JK Wrangler 2008 - Autolock doors problem - JeepForum.com
post #1 of 11 Old 04-01-2012, 02:33 PM Thread Starter
KenDWpg
Hi All,
Thanks in advance for any help with this.
My 2008 JK is doing some strange thing with the auto door locks (see video).
<iframe width="480" height="360" src="http://www.youtube.com/embed/ASP4e0nQpp4?rel=0" frameborder="0" allowfullscreen></iframe>
http://youtu.be/ASP4e0nQpp4
I hit the lock button on the key - and on the passenger front lock - it's like it tries to lock 10 times repeatedly really fast - and fails to lock.
I'm just seeing if anyone else has experienced this - and can fast track me to where to look?
I' have no idea if this is a wire, fuse, relay, mechanical .. or what?
Any ideas would be appreciated.
Thanks all.
Regards,
Ken
KenDWpg is offline
post #2 of 11 Old 04-02-2012, 02:26 PM
Jiblet
Well, that sucks!
I have to guess the power latch is going bad. About $80 for the part.
To see what's going on inside a half door google: K6860781
and you'll find the assembly instructions for the half door kits.
The half door is different from the full, of course, mainly in that there is no window to deal with. That and the half door latch isn't a power latch, not that there is much difference between the two types of latch.
At least you'll get an idea of what's going on inside the door.
good luck
Jiblet is offline
post #3 of 11 Old 04-06-2012, 12:37 PM Thread Starter
KenDWpg
Thanks "Jiblet"
That sounds like a good place to start. Should give me an idea of whats going on inside.
Thanks again.
KenDWpg is offline
post #4 of 11 Old 04-06-2012, 12:41 PM Thread Starter
KenDWpg
Ah. I also found these posts that have some handy pictures of the door assembly for a 2008 JK.
I'll let you know how it goes. I was just wondering if anyone else had this problem and if taking apart the door was necessary.
Thanks for your reply.
Ken
http://www.jkowners.com/forum/showthread.php?t=13393
KenDWpg is offline
post #5 of 11 Old 04-06-2012, 12:43 PM Thread Starter
KenDWpg
pic
KenDWpg is offline
post #6 of 11 Old 04-06-2012, 12:46 PM Thread Starter
KenDWpg
and
KenDWpg is offline
post #7 of 11 Old 04-06-2012, 01:09 PM Thread Starter
KenDWpg
Also found this post
http://www.jeepforum.com/forum/f96/h...007-jk-536543/
It looks to me like there are some differences with the various models and years - but the pain in the neck will likely be those "Push Pins"
45770d1225408879-how-do-you-remove-interior-door-plastic-panel-2007-jk-door-panel-removal-three.jpg
KenDWpg is offline
post #8 of 11 Old 04-06-2012, 01:10 PM
PhatJK
2009 JK Wrangler
Are these the pictures from your Jeep? I can see the door latch has two cables for pull open and pull close actions, like in dereailer shifting mechanism on bicycle. Maybe the plastic end is stripped or the cable popped out of the retaining bracket.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #9 of 11 Old 04-07-2012, 12:38 AM Thread Starter
KenDWpg
No, those pictures are not from my jeep.
But I know what you are saying, and I was thinking the same thing. But I have the door panel off now - and can see those "cables" and they seem to be working fine. The noise is coming from near the latch mechanism - but it looks like I'll have to remove the "carrier plate" (inside the inside of the trim) to get a better look.
Sounds like it may be as "Jiblet" said - the "power Latch". I'm taking pics and videos as I go - and I'll post it as soon as I'm done. Right now I'm stuck on STEP #6 from this post http://www.jeepforum.com/forum/f96/w...moval-1066985/ (that seems to explain it a little better)
There is this very tricky part of releasing the tabs from the window bracket in order to remove the "carrier plate" and allow you access to the other parts like the "power Latch".
I'm sure, once I get that far, that I'll be able to see what exactly is causing the problem.
Let ya know how it goes. It's getting cold her for the next few days - so I'll probably put the rest on the back burner for a while.
Regards,
KenDWpg is offline
post #10 of 11 Old 04-07-2012, 12:51 AM Thread Starter
KenDWpg
I gotta say right now - I was expecting those "Push Pins" to be a nightmare, but they really weren't.
Typically I have had bad luck with those - breaking them or the part I was trying to remove - applying pressure in the wrong places. But these worked pretty good.
Having a diagram, knowing where each one was, and therefore where to place the pressure with the screwdriver to pop them out - made a difference I'm sure - but they also seem built better and the female end as well more durable.
I later read another post where the guy just yanks on the whole door panel and they all just pop out. Having seen these now - it's the way to go.
-_-
KenDWpg is offline
post #11 of 11 Old 06-12-2012, 09:12 PM Thread Starter
KenDWpg
OK - so I'm going to try to "Re-Ask" for help on this one again - if that doesn't work - I may just re-post this.
I got the door assembly apart (Thanks very much for the helpful photos and links on how to do that.) and still can't figure it out.
I've got a new video up -
Anyone know the solution to this?
Hi all,
I’m looking for help with this “chattering” malfunctioning door lock on my 2008 Jeep Wrangler Sahara Unlimited. As you can see from the video, the lock on the passenger side will chatter and seemingly attempt to lock multiple times without success.
If I manually lock it - and then hit the lock button on the remote key - it will chatter and actually unlock the door I manually locked. Almost as if the mechanism was going the wrong way.
Occasionally it will successfully lock after the chattering.
I have been looking for the answer to this for about a month now. I had the door partially apart - and then had to tend to more pressing issues with the breaks on the Jeep. But now I’ve got the whole door assembly off - and am still not sure what the problem is. My next step is to dismantle the driver side and try to compare the two behaviours and see if I can get any clues that way.
I don’t know much about electronics, and worry that I am chasing down a mechanical problem that may be an electrical / relay problem.
Anyone had any experience with this? Maybe even on other vehicle types? I would appreciate any feedback that could help me isolate this problem.
Thanks in advance.
Ken
KenDWpg is offline
Need help to remove passenger door panels for a 2008 2 doors Wrangler carloslopez63 JK Wrangler Technical Forum 1 03-19-2012 07:18 AM
Problem with 2008 Wrangler pastime Wrangler General Discussion 6 05-10-2010 06:55 AM
2008 Wrangler Unlimited Soft Doors? blueescapes JK Wrangler Technical Forum 4 04-27-2009 08:01 AM
Autolock @ 15mph stopped working.. another other questions MacK JK Wrangler Technical Forum 11 01-06-2009 02:29 PM
2008 Jeep Wrangler X Fabric Doors DoNotRead JK Wrangler Technical Forum 3 01-19-2008 11:58 PM
