JKI build thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > JKI build thread
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueOfficial Chassis Saver Rust Preventive Truck & Auto Un
Unread 07-23-2013, 11:59 AM   #31
mello
Originally Posted by GrandChe89
What is the correct tire pressure I should inflate my tires to?
Tire pressure is an opinion thing but the most u can run and tires still wear good the better the mpg. I have 35 in Mickey Thompson Mtz's and run 27psi. Anything over 30psi and I can feel it in the ride. Anything between 27 and 30 should've good.
mello is offline   Reply With Quote
Unread 07-23-2013, 01:34 PM   #32
442Wrangler
In like Flynn.
442Wrangler's Avatar
Do the chalk test...draw a line, make sure it all shows on the road (not a faint or heavy line) when you roll forward and then that's the magic numbah!
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1998 TJ Sahara Sold
-3.25" RC spring lift, Eagle alloys 125s, 33x12.5x15 Cooper STTs, XRC8 winch with stock bumper mount
1994 YJ SE Sold
-4" RC spring lift, 33x12.5x15 Firestone M/Ts, Eagle alloys 125, and a 4 cylinder to boot
1960 Willys Wagon
-Going to be restored and painted Omaha Orange
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
Male RN Jeep Club #1
442Wrangler is offline   Reply With Quote
Unread 07-23-2013, 03:37 PM   #33
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
I tried changing it to 28 psi but that didn't help much seems almost under inflated now, they were at like 33psi maybe I will change them back to 30... not sure. It isn't a bad wobble just a little something when I go like 45-50 mph. could it maybe be something else?
2010 JK Islander all stock right now but not for long
"Jeeps don't get stuck ... they just take a nap when they are tired of being awesome."
"Its more than just a jeep ... its a way of life!"
GrandChe89 is offline   Reply With Quote
Unread 07-23-2013, 04:21 PM   #34
mello
I would definitely do a quick rotate and check for those rings, that would Eliminate or confirm your most likely causes of your wobble.
Unread 07-23-2013, 04:46 PM   #35
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
I will have to do that tomorrow after work I will let you know my findings
Unread 07-23-2013, 07:45 PM   #36
TheBoss
malt, hops, yeast, water
TheBoss's Avatar
I'm inclined to agree with the previous post about removing the retaining tabs on the brake rotor. Your new rims do not have provisions for them like the stock rims. There are two per wheel and if are left in place they won't let the rim seat flush against the rotor.
JK : AEV, Synergy, JKS, Teraflex, Bilstein, GoodYear, M.B, LoD, Ramsey, Hella, Uniden, Smitty-re-bilt rails, Safari Straps
:sold:WJ : BDS, Teraflex, JK Rubicon shocks, GoodYear, JK wheels :sold:
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them." Thomas Jefferson
TheBoss is offline   Reply With Quote
Unread 07-24-2013, 01:18 AM   #37
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
I re-torqued my lug nuts last night and good thing too cause a couple were pretty loose, but now they are all at 100ft/lb so it should be good. I think that may have fixed my slight wobble but I will find out today when I get goin faster on the way to work.
Unread 07-24-2013, 06:48 AM   #38
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
So torquing the bolts helped a little but now it feels like a little shakey in the front end. So it might be my tires or those things on the wheels. Ill have to try rotating them
Unread 07-24-2013, 07:28 AM   #39
442Wrangler
In like Flynn.
What things on the wheels? Did I miss that?
2008 JK Rubicon
1998 TJ Sahara Sold
1994 YJ SE Sold
1960 Willys Wagon
-Steve McQueen
Unread 07-24-2013, 07:44 AM   #40
1222
Make mine a Jeep!
1222's Avatar
Why havenít you checked to see if those retaining clips are still on? If they are and your new wheels have no cutouts for them then that might also be the reason some of you lug nuts loosened up; cocked wheels. Although not noticeable by the naked eye they would still be uneven just the same.
If you want to trouble shoot a problem then you need to take one step at a time and eliminate things starting from the very basic and easiest things and work your way to solving the problem.
Torqueing the wheel isnít going to fix a wobble unless they (lug nuts) are all loose which I doubt they were.
1222 is online now   Reply With Quote
Unread 07-24-2013, 09:54 AM   #41
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
I just haven't had time yet. And I need to buy a new jack. I was using my dads but it **** the bed and doesn't like to stay up. What do the clips look like?
Unread 07-24-2013, 10:02 AM   #42
mello
Like this but a little bigger.
Unread 07-24-2013, 12:11 PM   #43
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
And those are on the lug nuts themselves? On each one or just one per wheel?
Unread 07-24-2013, 12:28 PM   #44
mello
They are not on the nuts they are on the lugs. They will be twisted up tight to brake rotor. There will two to three per wheel end.
Unread 07-24-2013, 03:03 PM   #45
GrandChe89
GrandChe89's Avatar
2010 JK Wrangler
thats what I meant, the lugs not lug nuts lol I am going to try switching the left front tire too cause it feels like that is the culprit. this wheel also has the most weights on it. the spare has far less so I will swap them out and also look for those and see if they are on there. How do you take them off just pull?
