Are JK's water proof - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Are JK's water proof
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-02-2006, 03:12 PM   #1
The Punisher
are Jk's water proof? Will I have any electrical problems if I flood it going through lake with a safari snorkel?
Thank you guys
1993 soft top 2.5L Jeep Wrangler
Mods: 4.88 gears front and rear, 36x12.50R16 Super Swamper TSL's with a 4" suspension lift, 2" BL, MORE boomerang shackles, KN drop-in filter with an ARB Safari Snorkel, Pacesetter headers, high-flow cat, Gibson cat-back, and a Herculined TUB
The Punisher is offline   Reply With Quote Quick reply to this message
Unread 10-02-2006, 03:48 PM   #2
Karamba
Thank you guys
Do you know any modern car, in particular a production car, that does not care about beeing flooded?
Karamba is offline   Reply With Quote Quick reply to this message
Unread 10-02-2006, 04:03 PM   #3
cab76
Thank you guys
Depends on the depth. As Karamba noted the JK (or the TJ for that matter) will have problems if you try to run too deep (even with a snorkel). I don't know specifically how deep the JKs will run but there have been some very impressive photos from the Africa trip showing the JKs with water past the door jambs and over the bumpers doing just fine.
cab76 is offline   Reply With Quote Quick reply to this message
Unread 10-02-2006, 05:05 PM   #4
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Thank you guys
Mods: 4.88 gears front and rear, 36x10.50R16 Super Swamper TSL's with a 4" suspension lift, KN drop-in filter with an ARB Safari Snorkel, Pacesetter headers, high-flow cat, Gibson cat-back, and a Herculined TUB
Based on your .sig file, it looks like you are wanting something that can replace your current offroader.
I imagine that all the electrical connections are weather-tight just as they are in our YJ's. A long dunking in a lake / river / stream (over night) might allow water to get into the connections, but quick jaunts through deep waters shouldn't harm it ... especially if you take the extra time to make sure that everything under the hood is sealed up as well as possible, the way you should have done with your YJ when you snorkled it up.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver 2006 TJ Unlimited, zombie ready as the daily-driver
- - - - - - -TEOTWAWKI- - - - - - -
NaeKid is offline   Reply With Quote Quick reply to this message
Unread 10-02-2006, 05:18 PM   #5
The Punisher
I was thinking, my jeep runs like a sloth. Either I want to put in an 8-cylinder chevy and be in it an other $1000, and have it be worth the same if not less. Or I want to get a newer wrangler with an I-6 in it from the start and invest money on that. What do you think is ideal Naekid? BTW, did you see my pictures?
Unread 10-02-2006, 05:22 PM   #6
92blazn
2010 JK Wrangler
Nock on wood but so far in water over my hood with a snorkle no issue, Just have to change diff fluids and my 5 speed Trans
2004 TJ (SOLD), 2010 4 Door 4x4 JK , 99 TJ , 99 WJ
Originally Posted by The Mean Fish
I'm not actually going for the wheeling, I just want to watch Ed drive his Jeep. :o
92blazn is offline   Reply With Quote Quick reply to this message
