JKU springs... - JeepForum.com
post #1 of 11 Old 05-31-2012, 04:39 PM Thread Starter
FaaipdeOiad
My lady just got a '11 JK and I want to lift it. Looking @ JKU take offs. What should I pay for a set or expect to pay? I was told to make an offer. They're at a local shop left over from a lift job. Person didn't want them I guess...
Any insight would be appreciated.
FaaipdeOiad is offline
post #2 of 11 Old 05-31-2012, 04:49 PM
LVCapo
2015 JK Wrangler
What size springs do you currently have, and what size are the takeoffs?
Maybe offer the guy lunch, or maybe $50....because most shops just throw them in the trash. I got mine for free from the local 4Wheel Parts, they had just done a lift and tossed them in the trash (I spend a lot of money there).
Having said that people are paying $150-225 for the takeoff springs and shocks on EBay and Craigslist, but those are for the 19/60 springs that are hard to find.
LVCapo is offline
post #3 of 11 Old 05-31-2012, 06:58 PM
ljrubitm
2011 JK Wrangler
How much do you want to lift it? With the 19/60 springs you could get 1-1/2'' maybe 2''
ljrubitm is offline
post #4 of 11 Old 05-31-2012, 07:18 PM
LVCapo
2015 JK Wrangler
A good rule of thumb is for each number you go up you add 1/4" in height. I want from 14 to17 and got exactly 3/4". Having said that, if you have 14s and install 19s you should get 1.25" of lift from the new springs alone....just make sure you also upgrade your shocks.
LVCapo is offline
post #5 of 11 Old 05-31-2012, 10:58 PM Thread Starter
FaaipdeOiad
Ok, so I own a WJ and I'm new to the JK world. She drives the wrangler. So if you could explain the spring numbers to me that'd be awesome. I assume that is the lenght of the spring...? The more info I recieve the better off I'll be. I like learning all that I can!
Thanks
post #6 of 11 Old 05-31-2012, 11:02 PM
DrHolliday
2011 JK Wrangler
The sock springs have a tag on them. The last 2 numbers are the numbers they are referring to. the higher the number the stiffer the spring. 19 is the highest in the front and 60 is the highest in the back.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #7 of 11 Old 05-31-2012, 11:12 PM Thread Starter
FaaipdeOiad
Thanks. Now will the stiffer spring screw the ride it has now? Because the ride is nice and Idk if she'll go for a more bumpy travel.
post #8 of 11 Old 05-31-2012, 11:28 PM
LVCapo
2015 JK Wrangler
Nope, the ride will still be stock, and feel exactly the same. Keep in mind that if you install bigger springs that will you will want to upgrade the shocks, because the added spring height will eat into the shock travel. Your shocks are also numbered (they have a sticker as opposed to tags), so if you find stiffer springs, see if you can get the stock shocks that came with them.
Ideally you will be looking for a JKU with the towing package or a JKU Rubicon....those stock springs and shocks seem to be ideal.
Not the best picture, sorry.... you are looking for the last two numbers before that letter combo at the end
LVCapo is offline
post #9 of 11 Old 06-01-2012, 11:02 AM
lowendrider
2011 JK Wrangler
For what its worth, I paid $40 for a front pair of 17s off ebay..like new takeoffs from a 2012. I also got four rubicon shocks like new for $100. Went from 14s to the 17s on the front to prepare for a bumper/winch combo. Made a noticable difference in leveling it out..maybe even a touch higher in front now. It should be perfect when the new parts go on. I was afraid the ride would be harsher but its great...loving the rubi shocks.
lowendrider is offline
post #10 of 11 Old 06-01-2012, 11:11 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Sold mine for $50 plus shipping, IIRC (19/60s). All depends upon what's out there right now. Good luck in your search
Mol is offline
post #11 of 11 Old 06-01-2012, 12:48 PM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
I have a set of 4 springs + 4 shocks all with 7k miles from a 2010 JKU Rubicon.
$150 - includes ground shipping to the lower 48. PM if interested.
PhatBasturd is offline
