Went on a trip this weekend and was the first time I have used 35's while towing our 3,500 lb travel trailer... Must say I am impressed... The ride was a lot better than with the stock wheel/tire combo but there was a slight lack of power... It still took 3 miles of 6% grade okay as I was heating up to 235-240 degrees at 55-60 mph... It was 70 degrees outside....
If I am going to go into the passes again on 35's I will likely regear before I go again or put stock tires back on... If you don't plan to hit any big hills, keep the 35's on...
