JKU 37"s 2.5 spring lift. rubbing HARD - JeepForum.com
post #1 of 27 Old 09-16-2013, 12:20 PM Thread Starter
Kmin
So about 2 weeks ago I put on a set of 37" KM2s on my JKU (stock wheels). It is lifted 2.5" on a rough country spring lift with the rough country shocks. I also installed bushwacker flat fenders and 1.5" wheel spacers. I also have trimmed the pinch seam.
I went to the Silver Lake Sand Dunes last weekend and with a trailer and weight noticed that I started to rub the fender right above where I trimmed the pinch seam. It rubbed the entire trip and when i got home and took the trailer off, it still rubbed even on the slightest turns and small bumps on the road.
What is my best resolve for this?
I figured order some new shocks and maybe lift it another 2" with a spacer kit
2013 JKU
- 2.5" Rough Country Spring Lift
- Smittybilt XRC Stinger Front Bumper
- Smittybilt CRES Cargo Net
Kmin is offline
post #2 of 27 Old 09-16-2013, 12:25 PM
Filthy-Beast
Neither of those will help when you flex, you'll still stuff the tire into it. I'd say you need to cut more or install bigger bump stops.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #3 of 27 Old 09-16-2013, 12:25 PM
duneslider
You could get longer rear arms and push the back axle back a little to clear? You could lift it a little more but you will need longer/taller bumpstops or it will keep happening.
duneslider is offline
post #4 of 27 Old 09-16-2013, 12:47 PM
HappyTrails
HappyTrails's Avatar
I cut my front pinch seam about 3" forward, and up about 2.5".
Then I trimmed the rear pinch seam about 1" rearward, and up about 3".
Absolutely no rubbing on the pinch seams.
And I can stuff those babies into the wheel wells!
I'm running 2" bumpstops in front, and 3" in the rear.
37's, RK 2.5" Max Travel lift.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #5 of 27 Old 09-16-2013, 01:12 PM
rock-rocker
What you do all depends on how deep your pockets are. As mentioned the cheapest way to stop the rubbing would be to install longer bumper stops to prevent your tire from being stuffed so far up but then again you mentioned you were rubbing when you were towing and after you disconnected the trailer. I can understand rubbing while you are towing because the trailer (depending on weight) is pulling the rear down but rubbing when not towing? Maybe because the plastic fender is pulled down closer to the tire due to the damage?? Were you rubbing before towing??
Sure, another 2" of suspension with new shocks would take care of the rubbing problem (most probably) but now your looking at 4.5" of total lift which I believe you'll run into more money for more mod's. Stuffing 37's under there is not a cheap thing to do IMO and not only that your pushing the lmits of your axle integrity/strength. I didn't look at your profile closely but I hope those axles are 44's but I do remember you mentioning your gearing is 3:21? WOW, with those tires and towing you must be in a flat land area. I know this hasn't helped you out much but do alot of homework so that it doesn't get to be an expensive nightmare without you expecting it. Towing with 37's and 2.5" lift with 3:21's, hmmmm I gotta go drink a beer...
BTCS, USN, Retired
2013 Jeep JKU Rubicon 10th Year Anniversary.
rock-rocker is offline
post #6 of 27 Old 09-16-2013, 01:22 PM Thread Starter
Kmin
I rubbed a little before the trailing but that was only taking sharp turns. It became much worse after the trip. I think with this new info I am going to trim the seams a little more and purchase a set of bump stops. The rear is the only place where I am having a rubbing issue but most likely will do them all the way around.
I love the 37s but trust me I know mistakes have been made by not doing more research. This is the first jeep I've been moding myself.
I do live in Chicago so it is flat and I only get offroad every so often. I will say it is not an ideal set up but the 37's haven't made it to much of a dog. It still handles and drives very well. ( i drove a 4cyl TJ with 33s before this and that thing was awful)
Thanks for all the help guys!
2013 JKU
Kmin is offline
post #7 of 27 Old 09-16-2013, 01:35 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
follow this procedure:
http://www.jeepforum.com/forum/f96/j...arned-1513528/
he found 2.5" bumpstop extensions were needed for the front and 3" bumpstop extensions in rear....for 35s.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 27 Old 09-16-2013, 02:46 PM
rock-rocker
x2, heck of a good write up and this will give you an idea what you have to play with. I don't know how long you have had the lift installed but maybe when you were towing it got your springs settled and hopefully they wont sag anymore. If you can make the bump stops work then that's the way to go. Don't play with increasing the lift because you may be opening up a can of worms unless you have the $$$ to put into it.
One recommendation I have is if this is your first Jeep then before you go out and buy and install anything that modifies it get on Forums like this and ask who has done this before and get the lessons learned. We have all pretty much been there and done that and this stuff is just darn too expensive to learn the hard way. Believe me, I have learned the hard way too many times over. I can personally say that Forum's have saved me some cash and again has pissed me off. When I thought I had my heart set on something I had a reality check. Good luck and post what you do and how it works out for you. You never know, there's someone else out there with 37's and rubbing...
BTCS, USN, Retired
post #9 of 27 Old 09-16-2013, 03:05 PM Thread Starter
Kmin
Ok maybe someone can tell me how adding bumpstops will work...
Since I am sitting very close to the pinch seam already, I would have to add bumpstops pretty much to stop the upward travel where it is right now (in pictures). Wouldn't that mean I have no upward travel at all? Which would make for a very bumpy ride?
2013 JKU
Kmin is offline
post #10 of 27 Old 09-16-2013, 03:18 PM
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
There is some good advice here...
Another thing is the Rough Country coils. They don't give you enough height to run that large of a tire without some major issues that you are having. More cutting, more bumpstops (yes less uptravel), and more coil height can all be your friend here.
We have a JKU on 40's with 3.5" of lift. We have cut a TON in the rear but we can stuff our 40's in with flat fenders without to much issues...
-Jason
Phone: 864-437-8029
Forum Discount: KORJEEPFORUM
KrawlOff-Road is offline
post #11 of 27 Old 09-16-2013, 03:26 PM
Filthy-Beast
no magic, you understand it correctly. but you do have room to do a little pinch seam trimming that will help greatly. If it was me I'd cut this much if not more and then seal the end of the seam.
For Sale:
post #12 of 27 Old 09-16-2013, 03:52 PM
4wdjeepguy
You need 3" bumpstops front and rear
4wdjeepguy is offline
post #13 of 27 Old 09-16-2013, 06:05 PM
Unlimited04
did you read the linked thread?
Useful Write-Ups:
Funny:
post #14 of 27 Old 09-16-2013, 06:42 PM Thread Starter
Kmin
I did read some of the linked thread. It is quite extensive and I will defiantly be visiting it again soon.
Good news though! I went ahead and took another 1/2" off of the seam and I no longer have the rubbing. I do not think it will be enough when I get offroad, however I can drive it on the road again.
2013 JKU
Kmin is offline
post #15 of 27 Old 09-16-2013, 07:28 PM
JTPhoto
JTPhoto's Avatar
You also do not have enough wheel backspace. factory wheels at 6.75" backspace - 1.5" spacer only gives you 5.25 backspace. With 37" tires you should have 4-4.5" backspace. This will help give you room to flex + bumpstops to help protect inner fenders.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
37" , jk , lift , rub , unlimited
