JKU rear seat question - Page 3 - JeepForum.com
post #31 of 39 Old 06-03-2011, 07:16 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
2008 jkur, and also useless, split foam (covered in black spray paint )
Mol is offline
post #32 of 39 Old 06-03-2011, 08:29 AM
Vin
Originally Posted by nyrangersfan19 View Post
With all due respect to a fellow Jeeper, maybe you should have made sure everything would suit your family's needs BEFORE you wrote a $28,000 check.
There are some expectations that should be met. If there is a 3rd set of seat belts, you would think a third person would be able to sit there.
Vin is offline
post #33 of 39 Old 06-28-2011, 07:09 PM
mexpiper
Easy fix for back seat. 7'' x 9'' 5/8 plywood board tucked under (between foam and wire support) and 2 screws to prevent from moving.
mexpiper is offline
post #34 of 39 Old 06-28-2011, 07:21 PM
deerassassin22
2011 JK Wrangler
I have yet to check my JEEP but I propose the following. The seat is probably not as rigid as the sides do to the HUMP in the center of the floor so when the seat folds down it forms around this spot allowing the seats to fold generally flat for more space and ease of use. With to stiff a seat the springs will not allow sufficient flex if they are to stiff and would not allow the seat to fold. After editing my post I realize somebody already stated this sorry. Also if you modify this with a board or brace it into the other seat you then must drop both seats because they are fixed to each other instead of just dropping 1 side for example. I do like to modify my JEEP and can see spending a big chunk of cash should check all aspects before spending $$ but also JEEP should have built this better just shoot them and email and let them know Engineers and Builders can't think of every thing all the time they use comments to better themselves and fix problems.
Cobra 29 CB, 4ft Firestick Antenna, Skid Row Evap Skid, Rockhard Engine Skid, Rockhard Tranny Skid, Mesh Grill Mod, Mastercraft Grab Handles, Front and Rear ARB Diff Covers, Smittybilt Rock Rails, KC 130Watt Long Range Lights, Delta Light Mounts, TorqFlo tranny cooler, Hood Louvers, Drake Hood Pins, AEV Snorkel, Smittybilt 10,000 Winch, Rockhard Shorty Bumper with KC 100watt Slim Light Driving Lights, JKS ACOS Front System, Breather Extensions.
deerassassin22 is offline
post #35 of 39 Old 01-28-2013, 07:51 AM Thread Starter
WXman
As usual...the aftermarket comes to the rescue and saves Chrysler's craptastic engineering. Now, why couldn't they do this at the factory and raise the MSRP $0.75 cents? Geez.
http://www.armoredworks.com/metalclo...at-Support.pdf
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #36 of 39 Old 01-28-2013, 08:09 AM
Filthy-Beast
Just got the email from MetalCloak they have a video posted. http://www.metalcloak.com/JK-Wrangle...ort-p/5000.htm
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #37 of 39 Old 01-28-2013, 08:16 AM
toxicwaste29
Mine is a 2012 and its the same thing, no support for the middle seat.
toxicwaste29 is offline
post #38 of 39 Old 01-28-2013, 02:47 PM
Mol
Mol's Avatar
Nice. That's a super simple design....anybody with a drill, grinder, and the ability to cut, or have cut, a flat piece of plate could make it for a few dollars.
I'm going to go ahead and make one tomorrow, I think. Thanks for sharing!
Mol is offline
post #39 of 39 Old 01-28-2013, 06:53 PM
dalearyous
is this still true in 2013? if so, i see why people have made threads about a mod to fix the seat and i will be doing the same.
dalearyous is offline
Rear seat question Colbruski TJ Wrangler Technical Forum 6 09-06-2010 11:42 PM
rear seat question deaconjeep YJ Wrangler Technical Forum 8 04-06-2010 07:22 AM
'99 TJ rear seat question... usetobejeeper TJ Wrangler Technical Forum 3 05-28-2009 10:11 AM
TJ Rear Seat Question Exerdoc TJ Wrangler Technical Forum 5 07-08-2008 03:08 PM
Best Top/Rear Seat question MuahMan TJ Wrangler Technical Forum 3 06-18-2007 03:52 PM
