JK wheels - JeepForum.com
post #1 of 5 Old 12-11-2006, 12:58 PM Thread Starter
hbf7744
JK wheels
I'm looking at a JK unlimited X. Just wondering - what would be the biggest wheels and tires you can put on it without a lift? Will it fit the same tires and wheels as the Rubicon model or is the Rubicon equipped with a factory lift?
hbf7744 is offline
post #2 of 5 Old 12-11-2006, 01:07 PM
doojer
The Rubi is not lifted and it's the same body as the X and the Sahara so, yes, the 32" tires will fit without any rub. There are even folks running 33s on Xs and Saharas without any lift, but they do rub off-road at full articulation. Apparently, on pavement 33s are not a problem
- Jeep Green, Auto, 4:10, D30 front/D44 rear, RockCrusher Diff Covers
doojer is offline
post #3 of 5 Old 12-11-2006, 03:59 PM
LONTON
So I can put 33"s on my 4 door?
You're saying that 33"s won't rub even on a hard turn (wheel cut all the way - one way or another)? Looks like I am going with 33s.
Thanks - LT
LONTON is offline
post #4 of 5 Old 12-11-2006, 04:33 PM
doojer
Thanks - LT
From what I've heard (from folks running unlifted JKs with 33s) they do fine even at full turn but they start to rub pretty badly once you start flexing. If you plan on wheeling your JK and you don't plan on lifting it, I'd stick with 32s.
doojer is offline
post #5 of 5 Old 12-13-2006, 09:51 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
What width will I be able to put on my X w/ 17" wheels?
As far as I'm aware, the stock tires are 255x75R17s, I believe the 17" rims are 7.5" wide, what degree of flexibility over stock width will I have before I start rubbing anything?
I'm just wondering because there seems to be a dearth of decent off road tires in the stock size, which I'm assuming is too narrow.
Thanks.
Kyoseki is offline
Picked my wheels, which size wheels and tires for a DD? JYogi JK Wrangler Technical Forum 7 09-11-2007 06:58 PM
Will the lug nuts for Ravine Wheels fit Moab Wheels? Thunderstrike TJ Wrangler Technical Forum 7 03-07-2007 05:47 PM
Everyday wheels and Trail wheels...balancing problems? Tacoma750 TJ Wrangler Technical Forum 1 08-19-2006 07:31 PM
Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? BIGCRAZYBELL TJ Wrangler Technical Forum 4 11-28-2004 12:10 AM
