to warrant buying adjustable LCA's.
My advice would be to lift it w/o readjusting your castor and see how you like how the front end handles. If you don't like how the front end handles I would just go with the cam bolts as they're a lot cheaper and you probably wouldn't need the range of adjustment that LCA's would give you.
FWIW I was able to get another +1.4* using cam bolts and I've been on several off roading trips since with no issue.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #8 of 20 Old 05-20-2010, 05:05 PM
aristobrat
2010 JK Wrangler
That's exactly how I understand it, but I'm totally new at this...
post #9 of 20 Old 05-20-2010, 09:03 PM
1222
RIP John
1222's Avatar
Iím sure cam bolts work just fine if tightened correctly. But if they were to loosen up a bit they could, over time, wallow out the slot and therefore cause a whole lot hurt to fix it. Later down the road if you decide to go higher and want LACAís your kinda screwed until you fix the slots for the cam bolts. Sure, adj. control arms will cost you more but if you were to buy the knockout tool, which will cost you $100 plus, it kinda makes buying ACAís not such a bad deal after all.
(2011-2016)
1222 is offline
post #10 of 20 Old 05-21-2010, 09:30 AM
DeepSky
Originally Posted by 1222 View Post
Later down the road if you decide to go higher and want LACA’s your kinda screwed until you fix the slots for the cam bolts.
Unless I'm missing something you should be able to just continue to use the cam bolts rather than the normal ones. This is what I was planning to do if I ever needed to replace my LCA's and decided to go adjustable.
DeepSky is offline
post #11 of 20 Old 05-21-2010, 11:11 AM Thread Starter
PlaHrd
Sounds good on cam bolts vs. stock LCA's vs. replacement LCA's
I notice a lot of people seem to replace stock trackbar with adj trackball when putting on the TF 2.5". What does that bring to the party? Is it likely needed for the TF 2.5", or is it something that you put on in case you go a higher lift in the future?
PlaHrd is offline
post #12 of 20 Old 05-21-2010, 11:22 AM
DeepSky
At 2.5" it seems like its personal preference. The adjustable trackbars (if you do the front you're going to want to do the rear) will allow you to center the body over the axles.
Even though a lot of people said they didn't bother with them on their TJ's after I put the 2.5" lift on my TJ the body was so uncentered it just looked awkward and I ended up installing front and rear adjustable trackbars.
My advice, get the lift installed and then take a good hard look at how far the tire sticks out from under the fender flair on both sides and front and back. If the look bothers you then go ahead and invest in some adjustable TBs.
DeepSky is offline
post #13 of 20 Old 05-21-2010, 11:22 AM
riverzendz
Cam bolts are fine if that's what you want to do but if you ever want to replace with adj. CA's there is some work that will need to be done.
It brings the adjustment you may need to recenter your axle. A track bar bracket and stock track bar can do the same job but you'll want to research that.
The concern with the adjustable track bar and the 2.5" lift is that the track bar may not be short enough which is where the bracket + stock track bar can come in. Depends on brand and how far out of center your axle is.
riverzendz is offline
post #14 of 20 Old 05-21-2010, 11:44 AM
1222
RIP John
1222's Avatar
Well Iím by no means an expert when it comes to front suspensions but I was thinking that youíre kinda limited as far as adjustment goes with the cam bolts. On my 3.5 lift witch netted me a little over 4-inches I used TeraFlex FLCA and have the joints screwed all the way in. I think I still need just a bit more adjustment but have non-left so Iíll have to get some uppers. So, I was under the assumption that the higher you lift it the more youíll need to adjust. Hope I didnít give any wrong advice.
(2011-2016)
1222 is offline
post #15 of 20 Old 05-21-2010, 02:07 PM
DeepSky
Well I’m by no means an expert when it comes to front suspensions but I was thinking that you’re kinda limited as far as adjustment goes with the cam bolts. On my 3.5 lift witch netted me a little over 4-inches I used TeraFlex FLCA and have the joints screwed all the way in. I think I still need just a bit more adjustment but have non-left so I’ll have to get some uppers. So, I was under the assumption that the higher you lift it the more you’ll need to adjust. Hope I didn’t give any wrong advice.
Oh no, not at all. I probably should have included in my post that I'm already running the longer Skyjacker LCA's that came with the kit. It's probably because I already have longer LCA's that the cam bolts were enough to get my castor to where it needed to be. I was only taking a guess that cam bolts would give you enough adjustment to accommodate 2.5" of lift.
Out of curiosity, how much castor are you running?
DeepSky is offline
Longer shocks with 1" coil spacer? Woodenya TJ Wrangler Technical Forum 16 04-02-2010 09:52 AM
coil-over shocks?! do i need a new lift? cmandes13 TJ Wrangler Technical Forum 5 06-19-2009 04:40 PM
Shocks to use with Teraflex 2.5" Coil lift? vanner77 JK Wrangler Technical Forum 3 06-13-2009 12:45 PM
Anyone have the BDS 2" coil lift with shocks jake97jeep TJ Wrangler Technical Forum 30 11-20-2006 09:36 PM
can 2" coil spacers be used with oem shocks cybiker123 TJ Wrangler Technical Forum 2 02-09-2004 02:37 AM
