Jk trackbar bolt upgrade. DO IT!!! - Page 2 - JeepForum.com
post #16 of 20 Old 10-02-2013, 09:34 AM
tslewisz
2010 JK Wrangler
Originally Posted by Nsiavosh90 View Post
So for 13$ I went to our local hardware store and picked up x2 9/16 18unf x 3.0 grade 8 shouldered bolts with washers and x2 9/16 18unf stover top lock nuts and I am amazed I haven't done this sooner. Shortly after my 2.5 rubicon express lift and new joints all the way around ( ball joints, drag links, tie rod ends and a rubicon express steering stabilizer) I was still getting massive shakes (and one occurrence of DW) in the steering wheel over bumps. Only a days worth of driving with new trackbar bolts in but what a difference in the feel over bumps. Just wanted to back everyone who has said to do this upgrade on the forum and encourage every jk owner to swap out those 14mm bolts with threads all the way to the head of the bolt.
Good stuff. 2 bolts? Did you do both ends of the front or 1 end on each?
tslewisz is offline
post #17 of 20 Old 10-03-2013, 01:23 PM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
With what came in my AEV and Northridge kit combined, I have replaced both ends on trackbar, both ends on upper CA's and frame side on lower CA's. As per this thread I ordered the synergy cam washers and will be replacing axle side lower CA's. Easy and inexpensive upgrade.
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #18 of 20 Old 10-03-2013, 03:34 PM
Mfrancis
2014 JK Wrangler
^Which AEV kit do you have? I'm leaning towards the 2.5" dual sport kit.
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #19 of 20 Old 10-03-2013, 06:04 PM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Sorry, I was referring to the AEV geo correction bracket kit. It came with sleeves for the OEM metric bolts on the upper and lower CA's frame side to eliminate the threads. I have heard good things about that lift though. Cheers!
post #20 of 20 Old 09-17-2015, 09:00 PM
tcrazy
2014 JK Wrangler
Thanks for posting. This helped.
tcrazy is offline
